olli
VB6-ban írt pcthermometer programmal kapcsolatban felmerült:
8 db DS 1624 szenzort lehet címezni, egy további ADS 7828E 8 csatornás konvertert kellene I2C vonalon csatlakoztatni.
Az ADC címe megegyezik a szenzorok egyikével, &H48, a csatorna kiválasztását hogyan kell beszúrni,
Csatorna címe pl &H21, &H23, &H24
"The address byte is the first byte received following the
START condition from the master device. The first five bits
(MSBs) of the slave address are factory pre-set to 10010.
The next two bits of the address byte are the device select
bits, A1 and A0. Input pins (A1-A0) on the ADS7828 determine
these two bits of the device address for a particular
ADS7828. A maximum of four devices with the same pre-set
code can therefore be connected on the same bus at one
time.
The A1-A0 Address Inputs can be connected to VDD or digital
ground. The device address is set by the state of these pins
upon power-up of the ADS7828.
The last bit of the address byte (R/W) defines the operation
to be performed. When set to a ‘1’ a read operation is
selected; when set to a ‘0’ a write operation is selected.
Following the START condition the ADS7828 monitors the
SDA bus, checking the device type identifier being transmitted.
Upon receiving the 10010 code, the appropriate device
select bits, and the R/W bit, the slave device outputs an
acknowledge signal on the SDA line.The ADS7828 operating mode is determined by a command
byte which is illustrated above.
SD: Single-Ended/Differential Inputs
0: Differential Inputs
1: Single-Ended Inputs
C2 - C0: Channel Selections
PD1 - 0: Power-Down Selection
X: Unused
See Table I for a power-down selection summary.
See Table II for a channel selection control summary.
MSB 6 5 4 3 2 1 LSB
1 0 0 1 0 A1 A0 R/W
PD1 PD0 DESCRIPTION
0 0 Power Down Between A/D Converter Conversions
0 1 Internal Reference OFF and A/D Converter ON
1 0 Internal Reference ON and A/D Converter OFF
1 1 Internal Reference ON and A/D Converter ON
- Helldivers 2 (PC, PS5)
- Home server / házi szerver építése
- World of Tanks - MMO
- Hitelkártyák használata, hitelkártya visszatérítés
- Így tüzelt el százbillió forintot az AI a héten
- HIBÁTLAN iPhone 14 Pro Max 128GB Purple -1 ÉV GARANCIA - Kártyafüggetlen, MS3918
- Akko 3098 /DE/PBT/RGB/Wireless/Hot swap/Yellow switch/
- AKCIÓ! Dell Latitude 3530 üzleti notebook - i5 1235U 8GB DDR4 512GB SSD Intel Iris Xe WIN11
- Dell S3221QSA 32 4K UHD Ívelt Monitor 27% ÁFÁS
- Új MSI 15 Cyborg FHD IPS 144Hz i7-13620H 10mag 16GB 512GB SSD Nvidia RTX 4060 8GB Win11 Garancia
