Keresés
  • corlagon
    válasz getto #62 üzenetére
    GeForce Overclocking - CoolBits Reg
    OS:Windows All
    Last Updated: April 3rd, 2003 09:37
    Product description
    With a couple of registry modifications, you can easily overclock your video card, and have
    smoother video and better frame rates.
    When you run this file to edit the registry, it change the values of the keys that allow you to
    use the factory overclocking utilities from Nvidia.
    Double-click the geforce_overclock.reg and you'll see a window that says, ''Are you sure you want to add the information?''
    Click Yes and the program will edit the registry. Once it's edited you'll see a window telling you the information has been successfully entered into the registry.
    Click OK and reboot.
    Now Right-click the desktop and select ''Properties'' from the menu.
    Select the ''Settings'' tab. A button labeled ''Advanced'' will appear.
    Select the icon tab with the name of your card on it. (GeForce 3 for example). You'll see a slider type menu with a NEW option named ''Clock Frequencies'' You can now control the frequency of
    the Nvidia's card memory and core speed independently.
    Ja és a venti:
    Mindegy, csak illeszkedjen. Érdemes egy nagy, olcsó procihűtő bordát rátenni, meg valami halk 8 centis ventit.
    [Szerkesztve]
