Drizzt
Végre az új peccsel lehet állítani az aspect raqtior, igaz csak parancssorból. Ezen kívül végre a fraps ki tud írni fps-t.
Drizzt
Legújabb support válasz a rossz aspect ratiora:
Thanks for the update. I currently have no information on when a patch is gonna be released. I know our developers are collecting data since launch.
I've found a temporary fix for this,
Instead of playing in full screen Ive found a tool that allows u to play border-less windowed, so basically u can play windowed full-screen.
I think it looks a little bit better than before but at least it works:
Download this http://www.mediafire.com/?jnsslpz2wl7yjf8
Install it, let it update, run the game windowed by right clicking on max payne 3 in steam, property's, then put -windowed in the box. If your not using Steam right click on the desktop icon and select properties. At the end of the target window after the quotations. type -windowed.
Let me know if this helps.
Drizzt
Ezt a valaszt kaptam az aspect ratio kerdesemre hivatalos Rockstar supporttol:
Thank you for contacting R* technical support
We have been receiving several reports from users regarding this. We are looking into possible fixes. In the meantime make sure you have your video cards up to date.
Depending on the video card make (and its user interface to change settings) you can disable the stretch/scaling. If you disable it however, using non-widescreen resolutions will cause some of your monitor real estate to not be used. You can find the settings in the ATI Catalyst Control Center or NVIDIA Control Panel depending on what your video card is.
Cheers,
xxx -
Drizzt
Biztos vagy ebben? Az enyém nem is telepített stema klienst, valahol olvastam is reggel, hogy a steamen nem lehet beregelni a retailt. Megkeresem...
Drizzt
1680*1050-ben egyszerűen aránytalan. Mit lehet ezzel tenni?
Drizzt
Végül csak emailt írtam. Azt válaszolták, hogy 14 max. napos átfutási idővel tudják analizálni a problémát, s cserélni, ha úgy találják.
Mondták még, hogy a CNGnek írjak, mert ők a forgalmazó\kiadó. Írtam nekik is, de ők is totál no comment jellegű választ adtak. Eddigre annyi plussz infóm volt hozzájuk, hogy a munkahelyi dvd-olvasóm be tudta nehezen olvasni, úgyhogy megvan elvileg a tartalma(csak install után merek már biztosat mondani
).:- Nézessem meg a dvd-t, "javasoljuk a DVD tisztítását (polírozását)". (... Hozom is a gépi polírozót...
- Tisztítsam meg a dvd-olvasót.Arról nem szól a fáma, hogy miért épp az egyik lemez olvasásához lenne koszos a dvd-olvasóm, a többi háromhoz meg épp elég tiszta.
Drizzt
No, hazahoztam. A póló egész jó, csak persze L-es, azaz rám hálóing. A 4 dvd-t látni azért szíven ütött. Aktiváció éjféltől lesz? Talán feltelepül addig.
Drizzt
A gametrailersen 7-et kapott, nem jó jel.
- Linux kezdőknek
- Micro Four Thirds
- bambano: Bambanő háza tája
- CURVE - "All your cards in one." Minden bankkártyád egyben.
- Milyen külső akkumulátort mobileszközökhöz?
- MacBook Air 13" M2 16gb ram/256gb ssd 27% Áfás
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RX 9070 XT 16GB GAMER PC termékbeszámítással
- BESZÁMÍTÁS! 64GB Corsair Vengeance LPX 3200Mhz DDR4 memória garanciával hibátlan működéssel
- Értékcsökkentett gamer alaplapok /ASUS/MSI/AM5/Számlával/
