Sa1ndor
Betettem egy wnaspi filet és szereztem egy nerot. Lelkiismeretesen másol a cdíróra, legalábbis a halott hangok és fények alapján. DE pontosabban nem másol semmit, hibaüzenetet nem ad. Ezt írja ki a naplóba:
Kende Sándor
jfk
1502-4120-1246-0757-1137-5514
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2004.08.15. 21:02:52
ahead WinASPI: File 'C:PROGRAM FILESAHEADNEROWnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 1998.08.20. 13:31:44
Nero Version: 5.5.9.9 (Nero Express)
Recorder: < Image Recorder> Version: Nem elérhető - HA -1 TA 0 - 5.5.9.9
Adapter driver: <Virtual Device> HA -1
Drive buffer :
CD-ROM: <TEAC CD-W552E> Version: 1.09 - HA 0 TA 1 - 5.5.9.9
Adapter driver: <ESDI_506> HA 0
Bus Type : default (0) -> ATAPI, detected: ATAPI
TEAC CD-W552E (Target 1, E:): Autoinsert On, DMA Off, Disconnect Off, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 17825792 (17825792) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 95MB (97732kB)
Free physical memory: 11MB (11828kB)
Memory in use : 100 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
17.8.2004
CD-ROM (ISO)
1:17:03 #1 Text 0 File Isodoc.cpp, Line 6003
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
1:17:03 #2 Text 0 File Reader.cpp, Line 118
Reader running
1:17:03 #3 ISO9660GEN -11 File geniso.cpp, Line 4488
First writeable address = 0 (0x00000000)
1:17:03 #4 Text 0 File Burncd.cpp, Line 3542
Turn on Track-At-Once, using CD-R/RW media
1:17:03 #5 Text 0 File ThreadedTransferInterface.cpp, Line 663
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 600 (600) = #600/0:8.0
relocatable, CD pos for caching/writing not required/required, no patch infos
1:17:03 #6 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 2147483646 (477218:37.21)
Last address to be written: 599 ( 0:09.74)
1:17:03 #7 Text 0 File DlgWaitCD.cpp, Line 204
Write in overburning mode: FALSE
1:17:03 #8 Text 0 File DlgWaitCD.cpp, Line 1403
Recorder: Image Recorder;
CD type reading failed
ATIP Data: ?
1:17:05 #9 Phase 40 File dlgbrnst.cpp, Line 1566
Aborted by user
1:17:05 #10 Text 0 File Scsicmd.cpp, Line 395
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSysSCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 1999.05.05. 22:22:00
File 'IoSubsysNEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 2002.03.11. 11:55:38
File 'IoSubsysCDR4VSD.VXD': Ver=5.10 (103), size=201960 bytes, created 2004.01.31. 3:06:18
File 'IoSubsysCDRALVSD.VXD': Ver=5.10 (103), size=20035 bytes, created 2004.01.31. 3:06:18
File 'IoSubsysACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 2004.01.31. 3:06:18
File 'IoSubsysCDUDF.VXD': Ver=5.10 (115), size=136969 bytes, created 2001.09.14. 11:36:26
File 'IoSubsysCDUDFRW.VXD': Ver=5.10 (115), size=173303 bytes, created 2001.09.14. 11:37:24
File 'IoSubsysCDRPWD.VXD': Ver=5.10 (115), size=76287 bytes, created 2001.09.14. 11:38:12
File 'IoSubsysCDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 1999.05.05. 22:22:00
File 'IoSubsysESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 1999.05.05. 22:22:00
File '..SystemVmm32Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 1999.05.05. 22:22:00
File 'IoSubsysDisktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 1999.05.05. 22:22:00
File 'IoSubsysESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 1999.05.05. 22:22:00 (Adapter driver for src)
Registry Keys:
ENNYIT ÍR KI ÉS ÍGY. MIT TEGYEK??? VÁLASZT KÖSZ SÁNDOR -
Sa1ndor
Easy-CD pro 95-tel próbálkoztam, adtak hozzá ugyan cd-n egy demoNérót, de az már lejárt. A program ''No compatible CD-writer devices found on SCSI bus'' szöveget írja ki. Piszkálgattam a masteres beállításait, amikor áttettem, akkor már nem ezt írta ki, hanem a scsi-n keresgélt valamit, de ekkor meg a gépet nem tudtam használni lefagyott, meg ilyenek. Ekkor mentem a biosba, sikeresen elállítottam a háttér vinyót, ekkor azt kiszedtem (ma sikerült visszarakom, úgy működik is, de semmilyen első-második vinyó cd meghajtó master-slave variációban nem akar cd-t írni.
Sa1ndor
Vettem télen egy TEAC- CD-W552E CDírót. Mostanában határoztam el, hogy tényleg mindent megteszek, hogy telepítsem P2-es, 300 mhz-es gépemre. Hely is lenne, de nem akarja. Két vinyó van rajta, de hiába kombinálom őket az íróval, addig eljutok, hogy CDolvasóként működik, aztán passz. Biosban is jártam már vele, Pedig de nincs eredmény. HELP és Minden kérdésre válaszolok. jó volna írni is vele. Vagy elcserélem bármire.
- Vezetékes FEJhallgatók
- Futás, futópályák
- talmida: My Art II.
- Samsung Galaxy S23 Ultra 256GB, Kártyafüggetlen, 1 Év Garanciával
- 268 - Lenovo Yoga Pro 9 (16IAH10) - Intel Core U9 285HX, RTX 5060
- 10+ db - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- AKCIÓ!! HP Zbook Studio G8 i7-11850H 32GB 1000GB Nvidia Quadro T1200 400NIT, 100% sRGB Garis!
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RX 9070 16GB GAMER PC termékbeszámítással
