Keresés
  • haver
    válasz guest #12 üzenetére
    Aktualis kerdes aktualis valasszal. A lenti eszkoz 4 portos 10/100 switch + NAT tuzfal +Print server +WAN port! Az ara 35eFt korul van.
    [L]http://www.smc-europe.com/english/products/broad.html[/L] es itt az SMC7004BR
    azert az angolt bemasolom:
    4-Port 10/100Mbps Broadband Router
    From SMC´s line of low-cost LAN Solutions
    The Barricade™ is an ideal all-in-one networking solution for home and small business users. This protocol independent multi-functional broadband router is combined with a 4-port 10/100 Mbps dual-speed switch, and incorporates both a built-in print server and an NAT firewall for security against hackers and other unauthorised users.
    The Barricade™ provides a WAN port as well as Network Address Translation (NAT), which extends simultaneous Internet access for up to 253 PCs on the LAN.
    The new broadband router also allows the connection of multiple users to the Internet using a single WAN/IP address. LAN and IP addresses are auto- assigned and easily managed, and the IP routing supports a range of popular applications.
    This new device is a complete networking solution for PC or Mac users, and is backed by SMC´s limited lifetime warranty.
    Udv
