PuMbA
Gameplay: [link]
PuMbA
Elég jó lett a gépigény,idézet egy tesztből:
"I played Warhead on a high-end machine with a quad core CPU and the latest Nvidia graphics card at high resolution (1680x1050) with all the details set to Enthusiast, which is essentially very high. It looked cutting edge and the frame rate was solid. Next, I checked the game on a slightly older PC with a two-year old 8800GTS and I was still able to crank it to Enthusiast settings and the same resolution and get solid results. Finally, I checked it out on the "$700 PC" that Crytek and EA have been touting. It really is a $700 machine built on the latest mainstream parts (the video card is a 9800GT), and I was able to play the final boss battle at the same resolution and at Enthusiast settings and get solid frame rates. I also tried it the Gamer setting, which is essentially high, and the frame rate was buttery smooth. You do lose some visual quality stepping down from Enthusiast, but even at Gamer Warhead still looks better than almost every game out there."8800GTS-el és 9800GT-vel is fullon ment még a játék legvége is. Igaz 4 magos processzorral ,de Crysis se támogatta csak a 2 magot,ez lehet ,hogy már igen.
- Gitáros topic
- Milyen légkondit a lakásba?
- Szerkesztett és makrofotók mobillal
- Arc Raiders
- Path of Exile (ARPG)
- MasterDeeJay: Mi ez a pici videókártya? AMD E9173 teszt
- Samsung kuponkunyeráló
- Wuthering Waves
- Az eddigi legolcsóbb, 3D V-Cache-t használó CPU-ját hozta forgalomba az AMD
- Sosemhasznált! HP OmniBook 5 Flip i5-1334U 16GB 1000GB 14" FHD+ áthajtós-érintős Gar.: 1 év
- HP EliteBook 840 G7 i5-10210U 16GB 512GB FHD 400nit 1 év garancia
- ÁRGARANCIA! Épített KomPhone i9 14900KF 64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- GYÖNYÖRŰ iPhone 13 128GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS4393, 100% Akkumulátor
- Ingyen elvihető hibás/törött TV/monitor
