OpenWrt topic
katalin888
Mi a gond a konfiggal? Nem akar csatlakozni a netre, pedig a MAC address jol van megadva.
root@OpenWrt:~# vi /etc/config/networkconfig interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'config interface 'lan'
option ifname 'eth0.1'
option type 'bridge'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'config interface 'wan'
option ifname 'eth0.2'
option proto 'dhcp'
option macaddr 'XX:XX:XX:XX:XX:XX'config interface 'wan6'
option ifname '@wan'
option proto 'dhcpv6'config switch
option name 'rt305x'
option reset '1'
option enable_vlan '1'config switch_vlan
option device 'rt305x'
option vlan '1'
option ports '0 1 2 3 5 6t'config switch_vlan
option vlan '2'
option ports '4 6t' -
katalin888
Erre megoldast...???
katalin888
Intruder2k5
#3179
BusyBox v1.19.4 (2014-01-09 06:42:02 UTC) built-in shell (ash)
Enter 'help' for a list of built-in commands._______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
BARRIER BREAKER (Bleeding Edge, r39211)
* 1/2 oz Galliano Pour all ingredients into
* 4 oz cold Coffee an irish coffee mug filled
* 1 1/2 oz Dark Rum with crushed ice. Stir.
* 2 tsp. Creme de Cacao
root@(none):/# mount_root
mount_root: No jffs2 marker was found -
katalin888
Fonera 2.0n, OpenWrt r39211 (Trunk)
Csak telnettel erem el a routert,de ahogy ssh-ra akaro valtani ezt kapom:
root@(none):/# passwd
Changing password for root
New password:
Retype password:
passwd: /etc/passwd: Read-only file system
passwd: can't update password file /etc/passwdMost ismerkedem igy segitsetek, hogyan tudo ujra eletet lehelni a routermbe!
katalin888
Fel van rakva csak elfelejtettem ezt is beszurni!!!
opkg install usb-modeswitch usb-modeswitch-data
Package usb-modeswitch (1.2.3-2) installed in root is up to date.
Package usb-modeswitch-data (20120120-1) installed in root is up to date. -
katalin888
BUEK! Van ket 3G USB modem nalam amivel egyutt kellene mukodjon az openwrt (AA 12.09) fonera 2.0n router, de idaig meg nem sikerult egyikkel sem mukodesre birnom!
3G modemek:
Option GI1515
Huawei E3131opkg list_installed | grep usb-serial
kmod-usb-serial - 3.3.8-1
kmod-usb-serial-option - 3.3.8-1
kmod-usb-serial-wwan - 3.3.8-1cat /proc/bus/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 3.03
S: Manufacturer=Linux 3.3.8 dwc_otg
S: Product=DWC OTG Controller
S: SerialNumber=dwc_otg.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256msT: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 5 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=12d1 ProdID=151d Rev= 1.02
S: Manufacturer=HUAWEI
S: Product=HUAWEI Mobile
C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=(none)
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=02 Prot=16 Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
I: If#= 1 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=(none)
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=03 Driver=(none)
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=02 Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0msroot@OpenWrt:~# ls /dev/ttyUSB*
ls: /dev/ttyUSB*: No such file or directoryMi lehet a gond? Varom az otleteket!
katalin888
Probaltam ezt is:
Pinging 192.168.1.1 with 32 bytes of data:
PING: transmit failed. General failure.
PING: transmit failed. General failure.Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),Akkor most allitsam be a 192.168.1.1-t az IP Properties-nel?
katalin888
Most mar mindent felraktam, hatha valaki hozza tud szolni.
A lenyeg, hogy utana nem tudok kapcsolatot letesiteni es a net sem megy
. (szerencse van egy regi router amit most hasznalok) -
katalin888
Most megprobaltam az errico fele imaggel is, lad itt.
Minden jonak tunik,
es most megint elerhetetlen a router!
Hat ilyen
katalin888
katalin888
#2836
Esetleg valami otlet meg... ?
En arra gondolok, hogy serul az image letoltes kozben, annak ellenere, hogy azt jelzi, hogy 100%.... -
katalin888
Sikerult felelesztenem a fonera 2.0n routeremet es felrakni a a fonera 2.3.7.0 DEV firmwaret.
Ez utana most az openwrt factory imageval probalkoztam, de azzal sem sikerult!, pedig mindent a leiras szerint csinaltam.
Mi lehet a gond?
Idaig meg nem fogott ki rajtam meg egy ilyen egyszeru flashheles! brrrPutty-val SSH login:
wget http://downloads.openwrt.org/attitude_adjustment/12.09/ramips/rt305x/openwrt-ramips-rt305x-fonera20n-squashfs-factory.bin
mtd -r write openwrt-ramips-rt305x-fonera20n-squashfs-factory.bin image
katalin888
Intruder2k5
#2811
Ok! Azert koszi!Hatha valaki tud segiteni... :-(
katalin888
Pedig itt is ez volt fent!
Akkor most mit tudok tenni, csak van ra megoldas!? :/
katalin888
A fonera 2.0n routeremre szerettem volna felrakni az openwrt romot, de valami rosszul sulhetett el, mert utolag most mar nem is tudom pingelni a routert!
Mi lehet a gond?
wget -O fonera.img http://downloads.openwrt.org/attitude_adjustment/12.09/ramips/rt305x/openwrt-ramips-rt305x-fonera20n-squashfs-sysupgrade.bin
mtd -r write fonera.img image -
katalin888
vargalex
#1092
Koszi!
Akkor gondolom mar jobban is teljesit mint a WDR3600 es nem vonatkozik az alabb allitas ra.
"The most compelling other budget option is the TP-Link TL-WDR3500, a model which is available new for just $50, and beats the EA2700 in 5GHz downlink transfer speeds. I still prefer the EA2700, because the TP-Link does quite poorly in the 2.4GHz transfer tests (important for getting good performance with older wireless devices) and it’s advantage in 5GHz transfers isn’t dramatic."
katalin888
Valaki tudja, hogy mi a különbség a TP-LINK TL-WDR3500 és WDR3600 között?
katalin888
Peter789
#1003
En a TL-WDR3600 nezegetem.
Erdekes, hogy egy antennaval tobb van WDR4300-nak megis a kulfoldi osszehasonlito teszben szinte elhanyagolhato a wireless teljesitmenybeli kulonbsege..."The TL-WDR3600 performs the same as the more expensive WDR4300"
Nektek mi a velemenyetek errol?
Tudasban se nagyon kulonbozik ha jol neztem..... -
katalin888
A legjobb ar/telj.-ben melyik routert ajanljatok amelyire operWRT-t is lehet rakni???
Varom a javaslatokat? -
katalin888
ar/telj.ben melyik a legjobb router???
- MWC 2026: Farsangra Galaxy Ultrának öltözött a gyerek
- Arc Raiders
- Hővezető paszták
- Fejhallgatós találkozó
- Crimson Desert
- PCIe 5.0/4.0/3.0 Riser kábelek 90-os hajlított csatlakozóval (220mm/300mm)
- Samsung 16GB DDR5 5600MHz M425R2GA3PB0-CWM
- Gamer PC-Számítógép! Csere-Beszámítás! R5 3600X / GTX 1080Ti 11GB / 16GB DDR4 / 512 Nvme SSD
- BOMBA ÁRrR! Lenovo ThinkPad T14 Gen 4 Ryzen 5 PRO 7540U 14" FHD+ 32GB 1TB Lenovo gar: 2028.01.07!
- Pixel 7a Dobozában
