e-biza
4053hoz help meg minden.
[L]http://www.microbeta.net/4053.htm[/L]
a WinFS angolul: szvsz ez nem láthato :))
What is ''WinFS''?
''WinFS'' is the active storage subsystem in ''Longhorn'' that is used for searching, organizing, and sharing data. ''WinFS'' maintains a store of items and their properties, and provides a system service in ''Longhorn'' to retrieve information when it's needed. Because ''WinFS'' allows organization and retrieval of items based on properties (such as author or title), users can find things more quickly. Users can also organize, relate, and act on their documents, music, photos, e-mail, calendar information, and other types of items more efficiently.
What are the benefits of Using ''WinFS''
In ''WinFS,'' how information is organized is separate from how that information is stored physically. How users and applications organize information is also separate from how the information is saved. Data can be organized using a connected folder structure, namespaces, properties, tables, invariant identities, or relationships.
To benefit developers, the ''WinFS'' platform supports unified data services for all end-user applications. Integrated data services such as synchronization, notification, a unified store, and a common security model, and their integration with other technologies such as peer-to-peer networking and directory services, make data sharing among applications easier. These data services enable you to write applications that exchange data with applications built by other software developers. Also, ''WinFS'' works with other Windows-based technologies to allow information sharing remotely with both ''WinFS'' and non''WinFS'' stores.
What is ''WinFS'' capable of?
''WinFS'' supports efficient indexing of file content, which enables rich querying that is very difficult to achieve with other file systems. For example, in ''WinFS'' it is easy to search files based on their content and other criteria such as file name, title, author, or date of publication. This would be difficult, if not impossible, in a traditional file system such as NTFS. In addition, ''WinFS'' still has efficient streaming capabilities—the cornerstone of traditional file systems—to handle large data values.
''WinFS'' can also be used with computers running earlier versions of Windows that support the NTFS file system. Files stored in ''WinFS'' can be accessed using the new ''WinFS'' API or the existing Win32 API. Therefore, existing Win32 applications can work with files stored in ''WinFS'' with little or no modification.
In ''Longhorn,'' files can be stored either in ''WinFS'' or on NTFS, but ''WinFS'' is more efficient and effective than NTFS for organizing, searching for, and sharing files. ''WinFS'' is particularly useful for storing data that needs to be queried or shared by users or applications. Advantages are largely because ''WinFS'' data is schematized, and the items can be related to each other in more than one way and, therefore, can be searched in multiple ways. You can still use NTFS for storing files that have few or no searching and sharing requirements. In fact, ''Longhorn'' uses NTFS for all the Windows system files needed for starting up and running the system.
ez biztosan szemmel láthato? :))
ami a sok pletykát illeti, a microsoft megerösitette az idén nyáron MSND elöfizetöknek elérhetö beta eljövetelét - legalábbis emlékeim szerint.
[Szerkesztve] -
e-biza
szerintem jo program, nem instabil, a winfs pedig soha nem lesz láthato, annak a feladata más. 4053 a legfrissebb. de várhato egy beta most nyáron, természetesen zártkörü, msdn elöfizetöknek lesz csak, de ismerjük mi már azokat az embereket ieXbetas winbetas, betasirc stbstb. összeségében csak kiprobálás céljára érdemes feltenni, nem valami izgalmas egyelöre.
[Szerkesztve]
- Hobby elektronika
- Fotók, videók mobillal
- OLED monitor topic
- EarFun Air Pro 4 - a cél a csúcs
