HAIMAN
Alukard
#2316
őőő, jogos ...
még két kérdés, wind-en gyárilag lévő winXP-re, m$ eredetiségvizsgálója:"Windows XP Genuine Validation Results Windows XP Genuine Validation Results This copy of Windows did not pass genuine validation.
The product key found on this computer was issued to an organization that is no longer using the key.
The Windows product key found on your computer is a Volume License Key (VLK). A VLK is typically licensed to an organization that wants to use multiple copies of Windows. When a VLK is reported as stolen or leaked, or the organization stops using the VLK, the VLK is blocked from passing validation.The product key used to install your copy of Windows was issued to an organization that is no longer using the key.
If you believe you are a valid user of this key, contact the organization from which you purchased your PC for assistance.
If you received a computer with a VLK and you do not have a Volume License Agreement with Microsoft, you may be a victim of software counterfeiting. Learn how to get genuine below."
ez elég wtf, megoldás?
An Overclocking CPU with TurboDrive
The Wind NB includes a TurboDrive button (activated by pressing Fn+F10), which overclocks the system’s CPU by as much as 20 percent. When the TurboDrive is turned on and the system is plugged in, an orange icon flashes in the corner of the screen and the power button changes from blue to orange. Running a CPU Speed Professional test with the TurboDrive turned on, the CPU clocked in at 1.9 GHz.
[An Overclocking CPU with TurboDrive]
csak nekem nem megy?
HAIMAN
Alukard
#2310
[ file sharing between vista & xp] már müxik, tényleg csak nemtudomijez Link Layer Topology Discovery (LLTD) Responder hiányzott
- Biztosan felbúgnak a ventilátorok az új GeForce driverrel
- Diablo II: Classic és Resurrected
- LCD, plazma és projektoros TV-k hibái
- AliExpress tapasztalatok
- OLED monitor topic
- Óra topik
- Huawei Watch GT 3 Pro - korlátolt szépség
- Parkside szerszám kibeszélő
- Acer Aspire 3 A317-53-76NV. Intel 11.gen I7 / 16Gb ram / 512Gb ssd / 17,3"
- ÚJ BONTATLAN Apple Macbook Air 15,3 M4 10C CPU/10C GPU/16GB/256GB - Égkék - HUN - mc7a4mg/a 3 év gar
- ÚJ Apple Macbook Air 15,3 M4 10C CPU/10C GPU/16GB/256GB - Ezüst mw1g3mg/a - 3 év gari - MAGYAR
- Újszerű Acer Nitro 5 - 17.3" QHD 165Hz - i9-12900H - 32GB - 1TB - RTX 4060 - Win11
- Újszerű HP EliteBook 640 G11 2028.12.Hó-ig Garis Ultra 5 135U 16GB DDR5 512GB SSD 9nap üzemidővel!
