Randomized
Sk8erPeter
#3285
Script:
$(document).ready(function(){
var alert = $('#alert');
$("form:not('#regis'):not('#ranglista')").submit(function(e){
e.preventDefault();
var triggeredform = $(this);
$.ajax({
type: 'POST',
url: pageurl+$(this).attr('action'),
data: $(this).serialize(),
dataType: 'json',
encode: true
.done(function(data){
console.log(data);
if(!data.success){
//Ha nem sikerül
var errormessage = '';
$.each(data.errors,function(index,value){
errormessage = errormessage + value + '<br/>';
alert.css("background","#990000").html(errormessage).fadeTo(500,0.8).delay(3000).fadeOut();
else
//Ha sikerül
alert.css("background","#00FF00").html(data.message).fadeIn().delay(2500).fadeOut();
console.log(this);
// triggeredform.fadeOut();
if(data.reload == true)
window.setTimeout(function(){
window.location.href = pageurl+data.tourl;
},data.timeout * 1000)
}).fail(function(data){
alert.css("background","#FF0000").html("Szerver oldali hiba").fadeTo(500,0.8).delay(5000).fadeOut();
});Feldolgozó PHP:
<?php
error_reporting(0);
require("config.php");
require("functions.php");
session_name("MyHomePage");
session_start();
$conn = mysqli_connect($conf_host, $conf_user, $conf_password);
$errors = array();
$data = array();
if(empty($_POST['userid']))
$errors['user'] = 'Nem adtál meg felhasználó nevet!';
if(empty($_POST['userpass']))
$errors['pass'] = 'Nem adtál meg jelszót!';
if(!isset($errors['user']) && !isset($errors['userpass']))
$user = mysqli_real_escape_string($conn,$_POST['userid']);
$pass = mysqli_real_escape_string($conn,$_POST['userpass']);
$query = mysqli_query($conn,"SELECT * FROM hp.users WHERE name LIKE '$user' AND password=PASSWORD('$pass') LIMIT 1");
if(mysqli_num_rows($query) != 1)
$errors['login'] = 'Hibás felhasználó név vagy jelszó!';
if(!empty($errors))
$data['success'] = false;
$data['errors'] = $errors;
else
$userinfo = mysqli_fetch_object($query);
$_SESSION['user_id'] = $userinfo->id;
$_SESSION['user_name'] = $userinfo->name;
$_SESSION['user_rank'] = $userinfo->rank;
$data['success'] = true;
$data['message'] = "Sikeres bejelentkezés!";
$data['reload'] = true;
$data['tourl'] = "/?oldal=felhasznalo";
$data['timeout'] = 0.5;
echo json_encode($data);
Randomized
Egy kis segítségre lenne szükségem jQuery-AJAX-PHP kombinációban, remélem jó helyen járok.
Szóval fejlesztek egy weboldalt, minden okénak tűnt. Windows-on tesztelem XAMPP programcsomaggal, localhost-on szoktam tesztelni. Megpróbáltam havernak megmutatni, hogy tesztelje le a dolgokat, hátha talál benne hibát, de neki nem volt jó egy része (mindjárt írok részleteket is). Szóval megpróbáltam én is, nálam jó volt (megint csak localhoston próbáltam). Utána megpróbáltam én is úgy, hogy beírtam az IP-címemet, azzal nekem sem volt jó.Egy olyan dolgot akartam megcsinálni, hogy például regisztrációkor a script elküldi a form tartalmát egy PHP-nak, ami feldolgozza az adatokat, és értesíti a felhasználót az oldal újratöltése nélkül az eredményről.
Bejelentkezésnél is hasonló a helyzet. Kiírja, hogy sikerült bejelentkezni, de mégsem működik a dolog.$_SESSION-al oldanám meg, ha ez számít.
Tehát ha "localhost" címen próbálkozok, akkor jó, de ha bármilyen IP-címen próbálkozok (pl. 127.0.0.1, 192.168.1.109) akkor a PHP-tól megkapja a választ, a php temp mappájában látszik is, hogy létrehozza a session adatait tároló fájlt, megnyitom és valóban benne vannak, a dolgok, amiknek ott kell lenniük.
Remélem valaki tudja, hogy miért csak akkor működik, ha localhoston nyitom meg az oldalt. Előre is köszi a segítséget
- Projektor topic
- Android szakmai topik
- Házimozi belépő szinten
- BestBuy topik
- OLED TV topic
- hcl: Google Drive csatolása szerveren / Nextcloud integráció
- BESZÁMÍTÁS! Asrock B450M R5 4500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus DeepCool 400W
- Precision 7760 27% 17.3" FHD IPS i7-11850H RTX A3000 32GB 512GB NVMe magyar vbill gar
- BESZÁMÍTÁS! ASRock H410M i5 10400F 16GB DDR4 512GB SSD GTX 1080 Ti 11GB Zalman T3 Plus Gigabyte 650W
- BESZÁMÍTÁS! Asus B150M i5 7400 8GB DDR4 128GB SSD 1TB HDD GTX 1060 3GB Zalman T3 Plus DeepCool 400W
- BESZÁMÍTÁS! Gigabyte B650M R7 8700F 64GB DDR5 1TB SSD RTX 5070 Ti 16GB Lian LI LANCOOL207 ADATA 850W
- HP 255 G8 - 15.6" FullHD IPS - Ryzen 5-5500U - 8GB - 512GB SSD - Win11 - MAGYAR - ÚJ AKKU
- BESZÁMÍTÁS! 64GB Patriot Viper 3600Mhz DDR4 memória garanciával hibátlan működéssel
- GYÖNYÖRŰ iPhone 12 Mini 64GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4167, 94% Akksi
- Samsung Galaxy A04s / 3/32GB / Kártyafüggetlen / 12Hó Garancia
- Akció! Gamer PC-Számítógép! Csere-Beszámítás! I9 13900 / RTX 3090 24GB / 32GB RAM / 1TB SSD
