Témaösszefoglaló
nubreed
#15674
igen jó a net, addig be tudok lépni amikor ki kell választani hogy open/solo, de amikor elindítom valamelyiket tölt egy kicsit és jön a hibaüzenet.
amúgy adtam fel ticketet és ezt a választ kaptam:
Thanks for getting in touch with us. I’m very sorry to hear that you have been experiencing some difficulty connecting.
Given the number of reports of this behavior we’re seeing it’s very likely this was due to some difficulties on our side, but this is being looked into as we speak.
It would be helpful to take a look at your netlog in order to diagnose this problem. The netlog reads the communication between your computer ond our servers, so it might give us a better idea of what kind of issues the server was having, or if something was specific to your situation.
The netlog should be located in this location: C:\Users\Username\AppData\Local\Frontier_Developments\Products\FORC-FDEV-D-1000\Logs
Please note that the exact path will vary a little depending on where you installed the launcher and which game version you have.
If you don't find it there, please try here: C:\Program Files (x86)\Frontier and then see if you have a Products folder with FORC-FDEV inside it. Inside the FORC folder there should be a Logs folder with netlogs in.
If you're using the Steam version then you'll find your AppConfig.xml file in: C:\Program Files (x86)\Steam\steamapps\common\Elite Dangerous\Products\FORC-FDEV-D-1010
And the logs generated in: C:\Program Files (x86)\Steam\steamapps\common\Elite Dangerous\logs
Simply save the file(s) to a convenient place such as your desktop and attach the copies to your reply.
We’re very sorry for any inconvenience caused by this experience and we’re committed to providing you with a smooth experience in the future!ha hazamegyek feltöltöm nekik a logokat, remélem jövő hétre meggyógyítják, mert akkor leszek szabin
(nem erre akartam válaszolni hanem Htibimor-nak)
#24909056
sziasztok,
tegnap óta nem tudok belépni a játékba mert mindig ezt az üzenetet kapom:
Could not connect to the adjudication server. Press OK to return to the main menu.
találkoztatok már ilyennel, van valami ötletetek hogy mi okozhatja ez?
kösz.. -
#24909056
e00dgy
#14419
ööö... nem akarom elrontani a hangulatot, de szerintem ez felesleges volt
ha majd kijönnek a privát frakciók, én arra számítok hogy a frakciótagsággal együtt lesz majd frakció "tag" is ami alapján be lehet majd azonosítani hogy ki hová tartozik..
legalábbis eddig minden online játékban volt ilyen amivel játszottam.. és az SWG óta volt egypár..
#24909056
ezt már láttátok?
nem a link-re gondolok, hanem arra hogy A Lavigny-Duval elég durván visszaesett. -
#24909056
ha valakit érdekel itt vannak a modulok statjai
[PP Weapon Stat]most egy kicsit csalódott vagyok, egyik sem tűnik valami hasznosnak..
#24909056
van valakinek közületek valami infója az új faction specific fegyverekről?
tudtommal ezen a héten kapják meg azok, akiknek sikerült szinten tartaniuk magukat, de sehol nem találok erről semmit.
vagy tévedek és csak a jövő héten lehet majd megvenni őket? -
#24909056
van valahol olyan lista hogy ki milyen hatalmasságokat támogat?
nézegettem az elitdangerous.hu de ott nem találtam, csak játékoslistát.
vagy erről csak a TS-en lehet infókat szerezni?
RÉSZLETES, FOLYAMATOSAN
FRISSÜLŐ FAQ
AZ ÚJ JÁTÉKOSOKNAK
- Linux kezdőknek
- Elektromos autók - motorok
- Akciókamerák
- Anime filmek és sorozatok
- Milyen légkondit a lakásba?
- Világrekordot ünnepel az ASRock
- Új könyv: A szamuráj erényei Kicune - Itó könyve
- szinteÚJ! Microsoft Surface Laptop 5 13.5" i5-1245U 16GB 512GB Alcantara 1év garancia
- Acer Predator Helios 18 AI I9 ULTRA 9275HX, 192GB RAM, 2TB SSD, RTX 5080
- LG 77C4 - 77" OLED evo - 4K 144Hz - 0.1ms - NVIDIA G-Sync - FreeSync - HDMI 2.1 - 1000 Nits
