e-biza
[L]http://www.quake.co.il/modules/news/article.php?storyid=117[/L]
Here are the NV40 specs:
300-350 Million Transistors on 90-nm process
750-800 MHz Core
16MB Embedded DRAM (134M trans.)
1.4 GHz 256-512MB DDR-II Memory
8 Pixel Rendering Pipelines (4 texels each)
16 Vertex Shader Engines
204.8 GB/sec Bandwidth (eDRAM)
44.8 GB/sec Bandwidth (DDR-II)
25.6 GigaTexels per Second
3 Billion Vertices per Second
DirectX 10 (or extended 9.1)
Release H2 2004
We will release more data as soon as it comes available to us.
***The data above is not official, and shouldnt be treated as such.
To compare, here are the NV30 Specs
0.13u process
500 MHz core clock speed
500(1Ghz) MHz 128-256MB DDR-II
125 M transistors
8 pixel pipelines with 2 texturing units each
16 texture layers per rendering pass
3.2 gigapixels per second
6.4 gigatexels per second
360-400 million vertices per second
16 gigabytes/sec
DirectX 9.0+ features (Pixel Shader 2.0+, Vertex Shader 2.0+, etc.)
128 and 64-bit Floating-Point Pixel Processing
Quad Vertex Shader Engine
Improved FSAA (Programmable Grid AA or Adaptive AA)
Improved HSR (Lightspeed Memory Architecture III)
AGP 3.0 (AGP 8x)
- Rajzfilmen az életed: Teszten a Dear me, I was...
- Nintendo Switch
- Samsung kuponkunyeráló
- Milyen okostelefont vegyek?
- LEGO klub
- Kutya topik
- Amit látnod kell 80’ – 90’ évek, egész estét betöltő mozi filmjei.
- GYÖNYÖRŰ iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4022
- Dell Latitude Precision Üzleti gépek, 2-in-1 gépek, 3-11. gen.
- Behringer B-CONTROL BCF2000 USB/MIDI kontroller
- Acer Chromebase All-in-One PC 23.8" Touchscreen
- HIBÁTLAN iPhone 12 Pro Max 128GB Pacific Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4517, 100% Akksi
