Dißnäëß
Dißnäëß
Dißnäëß
#72245
VM-en a legjobb eredmény (host vagy EPYC, mindegy) :
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw topoext perfctr_core ssbd ibpb stibp vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 clzero wbnoinvd arat umip arch_capabilities
host:
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate sme ssbd mba sev ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif umip rdpid overflow_recov succor smca -
Dißnäëß
Neil Watts
#72241
Csináltam egy érdekességet, miután mindent virtio-ra tettem, amit lehetett, bár a diszkkel amúgy sem volt gondom.
VM-en belül:
1. grep flags /proc/cpuinfo | uniq > cpuinfo_...... .txt
2. ls -hn cpuinfo*
-rw-r--r-- 1 1000 1000 581 Apr 7 14:36 cpuinfo_copyhost.txt
-rw-r--r-- 1 1000 1000 581 Apr 7 13:58 cpuinfo_EPYC.txt
-rw-r--r-- 1 1000 1000 237 Apr 7 14:32 cpuinfo_kvm64.txt
-rw-r--r-- 1 1000 1000 281 Apr 7 14:23 cpuinfo_OpteronG3.txt
-rw-r--r-- 1 1000 1000 220 Apr 7 14:27 cpuinfo_qemu64.txtSzóval a méreteken látszik, mikor mennyi CPU flag-et tesz be a txt fájlokba a guest VM.
Ehhez képest amit a host mutat a fentebbi parancsra, egy 897 byte-os fájl, tehát a /proc/cpuinfo még a legjobb, host CPU jellemzőket másoló üzemmódban sem mutat annyi CPU flag-et guest-ben, mint amit a host tud. (Lehet nem is kell mindet, mert azok már nem érintenék a virtualizációt érdemben, de ebben nem vagyok biztos, tekintettel arra, hogy a különbség azért elég nagy).
Szóval a host-on raklap flag van, míg a KVM/QUEMU által a legjobb esetben is csak ezek sacc kétharmada van megmutatva VM-nek. Ez normális ? (Esetleg van kedvetek megnézni, Nálatok hogy néz ki?)
Dißnäëß
Neil Watts
#72241
Minden VirtIO de azert megnezem megint + a W10 driverek es spice tippet koszi.
Dißnäëß
Sziasztok, Ti mivel virtualizáltok és mennyire hatékonynak tartjátok ?
Debil 10 testing-en élek jó ideje, SSD-n virtualizálva QEMU/KVM módon, Virtual Machine Manager-el adminolva őket. Bevált, de a sebességgel nem vagyok elégedett (de ez lehet normális).
Általánosságban mekkora overhead-et jelent egy Hypervisor a guest vCPU-k és a fizikai magok között ?
Cégben VMWare-es nagyvállalati környezetben ezt olyan 5% köré saccoljuk. Nálam meg itthon nekem néha olyannak tűnik, mintha egy 50% lenne, eléggé nagyonlomha minden Linuxos VM-em (a W10 sem pattog mint állat).. hozzá kell tenni, grafikus felületekről beszélek, tehát amikor kipróbálok egy Live ISO-t, tökmindegy, mit, vagy készre telepítek egy XFCE-t, KDE-t, akármit, nem egy rakéta úgy sem, hogy 3-4 magot adok neki.
Az összes CPU feature aktiválva (Ryzen5 3600), vtx/vtd AMD megfelelői, swap-ok offon host-on is, guest-ekben is, RAM-ot adok nekik 4 Gigát, SSD alattuk a host-on, .. OK, hogy VGA nincs agyongyorsítva (host: GeForce710) de kicsit lomha a betöltés, az élet a guest-eken.
Ami még feltűnt, hogy mindeközben (töltés közben pl, boot, ilyesmi), se a host CPU nem megy púpon, se a guest CPU. Hanem csak úgy közepesen elvannak, mintha őrült futás helyett (amit várnék tőlük) csak úgy kényelmesen fagyizva sétálgatnának az utcán, "ráérünk" alapon.
Ez normális ? A vas nem rossz szerintem, a proci alatt azért van még jó maréknyi, ennél sokkal többe kerülő Xeon meg egyéb, szóval nem gondolom indokoltnak a lassúságot - vagy nem szoktam meg a dolgot, 1 hónapja játszok csak ezzel.
Esetleg parancssoros cpu teljesítmény mérő (1 szál, több szál) tudtok mondani ? Amolyan gyors valamit, ami megkergeti a CPU-t és akkor mérnék host-ra is egy nyerset, illetve mondjuk egy 4 vCPU-s VM-en is, aztán meglátjuk. Lehet a CPU-val agyonemulált VGA fogja, a grafikus környezet, ki tudja, csak hangosan agyalok.
(Nem szeretnék VMWare-re váltani, ragaszkodom a Debian host-hoz, de ahogy neten olvasom, mások elégedetten használják, Proxmox is pl. erre épül).
Lehet csak szoknom kell ...
Dißnäëß
Dißnäëß
#72217
MAC (AP Main) : 30:5A:3A....
Operation Mode : AP
WPHY Mode : 11a/n/ac
Channel Main : 36
AP Main Stations List
MAC PhyMode BW MCS SGI LDPC STBC TRate RSSI PSM Connect Time
................. VHT 80M 9 YES YES NO 867M -63 YES 00:28:22
................. VHT 80M 4 NO YES NO 351M -71 YES 00:27:42
................. VHT 80M 9 YES YES NO 867M -53 YES 00:27:00
................. VHT 80M 9 NO YES NO 390M -58 YES 00:26:29
................. HTMIX 40M 14 NO NO NO 243M -59 NO 00:02:49 -
Dißnäëß
Tegnap tartósan 500-800 Mbit körül lógott a laptop a wifimen, ez nincs messze a kábeles Gigától, pláne úgy, hogy tömörített adatot tolna át (a kábelen lógó workstation gépemre).
250-es SSD, friss szűz mint a hó a W10 install, szerintem ez most nincs 20 Giga. (Nem néztem meg még, mennyi). Szóval elég üres a gép még.
Legális, aktivált W10, nem akarnám bukni egy hülye vírus, vagy hardver hiba miatt, így lementeném most a pucér gépet. Annyira sokat ilyen mennyiségnél nem buknék.
Persze attól függ, mivel csinálom a mentést. Clonezilla átugorja azt, ahol nincs tényleges adat, elvileg. Ha dd-znék, sajna az egész SSD-t be kéne olvasnia, illetve a fájlrendszerben üresnek jelzett blokkok nemnulla (hanem random szemét) tartalmát is felolvasná és tárolná az elkészülendő image fájlban, így ott legjobb tömörítés esetén is (számoljunk egy optimista 60%-al) át kéne tolni ezen a wifin úgy hasra ~140 Gigát.
De tekintettel az említett sebességekre, nem téma a wifi használata. A router ugyanis fent csücsül fejünk felett magasan, az előszobában
szóval macera lenne még ideiglenesen is rádugni a laptopot (csak 1 méteres UTP-m van kéznél).Szerk: na csak ránéztem. 423-536-867 között billeg a laptop a gyerek szobájában, attól függően, elállom-e az útját a router és őközte, illetve a telóm ugyanezen a wifin lóg-e vagy sem. Ha teló wifi ott (nekem a mobilnet ingyen amúgyis), akkor 867, az meg kellemes már.
Dißnäëß
Dißnäëß
Mindkét választ nagyon köszi
1. tehát menne dd-vel is, ahogy elképzeltem, mondjuk lementeni a gyerek SSD-jét egy gzip-en átkergetett fájlba, majd később nagyobb SSD-re váltás esetén arra visszatolni az image-et szintén dd-vel, + resize és meg is volna.
(W10 van rajta, jómagam linuxon élek amúgy, de ilyenekkel még nem foglalkoztam részleteiben, de gondolom egy bájtról bájtra beolvasásnál és visszaírásnál nem kell, hogy stresszeljen a W10 ezen, max 1 reboot egy full restore után).
2. Clonezilla, már nézem is, kipróbálom mindjárt. (SSH-n keresztül is tud egyből másik host-ra menteni, vagy adjak alá egy NFS-t a linuxomról ?)
Dißnäëß
backup-restore témában (Debian Live CD-vel mókolnék) szeretnék e cikk alapján rájönni arra, hogy ki melyik megoldást szokta használni mentésre és visszaállításra: [link]
A dd-vel az a "gondom", hogy olvassa a nullákat is a forráson, holott őket átugorhatná. De ez a kisebbik. A nagyobbik: ha egy 120-as SSD-t bájtról bájtra be-dd-zek egy fájlba mint biztonsági mentést, azt hogyan teszem ki egy eltérő méretűre ? Akár kisebbre, akár nagyobbra ?
(+ gondolom, összevissza fog zavarodni az OS, amikor restore után beindul, hogy ő 2x akkora, mint amekkora, vagy hogy kell ezt elképzelni ??)
Dißnäëß
Sziasztok, ha többféle HDD-m van többféle méretben, mindenféle raid-eket alkotok, teszek-veszek, néha át akarom konfigolni, fájlrendszert csökkenteni-növelni, ilyesmik, -> LVM ?
2-es kérdés - kicsit egyszerűbb: JBOD-t használ valaki ma még, mondjuk bukható adatra, vagy csak a múlt egy csúnya csontváza és LVM mellett értelmetlen, vagy mi van ezzel most ?
Dißnäëß
CPT.Pirk
#64979
De ez régi kártya, ha megnézed a speckóit wiki-n, szerintem ez a CPU elfogadható. Azért csekkolom én is mégegyszer, amit írtál, megpróbálom feltenni őket.
Na fent is vannak, vaapi fent volt már, vdpau kellett még.
display: :0 screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name width height types
420 8192 8192 NV12 YV12
422 8192 8192 UYVY YUYV
444 8192 8192 Y8U8V8A8 V8U8Y8A8
Decoder capabilities:
name level macbs width height
MPEG1 --- not supported ---
MPEG2_SIMPLE 3 9216 2048 1152
MPEG2_MAIN 3 9216 2048 1152
H264_BASELINE 41 9216 2048 1152
H264_MAIN 41 9216 2048 1152
H264_HIGH 41 9216 2048 1152
VC1_SIMPLE 1 9216 2048 1152
VC1_MAIN 2 9216 2048 1152
VC1_ADVANCED 4 9216 2048 1152
MPEG4_PART2_SP --- not supported ---
MPEG4_PART2_ASP --- not supported ---
DIVX4_QMOBILE --- not supported ---
DIVX4_MOBILE --- not supported ---
DIVX4_HOME_THEATER --- not supported ---
DIVX4_HD_1080P --- not supported ---
DIVX5_QMOBILE --- not supported ---
DIVX5_MOBILE --- not supported ---
DIVX5_HOME_THEATER --- not supported ---
DIVX5_HD_1080P --- not supported ---
H264_CONSTRAINED_BASELINE 0 9216 2048 1152
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
HEVC_MAIN --- not supported ---
HEVC_MAIN_10 --- not supported ---
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported --- -
Dißnäëß
CPT.Pirk
#64959
Köszi, megnézem, ha lesz Ryzen. (Lehet kivárom a 3-as szériát).
Most Debian lett ismét, testing (Buster). KDE-full-t feltettem egy szűz, 84 mega RAM-ot foglaló install-ra
.. az alap videolejátszó CPU-ból tolja a vidiket, nem is nagyon lehetett mit állítani benne (Dragon Player). Tettem fel egy VLC-t, hozzá se kellett érnem és voilá, 10-15% CPU-ból megúszom ugyanazt a vidit.Rájöttem egyébként, mi volt az önálló életre kelése a friss, pár héttel korábbi Debianomnak: standard telepítőt nyomtam, nem expert módot. Most az expert install-ban megkérdezett, hogy szeretném-e, ha a security jellegű frissítések automatikusan jönnének-e le és települnének, vagy magamtól majd manuálisan a régi módszerrel intézem őket. Manuált választottam. A nem-expert (tehát standard) telepítő aktiválja ezt, így a legváratlanabb pillanatban képes a gép egyszercsak frissítéseket lehúzni és telepíteni, ami szolídabb erőforrású gépet igénybe vehet, vagy éppen csak "pont rosszkor jön" a dolog.
Most kerek minden, szép a KDE Plasma, gyorsított a H.264 video lejátszás. Még W10-nél is jobb, mert arra már nincs AMD driver (11 éves NV710/HD4350), az M$-é pedig vacak.. a Linux alatti meg úgy látom, jobban kezeli. Öröm, mosoly.
Köszönöm a jótanácsokat, lejegyzeteltem amit szükséges.
(Ez többieknek is szól). -
Dißnäëß
Rimuru
#64945
Van egy kétmagos AMD Athlon X2-m, egy full ATX Giga lappal, az ősrégi Starcraft-os és CS-s gépem amit anyámnak levedlettem, majd eltelt sok év és visszaadott (lett új laptopja). De ez nagy. Néznék valamit tv hátuljára Vesa mount-al, egy kis passzív házban (Akasa Euler M), 35W TDP-be már nagy erő belefér egy bármilyen linuxnak.
Laptop HDD-ket raid-elnék be, egy kisebb részt raid1-be, a maradékot raid5 vagy raid6-ba, esetleg a bármikor pótolható motyókat 0-ba.. attól függően, hogy hány van (most 3db de lehet nézek egy negyediket apróért - 1T-s mind, Toshiba és Seagate).
Tegnap viszont sokat agyaltam azon, hogy konzol elég-e nekem, vagy jó lenne-e egy grafikus felület. Mert akkor nem kellene egy külön lejátszógép és külön a NAS, hanem lehetne egyben.
- menne rá egy Kodi mint lejátszó szoftver (csak szoftver, nem OS)
- külső DAC, így film, zene megoldva
- illetve mint NAS egész nap ellehetne ott a tv hátulján, mivel az nem a falon van és megúszom a kábeldzsungelt és a porfogókat a tv alatt-körülAzt hiszem, ez a legjobb út. Szerintem erre bármi jó szinte, prociban. Az integrált VGA h.264/h.265/HEVC/Google VP9 4K gyorsítása miatt valszeg valami legújabb generációs procisat néznék a szerény fajtákból, de az integrált VGA-ja kezelje ezeket szépen.
Még azt lenne jó tudnom, hogy egy ilyesmi célra szánt Linuxos kis géphez milyen VGA-t ajánlanátok.
Két szempont mentén:
1. nVidia, AMD, Intel - melyik mennyire támogatott, értem ezt a fentebbi dekóderekre, video lejátszás gyorsítás implementációja. W10 alatt mind gyorsít mindent, de Linuxban már kicsit más a dolog, szerintem nagyon driver függő, mert többször szaladtam Debian alatt olyanba, hogy böngésző marhára CPU-val oldotta meg azt, amit nvidia-val kellett volna és a gyári driver fent volt (nem nouveau).
2. Linux verzió. Olyanra lenne szükségem, ami friss driverekkel műxik, előszeretettel támogatja ezeket az "új" kodekeket és azokat gyorsítja megfelelően, kezeli a hardvert megfelelően, stb.
Az AMD Ryzen 2-ik gen-es APU-jai a VP9 4K-t is fullba tudják már gyorsítani, például arra is lőhetnék.
Tudom AMD jobban együttműködik a Linuxos közösséggel, mint nVidia, ennek ellenére én már mindkét oldalon láttam olyat, hogy au, nem akartam nekiállni XOrg-ot hack-elni, hajam kihullik
Szerk.: ráfutottam erre a cikkre. Jó lehet, van tapasztalata vkinek ezzel a disztróval ?
Dißnäëß
Sziasztok, én a "kicsit gyakorlottabb" linuxos volnék, és lenne egy kérdésem a mélyen tisztelt utazóközönséghez: milyen minimál disztrót tudnátok nekem ajánlani egy kis NAS-hoz ?
Mini ITX lenne az alap, Celeron, esetleg valami új AMD üdvöske, nem tudom, még kiválasztás alatt, de raid-elgetnék rajta, kicsit tanulás célból is, kicsit azért is, mert értelmét látom raid1-ben tartani a számomra fontosabb motyókat, beteg lett egy vinyóm, még olvasható, de Sentinel már döglést jelez (Windows, egyedüli egyelőre), szóval lassan mentenem kéne le róla mindent.
Azt hiszem, inkább összegyűjtöm a kérdéseimet egy csokorba.
1. milyen minimál disztró ? Debianozok régóta, elég lenne egy stable verzió netinst-ről feltéve tökminimálban és konzolon elvagyok, ssh, no prob. Viszont a legújabbat próbálgatva nem tetszik, hogy elkezdett jobban önálló életet élni, mint a korábbi Debian installjaim pár évvel ezelőttről. Szóval anno ha feltettem egy minimál Debiant, az a végén beállt, proci lement 0-1%-ra és nyugodtan ült a fenekén, lesve minden szavam. Most meg a háttérben ilyen auto task-ok indulnak a nem túl combos régi AMD vasamon, hogy apt elkezd valamit tekerni a háttérben, meg 1-2 apróság, így tökrandom.
És nekem ez nagyon nembegyere, sírom vissza a kussban lévő régi Debianos időket.
Nem tudom, ez a systemd-nek köszönhető-e és egy Devuan-al jobban járnék-e, vagy valami tökmást kéne néznem, vagy tudtok tanácsot adni, hogyan herélhetem ki a mai friss Debian installációkat is .. csak ne éljen nélkülem, ne fussanak le olyan task-ok a háttérben, amik tökváratlanul elkezdik nyúzni a rendszert "csak úgy" - biztosan van oka, nem mentem bele jobban, de akkorse tegyék. Kussoljon, várjon tőlem inputra és álljon kilövésre készen, 0-1% CPU körül, mint a régi verziók.
Azért használtam Debilt mindig is, mert csicsamentes, automatizációmentes, minden önálló élettől mentes.
A maiak viszont kicsit tolnak Orwell fele, önálló élet, ma még csak 1-2 móka a háttérben, 10-20 év múlva már ez is ilyen Win10-szerű agyonkémszoftver lesz ? Vagy csak túlparázom ?No, szóval kellene valami, ahol én vagyok az úr.
Köszönöm.
Dißnäëß
szeretnék egy titkosított fájlrendszert létrehozni, aminek tartalmát megosztomk Windows-os gépek számára.
1. létrehoztam egy 10 gigás fájlt.
2. luksFormat megvolt, kód, stb.
3. ext4 kreálva, rajta
4. mount-oltam
5. működik, teszi a dolgát szépen, /dev/mapper-ben is ott a viruális eszköz, szóval minden kerek.Viszont azt nem tartom normálisnak, hogy csak a root tud az újonnan mount-olt fájlrendszerre írni, vagy olvasni arról dolgokat. Sima user-nek is elérhetőnek kellene lennie.
Tehát root-ként mount-olom a /dev/mapper-ben lévő, immár "titkosítatlan" eszközön lévő ext4 fájlrendszert, de ezt szeretném bármilyen user számára engedni, kb. mintha egy új HDD-t adnék hozzá a rendszerhez és formázás után azt is eléri minden user, alapjáraton.
Na ezt csak a root és ezen szeretnék változtatni, mert ha Samba-val "kipublikálom" 2 Windows-os gépnek, amiket L2TP/IPSec-en belógatok a gépre a távolból, akkor gondolom ott normál user jogosultsági szinteken vagyunk.
Amit csináltam, root-ként:
mkdir /mnt/secret
fallocate -l 10G /mnt/disk.img
cryptsetup -y luksFormat /mnt/disk.img
cryptsetup luksOpen /mnt/disk.img secretdisk
mkfs.ext4 /dev/mapper/secretdisk
mount /dev/mapper/secretdisk /mnt/secretÉs ott a default lost+found könyvtár, minden szipiszupi, csak épp root szintet elhagyva nem férek hozzá a felmount-olt könyvtárhoz. Beenged, de már a lost+found-ba nem enged belépni. Írásvédett az egész cucc normál user-ként.
Valszeg banális dolog lesz. Tipp ?
Dißnäëß
Dißnäëß
#59164
Talan rovidebben:
1. teljes hdd titkositas eseten van-e meg titkositast kovetoen is adat titkositatlanul a legelejen (vagy barhol mashol?). Ha igen, -> 2. Ha nem -> Nincs tobb kerdesem.
2. Ezeket boot utan felul lehet-e irni (csak az azonosito par bajtot ovatosban) mikozben a rendszer el es virul ?
Dißnäëß
live disztrorol (debian, ubi..) szeretnek sw raid-et mount-olni es hasznalni ugy, hogy titkositom a hdd-ket. Ez menne is alapbol, csak a particiok legelejen van egy azonosito, par bajt, ami elarulja, hogy az ott egy titkositott particio ami kezdodik. Jol tudom ?
Szoval a gep futtatasa kozben boot vegen, mar osszerakva a logikai meghajtokat es mindent, nagyon barom dolog ezt a par elso byte-ot eltenni egy txt-be (vagy szimplan megjegyezni) es /dev/urandom-bol felulirni ?
A cel az lenne h egy minimum 2 diszk-es sw raid (mdadm) array-em legyen mondjuk raid 1-ben es ha a gepet kikapcsolom v lehuzom az aramot, reboot-olom, stb, teljesen random adatnak latsszon mindket diszk, mintha szuz lenne meg (bar az nullas, mindegy). Semmi utalas se titkositott particiora, se semmire. Buta ures hdd-nek lassa egy Gparted vagy akar egy Windows is.
Es amig nem ir rajuk senki
addig par parancs utan, amit hajlando vagyok bepotyogni neki minden boot-nal (nagyon ritkan lenne reboot vagy power off) szepen fel-mount-olgatom a feloldott array-t, partitiokat, titkositast es hasznalom.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Túra és kirándulás topic
- Víz- gáz- és fűtésszerelés
- Vivo X300 Pro – messzebbre lát, mint ameddig bírja
- Spórolós topik
- Motorola Edge 40 - jó bőr
- Androidos tablet topic
- Mikrotik routerek
- BLACK FRIDAY! - Jogtiszta Windows - Office & Vírusirtó licencek- Azonnal - Számlával - Garanciával
- Árváltozás: Deus Ex Human Revolution Collector's Edition
- Path of Exile 2 (POE2) Early Access kulcs
- Bomba ár! Dell Latitude E5540 - i3 / i5 I 6-8GB I 320GB I 15,6" HD I HDMI I Cam I W10 I Gari!
- Gamer PC-Számítógép! Csere-Beszámítás! R5 5600 / RX 6700XT 12GB / 16GB DDR4 / 500GB SSD
- Apple iPhone 13 128 GB Fekete 1 év Garancia Beszámítás Házhozszállítás
- Dell Latitude 7320 i5-1145G7 16GB 256GB 1 év garancia
- HIBÁTLAN iPhone 14 Pro Max 128GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, MS3913, 100% Akkumulátor
(Amúgy mindkét nagy márkát csipázom, nem húzok egyik fele sem, csak bennem van a reggeli rosszkismanó) ![;]](http://cdn.rios.hu/dl/s/v1.gif)
Én is voltam már topicgazda, úgy hagytam ott a fórumot a bolondok miatt, hogy töröltettem is a nick-em. Ez vagy a 3. regim itt, amúgy a ph indulása óta itt vagyok. Már az arcképpel sem törődök, meg közben átlépni is megtanultam dolgokon ... lehet öregszem
