Cos
II. Újabb probléma!
Xp újratelepítés előtt álok és nem találom a leveleimet :( a programot pedig nem tudom elindítani (probléma van) Hol találom milyen mappában tárolja el az Xp őket!? :F -
Cos
Ismét csoda törtnét! :))
De hogy micsoda azt senki sem fogja elhinni... :)
Na ezt magyarázza meg Valaki! :F -
Cos
Íme a mail...
Dear Laszlo Ihos,
Your Case ID is PTS9041302.
[Critical: Please do not change the subject line of your email when you reply.
Leaving the subject line as it is will allow us to review your complete history
and help us to better serve you.]
Note: No pre-sales question should be answered via Technical Support, all
pre-sales suggestions should be considered invalid. Technical Support is not
authorized to make product suggestions. Their responsibility is only to offer
warranty support for non end of life (EOL) / last date of support (LDOS)
products you currently own. Last date of support may be earlier than posted.
For Sales and Pre-Sales questions, please call toll-free 1-800 326 1688 menu
option 1 or email sales@dlink.com
Date of Reply: 11/6/2003 2:30:33 PM
Products: DI-604
Operating System: Windows ME
Due to the complex nature of your request, it is best if you speak with a live
technician to resolve the issue. Please call technical support at 877-45D-Link
(877-453-5465). Technical support is available 24/7 to serve your needs.
Are their any ports that you need to open for your mail server if so make sure
to open them under virtual server.
Thank you for networking with D-Link.
Sincerely,
Jerry Lopez
D-Link Technical Support Team
Azt hiszem nem fogom őket felhívni! :D -
Cos
Na most is végigpróbáltam minden opciót és letíltva engedélyezve... és semmi!!! :(
Cos
Win Me! :(
ez mond valamit?
Firewall Rules List
Action Name ----------------------Source ---------Destination--------- Protocol
Allow Allow to Ping WAN port ---WAN,* ----------LAN,192.168.0.1--- ICMP,8
Deny Default -----------------------*,* ------------LAN,* --------------------*,*
Allow Default --------------------LAN,* -------------*,*---------------------- *,* -
Cos
Megválok tőle hacsak valami hálózatépítő bajnok meg nem mondja hogy mit tudok kezdeni... tulajdonképp úgy csinál gondolom a tűzfal miatt mindtha nem lenne kapcsolat pedig van :( az outlook és még jópár progi ezt csináljs viszont azoknál ha mondom nekik hogy újra akkor már nem akadnak fenn! :F
Cos
Az még nem lett volna probléma hogy nem jön le csak a következő volt a szitu....
Check mail....
és bejön egy abalak amibe be kell újra állítani az account-hoz tartozó jelszót na ugye beírom és semmi... de itt meg is akadt!!! és később az axeleros mailekkel is ezt csinálta!
Viszont meg tudtam lesni egyéb módon( [L]http://www.mail.2web.com[/L] ) és akkor simán le tudtam kérdezni a maileket! :F -
Cos
Nos az az igazság hogy mostmár az outlook sem műxik még amikor ma elindítottam ma elkezdett játszadozni és nem akarta leszedni a freemail-es e-maileket ugyanis kérte hogy írjam be a helyes jelszót... és egy fél óra elteltével már az axelero-s maileket sem akarta leszedni!
Ok??? :F :F :F :F :F -
Cos
Senki más? :(
Cos
Valaki még esetleg valami ötlettel? :)
Cos
Sajnos nem tudom de majd beírok a D-link-es topicba is mert egy ilyen DI-604-es ketyeg itt :))
Ha nagyobb hálózatépítési tudással rendelkeznék lehet hogy nem is nyitottam volna topicot szval ha az ötleteted kifejtenéd hogy mit is tehetnék hálás is lennék egy kicsit akár! :)) -
Cos
Eléggé megszerettem ezt a kis progit a sok kis bolondságával, viszont egy routerrel meg lett osztva a net és azóta nem hajlandó leszedni és küldeni a mail-eket csak offline módban van folyamatosan! :U
Pls Help!
Ez azért furcsa mert az outlook pedig tökéletesen működik... :F
- BESZÁMÍTÁS! HP Elitebook 745 G6 14 üzleti notebook - R5 3500U 16GB DDR4 256GB SSD Vega 8 IGP WIN11
- Apple iPhone 13 Pro Max 128GB,Átlagos,Dobozaval,12 hónap garanciával
- Kezdő Gamer PC-Számítógép! Csere-Beszámítás! I7 4770K / GTX 1060 6GB /16GB RAM /250SSD + 500GB SSHD
- Dell UltraSharp 24 USB-C Hub Monitor - U2422HE - 27% ÁFÁs
- BESZÁMÍTÁS! ASRock B550 R5 5600 16GB DDR4 512GB SSD RX 6600 XT 8GB Zalman i3 Edge FSP 700W
