Padavan firmware image file-ok, hasznos infók
VANESSZA1
trance89
#2803
Szerintem ezt :
wget --no-check-certificate https://breed.hackpascal.net/breed-mt7621-xiaomi-r3g.bin
és ezt is :opkg updateopkg install kmod-mtd-rwinsmod mtd-rw i_want_a_brick=1mtd unlock /dev/mtd0mtd -r write /root/breed-mt7621-xiaomi-r3g.bin Bootloader
Te írtad be, akkor mi az összevissza ?
VANESSZA1
trance89
#2800
BusyBox v1.29.3 () built-in shell (ash)
_ _ _ _
| | | | | || | _____ _____
| |_| |.----..----. __| || | .----.| ___|| ___|
| _ || -__|| -- || __ || |_ | -__||___ ||___ |
|_| |_||____||__|_||____||___||____||_____||_____|
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
HeadLess/Suste LEDE SNAPSHOT, 16
Kernel: 4.14.77 | Release: r8353-d27d87c
root@XiaomiMiRouter3G:~# wget --no-check-certificate https://breed.hackpascal.ne
--2021-03-19 18:44:31-- https://breed.hackpascal.net/breed-mt7621-xiaomi-r3g.bin
Resolving breed.hackpascal.net... 192.154.240.106
Connecting to breed.hackpascal.net|192.154.240.106|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 105495 (103K) [application/octet-stream]
Saving to: 'breed-mt7621-xiaomi-r3g.bin'
breed-mt7621-xiaomi 100%[===================>] 103.02K 217KB/s in 0.5s
2021-03-19 18:44:33 (217 KB/s) - 'breed-mt7621-xiaomi-r3g.bin' saved [105495/105495]
root@XiaomiMiRouter3G:~# -
VANESSZA1
trance89
#2798
Kiadom a parancsot és ez fogad:
Example: To write linux.trx to mtd4 labeled as linux and reboot afterwards
mtd -r write linux.trx linux
Could not open mtd device: /dev/mtd0
root@XiaomiMiRouter3G:~# * opkg_download: Failed to download http://downloads.l
ede-project.org/releases/packages-18.06.1/mipsel_24kc/base/Packages.gz, wget ret
urned 8.
-ash: *: not found
ede-project.org/releases/packages-18.06.1/mipsel_24kc/luci/Packages.gz, wget ret
urned 8.
-ash: *: not found
ede-project.org/releases/packages-18.06.1/mipsel_24kc/packages/Packages.gz, wget
returned 8.
-ash: *: not found
ede-project.org/releases/packages-18.06.1/mipsel_24kc/routing/Packages.gz, wget
returned 8.
-ash: *: not found
ede-project.org/releases/packages-18.06.1/mipsel_24kc/telephony/Packages.gz, wge
t returned 8.
-ash: *: not found
root@XiaomiMiRouter3G:~# root@XiaomiMiRouter3G:~# opkg install kmod-mtd-rw
-ash: root@XiaomiMiRouter3G:~#: not found
root@XiaomiMiRouter3G:~# Unknown package 'kmod-mtd-rw'.
-ash: Unknown: not found
root@XiaomiMiRouter3G:~# Collected errors:
-ash: Collected: not found
root@XiaomiMiRouter3G:~# * opkg_install_cmd: Cannot install package kmod-mtd-rw
-ash: *: not found
root@XiaomiMiRouter3G:~# root@XiaomiMiRouter3G:~# insmod mtd-rw i_want_a_brick=1
root@XiaomiMiRouter3G:~# Failed to find mtd-rw. Maybe it is a built in module ?
-ash: Failed: not found
root@XiaomiMiRouter3G:~# root@XiaomiMiRouter3G:~# mtd unlock /dev/mtd0
root@XiaomiMiRouter3G:~# Could not open mtd device: /dev/mtd0
-ash: Could: not found
root@XiaomiMiRouter3G:~# root@XiaomiMiRouter3G:~# mtd -r write /root/breed-mt762
root@XiaomiMiRouter3G:~# er
-ash: er: not found
VANESSZA1
Intruder2k5
#2776
Köszönöm, de sajnos ebből nem igazán értem, hogy melyik rész vonatkozik az én esetemre, vagy hogy hogy is álljak neki.
VANESSZA1
Van egy xiaomi MIR3G-m amin HeadLess-Lede-18.01 r7190 14 r7190-1b8f3d9 van fenn.
Kérdésem az lenne, hogy ezt a firmware-t arra is fel lehet tenni? Ha igen mi lenne a menete?
Köszönet előre is
- Filmgyűjtés
- Bambu Lab 3D nyomtatók
- ThinkPad (NEM IdeaPad)
- Battlefield 6
- Futás, futópályák
- MWC 2026: Munkahelyi igásló lehet a Lenovo ThinkTab X11
- ÓRIÁSI AKCIÓK! GARANCIA, SZÁMLA - Windows 10 11, Office 2016 2019 2021,2024, vírusírtók, VPN
- BESZÁMÍTÁS! 8GB Crucial Ballistix Sport 1600Mhz DDR3 memória garanciával hibátlan működéssel
- HIBÁTLAN iPhone 12 Pro Max 128GB Pacific Blue -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
- Azonnali készpénzes Intel i5 i7 i9 8xxx 9xxx processzor felvásárlás személyesen / csomagküldés
- Lenovo Thunderbolt 3 kábel (4X90U90617)
