ReFleXx
Thx az eddigi hozzaszolasokat.
A problema meg lett oldva. -
ReFleXx
Nemtom h monde ez vmit.
A log ezt irja:
[00:00:00:032] +------- BeSweet -----
[00:00:00:032] | Input : C:DVD2AVI_176m AC3 T02 2_0ch 192Kbps DELAY 0ms.ac3
[00:00:00:032] | Output: C:DVD2AVI_176m AC3 T02 2_0ch 192Kbps DELAY 0ms.wav
[00:00:00:032] | RIFF header will be added
[00:00:00:032] | Floating-Point Process: Yes
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Input Channels Mode: 2/0, Bitrate: 192kbps
[00:00:00:000] | Output Stereo mode: Dolby surround compatible
[00:00:00:000] | Total Gain: 0.000dB, Compression: None
[00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +-------- LAME -------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | MP3 bitrate : 128
[00:00:00:000] | Channels Mode : Joint Stereo
[00:00:00:000] | Error Protection: No
[00:00:00:000] +---------------------
[00:00:08.890] E31: Compositely coded 3-level value >26
[00:00:20.570] E31: Compositely coded 3-level value >26
[00:00:58.778] E33: Illegal symmetric 7-level value =7
[00:02:07.514] E31: Compositely coded 3-level value >26
[00:02:13.722] E31: Compositely coded 3-level value >26
[00:02:13:728] Conversion Completed !
[00:02:13:728] Actual Avg. Bitrate : 128kbps
[00:00:16:000] <-- Transcoding Duration
Logging ends : 05/26/03 , 00:08:22. -
ReFleXx
''c:!!!BeSweetGUIv0.6b73BeSweet.exe'' -core( -input ''C: AC3 T02 2_0ch 192Kbps DELAY 0ms.ac3'' -output ''C: AC3 T02 2_0ch 192Kbps DELAY 0ms.wav'' -wavmp3 -logfilea ''c:!!!BeSweetGUIv0.6b73BeSweet.log'' ) -azid( -s surround2 ) -ota( -d 0 ) -lame( -b 128 ) -profile( ~~~~~ Default Profile ~~~~~ )
ez+ a command line. -
ReFleXx
Hi!
Mondjatok mar vmi jo progit amivel ac3 bol wavba vagy mp3ba lehet konvertalni.
Eddig a beesweetel probalkoztam kisebb nagyobb sikerrel. Egy 1oras ac3bol csupan 2 percet akart csak atkonvertalni.
help.
thx
- Acer LED monitor (B247Y)
- BESZÁMÍTÁS! Asus PRIME H510M i5 11400 16GB DDR4 512GB SSD RX 6600 8GB Rampage SHIVA Adata 600W
- Beszámítás! Benq Zowie XL2411 24 144Hz FHD TN 1ms monitor garanciával hibátlan működéssel
- Dahua 22" FULL HD IPS LED monitor 100Hz
- MacBook Pro 13, 14, 15, 16, MacBook Air M1, M2 M3 M4 bill magyarosítás lézerrel / sapkacserével
