tituszvagyok
#467
Pont most voltam ilyen helyzetbe én is pendrive-al, írásvédettet ordibált, formázni nem lehetett ...
nekem ez megoldotta:
Click start
then run regedit
go to this directory HKEY_LOCAL_MACHINE\SYSTEM\Currentcontrolset\control\
if you can't find StorageDevicePolicies under control folder
then make some new one. Follow this steps:step 1:
again and right click control folderstep 2:
select new, then click key and rename the new key #1 folder into
StorageDevicePoliciesstep 3:
right click StorageDevicePolicies folder and select new DWORD(32-bit) Value
for 32-bit Operating System and select new DWORD(64-bit) Value
for 64-bit Operating Systemstep 4:
rename dword newer folder into WriteProtect, then double click WriteProtect
and change the value data into 0 with hexadecimal base, Then close regeditstep 5:
open my computer and refresh it 5 times without do anything to your usb, and
properly eject your flash drivestep 6:
plug in your usb again into your computer and format it using exfat instead of fat32Now, you can use your flash drive again....
- MWC 2026: Szuperpixelekkel takarékoskodik a TLC CSOT
- Linux kezdőknek
- Samsung kuponkunyeráló
- MWC 2026: nézni szabad, megérinteni nem
- HP Victus Gaming Laptop RTX 4070 / i7-13700H 16GB DDR5 1TB SSD Garancia
- 152 - Lenovo LOQ (15IRH8) - Intel Core i5-12450H, RTX 4060 (ELKELT)
- iPhone 13 128GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS4593, 100% Akkumulátor
- 216 - Lenovo Legion Slim 7 (16IRH8) - Intel Core i7-13700H, RTX 4060
- Lenovo ThinkPad T14s Gen 2 i5-1135G7 16GB 1000GB FHD 1 év garancia
