Impair1980
#3698
https://online.roboform.com/login?lang= >
Advanced> pipát szedd ki a Tie the session to ip-address elől > Auto Logoff: 1 mounth -
Impair1980
#3695
lastpass
roboform -
Impair1980
#3693
jelszókezelő plug-in megoldás lehet
s7evcsenko
#3580
amerikai kedd, ami nálunk szerda reggel
a probléma
a lehetséges megoldás:
It ends up that, at least in some cases, you can uninstall KB 3038314, add Google (or another search provider), then re-install KB 3038314, and have the search provider come through unscathed. However other folks report that they haven't been so lucky.Poster Kimi K on the TechNet forum gives a more complete solution that involves uninstalling KB 3038314, adding Google to IE, exporting a Registry entry, re-installing KB 3038314, and then importing the Registry key.
s7evcsenko
#3573
Internet Explorer 11
1.Open Internet Explorer.
2.In the top right corner of the search box, click the down arrow.
3.Click Add.
4.Select Google.
5.Click Add to Internet Explorer.
6.Check the box next to"Make this my default search provider."
7.Click Add.Internet Explorer 10
2.In the top right corner of the page, click the gear icon.
3.Click Manage add-ons.
4.On the left side of the page, click Search Providers.
5.In the bottom left corner, click Find more providers.
6.Select Google.
7.Click Add to Internet Explorer.
8.Check the box next to "Make this my default search provider."
9.Click Add.Internet Explorer 9
2.In the top right corner of the browser, click the Tools icon.
3.Click Internet options.
4.In the General tab, find the "Search" section and click Settings.
5.Select Google.
6.Click Set as default.
7.Click Close.Internet Explorer 8
2.In the top right corner of your browser, click the down arrow in the search box.
3.Click Find More Providers.
4.Click Google.
5.Check the box next to "Make this my default search provider."
6.Click Manage Search Providers.
7.Click Add. -
pinnacle
#3420
nézd meg mit ír a Kaspersky rá: not a virus
sajnos sok víruskereső simán csak a heurisztikus keresés alapján fals pozitív jelzést adnak, de nem vírus, csak kényes adatokhoz (jelszavak) kell hozzáférnie.
Nagyon régi programok vannak azon az oldalon, a vírusirtók nem is tiltják az oldalukat, több pedig kivételként kezeli:
Avira
BitDefender
Comodo
F-Prot
F-Secure
Microsoft
Panda
SUPERAntiSpyware
Symantec (Norton)
TrendMicro -
anorche1
#3324
mindenféle nyelvet támogat csak magyart nem
de http://www.iespell.com/ - itt van egy progi amit ha felraksz, akkor tudni fogja ellenőrizni -
malnabokor
#3300
sokszor használom,
igazán jó a 10-es és a 11-es -
A DEP (Data Execution Prevention - Adatvégrehajtás megakadályozása) a Windows biztonsági megoldása, hogy vírusok és egyéb kártékony programok ne férjenek hozzá a Windows által lefoglalt memóriaterülethez, ezért ha egy program megpróbál beférkőzni erre a területre a Windows leállítja a programot, és hibaüzenetet küld.
Predator2
#2958
magyarítva az eltávolítás
- Facebook és Messenger
- OpenMediaVault
- The Elder Scrolls Online Imperial Collector s Edition
- LG 27GS95QE - 27" OLED / QHD 2K / 240Hz & 0.03ms / 1000 Nits / NVIDIA G-Sync / AMD FreeSync
- Apple iPhone 12 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 83%
- AKCIÓ! Dell Latitude 5455 14 FHD+ üzleti notebook - Qualcomm X Plus X1 16GB DDR5 512GB SSD W11
- iPhone 17 White 256 GB - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok - Számlás
- ÁRGARANCIA! Épített KomPhone R7 5700X 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
