Phobos
Megköszönném, ha valki teszteredményeket is tudna írni, mert mint olvastam a 3.8 sokhelyen lassabb volt. Kíváncsi lennék ez hogy teljesít.
Phobos
kérjük a hozzászólásoknál is figyeljünk.....
Drivers: New Omega Driver Catalyst 3.9
=>Posted by: Mertsch.
=>Sunday, October 12 @ 23:48:20 CEST
Omega just released an updated version of his Driver based on a silently leaked Catalyst driver that came from Dell. Based on unoffical Cat 3.9 version 2.4.96
Read more...
What's New? (2.4.96)
* Based on the leaked Dell drivers (I'm sure almost nobody heard about these,
it was a small leak and it was controlled in time by ATI). (2k/XP)
* New Control Panel option, the WMV hardware support. (2k/XP)
* More Smartshaders effects for OpenGL. (2k/XP)
* Fixed the TV out problems, now the monitor is no longer locked at 60Hz
with TV enabled. (2k/XP)
* Fixed the mutiple monitor problems in the device manager and ATI CP. (2k/XP)
* Fixed the ''Soft-Mods'', some games should no longer crash. (2k/XP)
* Enabled Overclocking support in the normal and soft-moded drivers for
ALL CARDS based on the following chipsets, even if they are locked:
RV250/RV280/R300/RV350. (2k/XP)
* Removed rTool from the driver package as it is no longer needed. (2k/XP)
* Added the ATI Software uninstaller. (2k/XP)
And a personal note:
This is the first driver that does NOT have the annoying bug, that each time you switch from a game to desktop the Card needs to reinitialise (screen goes blank for 1s and is back up again) -
Phobos
http://www.omegacorner.com/index_ati.html
- Gainward RTX 5060 Ti Python III 16GB GDDR7 128bit (NE7506T019T1-GB2061T) Videokártya
- MSI GeForce RTX 5090 VANGUARD SOC /// ÚJ BONTATLAN /// 2028.12.01.-ig GARI /// 2025.12.01. gyártás!
- Nvidia geforce rtx 5070 ventus 3x 12gb(vram)
- Asus GTX660-DirectCU2 II 2 GB GDDR5 192 bit PCI-E Videokártya
- Sapphire PULSE Radeon RX 550 4GB Garanciával!
- DOKKOLÓ BAZÁR! Lenovo, HP, DELL és egyéb más dokkolók (TELJES SZETTEK)
- Lenovo IdeaPad Slim 3 Ryzen 7 8840HS 15" FHD+ 24GB 1000GB Teljeskörű garancia
- Xbox One / Xbox Series játékok
- Azonnali készpénzes Sony Playstation 5 lemezes és digitális felvásárlás személyesen/csomagküldéssel
- Dell P2419H / P2719H Full HD LED IPS 24"-27" LCD monitorok
