drkbl
sanzi89
#1895
WrapText MaxCol=1-el?
Description
WrapText scans a string for occurrences of any of the characters specified by nBreakChars and inserts a line-break, specified by BreakStr, at the last occurrence of a character in nBreakChars before MaxCol. Line is the text WrapText scans. MaxCol is the maximum line length.
drkbl
sanzi89
#1892
A D7 helpjéből:
DisableControls method (TDataSet)
Usually DisableControls is called within the context of a try...finally block that reenables the controls even if an exception occurs. For example:
with CustTable do
begin
DisableControls;
try
First;
while not Eof do
begin
{ Process each record here }
Next;
end;
finally
EnableControls;
end;
end;
- Villanyszerelés
- X140M1F4N károsultjai
- Milyen okostelefont vegyek?
- AGM G3 Pro - ordít róla, hogy szoftverfejlesztők kellenének
- Eladó Samsung 24" Full HD LED monitor (S24C450B)
- 2013 Late 27 iMac - 1TB HDD i5 core4 24GB RAM 2GB GTX
- Bomba ár! Toshiba Portege R930 - i5-3GEN I 4GB I 320GB I DVDRW I 13,3" HD I HDMI I Cam I W10 I Gari!
- Bomba ár! Toshiba Portege X30-E - i5-8250U I 8GB I 256SSD I 14" FHD I Cam I W11 I Garancia!
- Bomba ár! Toshiba Satellite Pro A40-D - i5-7200U I 8GB I 256SSD I 14" HD I Cam I W11 I Garancia!
- Asus laptop E1504F Ryzen 3
- Asus ROG Strix G G531GT - 15,6"FHD IPS 144Hz - i5 9300H - 16GB - Win11 - GTX 1650 - MAGYAR
- BESZÁMÍTÁS! 4TB Western Digital Red Pro SATA HDD meghajtó garanciával hibátlan működéssel
- LG 27GS60QX-B - 27" Ívelt VA - 2560x1440 2K QHD - 180Hz 1ms - AMD FreeSync Premium
- ÁRGARANCIA!Épített KomPhone Ryzen 7 5700X 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
