whitezo88
}{3@Đ$}{0ot
#930
tudom de én mikor megvettem a crysis maximum editiont, ott is angolt választottam mert a magyartól a hajam téptem
pedig az hivatalos volt. -
whitezo88
}{3@Đ$}{0ot
#928
tökéletes nekem az angol, feelinges és értek mindent.
whitezo88
}{3@Đ$}{0ot
#925
megy
ez kellett:
set r_customWidth "1680"
set r_customHeight "1050"
set r_aspectRatio "2"
set r_mode "-1"bizonyíték: [link]
whitezo88
}{3@Đ$}{0ot
#922
nem kell írásvédetté tenni?
whitezo88
whitezo88
#920
1.3.1 után amúgy ezt írja ki:
DOOM 1.3.1.1304 win-x86 Jan 16 2007 15:36:51
2800 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
512 MB Video Memory
Winsock Initialized
Found interface: {E35E69B6-9B87-4750-A930-394F4C168CA5} Hamachi Network Interface - 5.198.59.17/255.0.0.0
Found interface: {BF40DB34-06A4-43C7-8CE5-8EA8572C9E77} Realtek RTL8139 családú PCI gyors Ethernet NIC - Packet Scheduler Miniport - 192.168.3.1/255.255.255.0
Found interface: {AB857DEB-E0CB-486C-BFA0-E019AEEB3CDB} WAN (PPP/SLIP) Interface - 89.132.19.47/255.255.255.255
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game01.pk4 with checksum 0x51c6981f
Loaded pk4 C:\Program Files\Doom 3\base\game02.pk4 with checksum 0xf3ec6f7
Loaded pk4 C:\Program Files\Doom 3\base\game03.pk4 with checksum 0x5d4230ea
Loaded pk4 C:\Program Files\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Program Files\Doom 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 C:\Program Files\Doom 3\base\pak007.pk4 with checksum 0x666bdb3c
Loaded pk4 C:\Program Files\Doom 3\base\pak008.pk4 with checksum 0x23ae5993
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak008.pk4 (3 files)
C:\Program Files\Doom 3\base\pak007.pk4 (38 files)
C:\Program Files\Doom 3\base\pak006.pk4 (48 files)
C:\Program Files\Doom 3\base\pak005.pk4 (63 files)
C:\Program Files\Doom 3\base\game03.pk4 (2 files)
C:\Program Files\Doom 3\base\game02.pk4 (2 files)
C:\Program Files\Doom 3\base\game01.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
Unknown command 'vid_restart'
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
...shutting down QGL
Couldn't load default.cfg -
whitezo88
hi!
az a gondom hogy nem menti el a configot, bármit beálíltok 640x480 marad. próbáltam manuálisan átírni a configban + read only de nem. hiába böngészem a netet (pl doom3world) nem tudom megoldani. még egy menu modot is leszedtem ahol direkt be lehet állítani mindent (widescreen) de beálíltás utána ugyanaz fogad, pefig azt írja 1680x1050ben van. tudtok-e rá valami megoldást? bár ahogy láttam elég sok embernek van ezzel gondja. köszi.
- MasterDeeJay: Comet lake (10gen) és DDR3 - mert ilyet is lehet!
- Házimozi belépő szinten
- Samsung kuponkunyeráló
- ÚJ Samsung Galaxy Z Fold 7 16 GB/1TB Jetblack
- Üzletből, garanciával, HP ZBook Furry 15 G8 i7-11850H/32GB RAM/512GB SSD/RTX A2000/FULL HD IPS
- Victus 16-r0013sl 16.1" FHD IPS i7-13700H RTX 4070 32GB 512GB NVMe gar
- Iphone 12 pro max
- ThinkPad P17 Gen2i 17.3" FHD IPS i7-11850H RTX A3000 32GB 512GB ujjlolv IR kam gar
- Apple iPhone 15 256GB,Átlagos,Adatkabel,12 hónap garanciával
- DELL Alienware 16X Aurora AC16251 Csillagközi indigó 2029-ig garancia
- Beszámítás! Lenovo LOQ 17IRX10 FHD Gamer notebook - i7 13650HX 24GB DDR5 1TB SSD RTX 5050 8GB
- ÚJ MSI Katana 15 HX - 15.6" QHD 165Hz - i7-14650HX - 16GB - 1TB - RTX 5060 - Win11 - 3 év gari - HUN
- BESZÁMÍTÁS! ASRock A520M R5 3600 16GB DDR4 512GB SSD RX 6600 8GB Rampage SHIVA Cooler Master 600W
ez kellett:
