zenit
Nem tippelgetek tovább, valahogy így kellene csinálnod:
(hosszú lesz, de igazából egyszerű. :) )
const
WM_NOTIFY_ICON = WM_USER;
type
TMainForm = class(TForm)
PopupMenu: TPopupMenu;
MenuShow: TMenuItem;
MenuExit: TMenuItem;
HideButton: TButton;
procedure FormCreate(Sender: TObject);
procedure FormDestroy(Sender: TObject);
procedure MenuShowClick(Sender: TObject);
procedure MenuExitClick(Sender: TObject);
procedure HideButtonClick(Sender: TObject);
private
procedure AddNotifyIcon;
procedure DeleteNotifyIcon;
procedure WMNotifyIcon(var Msg: TMessage); message WM_NOTIFY_ICON;
end;
var
MainForm: TMainForm;
implementation
{$R *.dfm}
procedure TMainForm.AddNotifyIcon;
var
NotifyIconData: TNotifyIconData;
begin
FillChar(NotifyIconData, SizeOf(NotifyIconData), 0);
with NotifyIconData do
begin
cbSize := SizeOf(NotifyIconData);
Wnd := Handle;
uID := 0;
uFlags := NIF_ICON or NIF_MESSAGE;
uCallbackMessage := WM_NOTIFY_ICON;
hIcon := Icon.Handle;
end;
Shell_NotifyIcon(NIM_ADD, Addr(NotifyIconData));
end;
procedure TMainForm.DeleteNotifyIcon;
var
begin
begin
Wnd := Handle;
uID := 0;
end;
Shell_NotifyIcon(NIM_DELETE, Addr(NotifyIconData));
end;
procedure TMainForm.FormCreate(Sender: TObject);
begin
AddNotifyIcon;
end;
procedure TMainForm.FormDestroy(Sender: TObject);
begin
DeleteNotifyIcon;
end;
procedure TMainForm.WMNotifyIcon(var Msg: TMessage);
var
P: TPoint;
begin
case Msg.lParam of
WM_LBUTTONDOWN,
WM_LBUTTONDBLCLK:
Show;
WM_RBUTTONDOWN:
begin
GetCursorPos(P);
PopupMenu.Popup(P.X, P.Y);
end;
end;
end;
procedure TMainForm.MenuShowClick(Sender: TObject);
begin
Show;
end;
procedure TMainForm.MenuExitClick(Sender: TObject);
begin
Close; // Elég a Close, mert ez a főform.
end;
procedure TMainForm.HideButtonClick(Sender: TObject);
begin
Hide;
end;
Na, ez így működik.
[Szerkesztve] -
zenit
Mindegy, mit írsz az Msg.Result-ba, mert az inherited miatt a TCustomForm.WMQueryEndSession-je úgyis felülírja neked.
A WM_QUERYENDSESSION-ben elvileg semmilyen Close meg egyéb műveletet nem kellene végrehajtanod, mert utána még úgyis jön egy WM_ENDSESSION, amire az alkalmazás magától kilép.
Ez a Delphi-ben már meg van írva, neked nem is kell vele foglalkoznod.
(Ha van a Formnak CloseQuery-je, akkor ott True-val kell visszatérned, hogy a QueryEndSession is True-val térhessen vissza.)
A DeleteTrayIcon meg egyéb dolgokat a TForm.OnDestroy eseményébe kell raknod.
- Eladó Spirit Of Gamer Headquarter 300 gamer asztal
- Eladó Razer Goliathus Extended Chroma egérpad
- Mika 6EU Konvektor helyére szerelhető gázkazán (Sosem használt,Digitális,ventillátoros,zárt égéstér)
- Samsung Galaxy S26 Ultra 512GB, Kártyafüggetlen, 1 Év Garanciàval
- Eladó dobozos, fóliás THERMALTAKE The Tower 600 fehér ház
- HP 255 G10 Ryzen 5 7520U 8 GB DDR5 256 GB SSD FHD Új 2 ciklus Gari 2028.
- Apple iPhone 14 128GB,Újszerű,Adatkabel,12 hónap garanciával
- Xiaomi Mi 10T Pro 256GB, Kártyafüggetlen, 1 Év Garanciával
- iPhone 13 Pro 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4383, 100% Akkumulátor
- Felújított laptopok számlával, garanciával! Ingyen Foxpost/PostaPont!
