Keresés
  • XaraX
    Width 1024
    Height 768
    Anti-Aliasing None
    Post-Processing No
    Texture Filtering Optimal
    Max Anisotropy 4
    Vertex Shaders Optimal
    Force PS 1.1 in GT2 & GT3 No
    Repeat Tests Off
    Fixed Framerate Off
    Comment
    3DMark Score 5594 3DMarks Game Tests
    GT1 - Wings of Fury 168,6 FPS Game Tests
    GT2 - Battle of Proxycon 37,1 FPS Game Tests
    GT3 - Troll's Lair 32,9 FPS Game Tests
    GT4 - Mother Nature 37,4 FPS Game Tests
    CPU Score 620 CPUMarks CPU Tests
    CPU Test 1 70,0 FPS CPU Tests
    CPU Test 2 10,9 FPS CPU Tests
    Fill Rate (Single-Texturing) 0,0 MTexels/s N/A Feature Tests
    Fill Rate (Multi-Texturing) 0,0 MTexels/s N/A Feature Tests
    Vertex Shader 0,0 FPS N/A Feature Tests
    Pixel Shader 2.0 0,0 FPS N/A Feature Tests
    Ragtroll 0,0 FPS N/A Feature Tests
    No sounds 0,0 FPS N/A Sound Tests
    24 sounds 0,0 FPS N/A Sound Tests
    60 sounds 0,0 FPS N/A Sound Tests
    System Info
    Version 3,4
    CPU Info
    Central Processing Unit
    Manufacturer AMD
    Family AMD Athlon(tm) XP 2500+
    Internal Clock 1870 MHz
    Internal Clock Maximum 3000 MHz
    External Clock 169 MHz
    Socket Designation Socket A
    Type
    Upgrade ZIF Socket
    HyperThreadingTechnology N/A
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
    Version AMD Athlon(tm) XP 2500+
