Meg van, működik.
Átálltam 32 bitre és ezt a két leírást kombináltam össze:
https://raspberrytips.com/unifi-controller-raspberry-pi/ -
betyarr
#45862
Én 64 bites oprendszert tettem fel, mert szeretném használni mind a 4GB RAM-ot.
telepítés után kiadtam egy apt update és apt upgrade parancsot, hogy naprakész legyen a rendszer.Ezzel a paranccsal már van egy kis probléma:
wget "https://github.com/SmokingCrop/UniFi/raw/master/install-unifi-pihole-English.sh" -O install-unifi-pihole.sh && chmod +x install-unifi-pihole.sh && ./install-unifi-pihole.sh no-piholeLefut, de a parancs végén megállapítja, hogy nem tudja telepíteni a MongoDB-t és legyalul mindent.
MongoDB will now be installed as it's a dependency of UniFi.Reading package lists... DoneBuilding dependency tree... DoneReading state information... DonePackage mongodb-server is not available, but is referred to by another package.This may mean that the package is missing, has been obsoleted, oris only available from another sourcePackage mongodb-clients is not available, but is referred to by another package.This may mean that the package is missing, has been obsoleted, oris only available from another sourceE: Package 'mongodb-server' has no installation candidateE: Package 'mongodb-clients' has no installation candidateThe UniFi controller will be installed now.Preparing to unpack unifi_7.3.83_sysvinit_all.deb ...Unpacking unifi (7.3.83-19645-1) ...dpkg: dependency problems prevent configuration of unifi:unifi depends on mongodb-server (<< 1:4.0.0) | mongodb-10gen (<< 4.0.0) | mongodb-org-server (<< 4.0.0); however:Package mongodb-server is not installed.Package mongodb-10gen is not installed.Version of mongodb-org-server on system is 4.4.19.dpkg: error processing package unifi (--install):dependency problems - leaving unconfiguredErrors were encountered while processing:unifiReading package lists... DoneBuilding dependency tree... DoneReading state information... DoneCorrecting dependencies... DoneThe following packages were automatically installed and are no longer required:mongodb-database-tools mongodb-org-database-tools-extra mongodb-org-mongos mongodb-org-server mongodb-org-shellmongodb-org-toolsUse 'sudo apt autoremove' to remove them.The following packages will be REMOVED:unifi0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.1 not fully installed or removed.After this operation, 272 MB disk space will be freed.(Reading database ... 48687 files and directories currently installed.)Removing unifi (7.3.83-19645-1) ...Ez a parancs látszólag lefut:
echo 'deb http://archive.raspbian.org/raspbian stretch main contrib non-free rpi' | sudo tee /etc/apt/sources.list.d/raspbian_stretch_for_mongodb.listdeb http://archive.raspbian.org/raspbian stretch main contrib non-free rpiEzt a parancsot is lefuttatom:
sudo apt update && sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt-get autoclean -yEz a kimenete a parancsnak, ha jól értem ezt sem települ fel:
Hit:1 http://security.debian.org/debian-security bullseye-security InReleaseHit:2 http://deb.debian.org/debian bullseye InReleaseHit:3 http://deb.debian.org/debian bullseye-updates InReleaseHit:4 http://archive.raspberrypi.org/debian bullseye InReleaseHit:5 https://download.docker.com/linux/debian bullseye InReleaseGet:6 http://archive.raspbian.org/raspbian stretch InRelease [15.0 kB]Err:6 http://archive.raspbian.org/raspbian stretch InReleaseThe following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2EReading package lists... DoneW: GPG error: http://archive.raspbian.org/raspbian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2EE: The repository 'http://archive.raspbian.org/raspbian stretch InRelease' is not signed.N: Updating from such a repository can't be done securely, and is therefore disabled by default. -
Amit kitaláltam nem fog menni.
Azt a MongoDB verziót amit az Unifi controller igényel nem lehet feltenni natívan a cuccra. Muszáj lesz dockerrel szórakozni.
A Zabbix is MongoDB-s, így valszeg az is bukta, ott is dockeres bütykölés lesz.
Egyelőre nem vagyok túl jó véleménnyel a cuccról.
Köszönöm a Pi4 hűtésével kapcsolatos infókat. Van itthon egy doboznyi hűtőborda, meg ventilátor teszek rá belőle. Ártani nem árhtat.
Megvan a Pi4. A cpu-ra kell hűtőbordát/aktív hűtést rakni?
Kezd összeállni a terv. (Bocsánat, ez részben nekem is egy összefoglaló lesz, hogy mikor megjönnek a cuccok ne kelljen megint keresgélem.)
Egy Raspberry Pi4 4GB verzió lesz beüzemelve és rá lesz kötve egy 120GB-os HDD USB3-SATA kábellel. A tápot a Pi4 GPIO-n keresztül fogja kapni. (5V a 2 és 4 lábán egyszerre, nehogy gond legyen mert a HDD a Pi4 USB3 csatijából fogja az áramot kapni és a földet is valószínűleg 2 lábon fogja kapni 6 és 9)HDD boot-ra ez egész jó leírásnak tűnik nekem:
https://www.tomshardware.com/how-to/boot-raspberry-pi-4-usbUnifi controller telepítése:
https://community.ui.com/questions/Step-By-Step-Tutorial-Guide-Raspberry-Pi-with-UniFi-Controller-and-Pi-hole-from-scratch-headless/e8a24143-bfb8-4a61-973d-0b55320101dcSamba szerver telepítése
https://magpi.raspberrypi.com/articles/samba-file-serverELK Stack naplógyűjtő, elemző telepítése
https://forums.raspberrypi.com/viewtopic.php?t=268432Zabbix (ha bírja-e még a Raspberry erővel akkor ez is, ha nem akkor majd meglátom)
https://bestmonitoringtools.com/how-to-install-zabbix-on-raspberry-pi-raspbian/ -
wassermann
#45481
Nem tervezem, 120GB több mint elég lesz. Kb 50 GB fájlt fogok rátenni, a maradék 70 GB elég lesz rendszernek, meg annak a 2 applikációnak.
De köszi az infót.Elkezdem összegyűjteni a szükséges linkeket.
Megér +10 000Ft-ot a 4GB-os verzió?
Igen, de lehet csak a 120GB-os lesz rajta, mert annak elég 5V 600mA. A 160GB-os 5V 1200mA kér és ez a max amit a Pi le tud adni USB3-on, ami így kicsit neccesnek tűnik nekem. (A 120GB is bőven elég lesz.) A vinyó folyamatosan darálni fog a logok miatt de az legalább bírni fogja.
@Airedhyal, @AiRLAC köszi az infókat. Akkor ennek még utána kell néznem, mert tévedésben vagyok.
Nekem az volt a tervem, hogy wifin csatlakozik a Pi3 a hálózathoz, USB3-ra kötött HDD-n van az oprendszer. Vagy lehet akkor kevertem a Pi 4-el? Nagyon sok Pi-t néztem az utóbbi napokban, lehet már keverem őket. -
wassermann
#45465
Úgy tudom az Pi3-on van 2 db USB3 csati. Nekem meg olyan kábelem van ami USB3-SATA. Elvileg ezzel akkor nem lehet probléma.
Segítséget szeretnék kérni.
Felmerült bennem, hogy a jelenlegi home szervert (plex, torrent, Unifi management, fájlszerver) kicsit tehermentesíteném.
Arra gondoltam, hogy egy Raspberry pi 3B-t vennék és erre átköltöztetném a Unifi management, fájlszerver funkciókat illetve egy log gyűjtő szoftvert is tennék rá. (Egy Unifi AP és egy Ubiquity Edgerouter logjait kezelné.)
Nincs szabad SD kártyám, ellenben van van itthon több UBS3-SATA kábelem és több 2,5 SATA HDD-m is.
Arra gondoltam, hogy egy ilyen USB-SATA kábellel csatlakoztatnék egy 160GB-os 2,5-es HDD-t a Raspberry-hez, és erre a HDD-re menne fel az oprendszer, a fájlok, szoftverek szóval minden.
Ezt meg lehet-e csinálni?
A Raspberry USB3-on le tud annyi áramot adni, hogy a 2,5 HDD menjen vele?
A Raspberry-hez gyári tápot vennék.
Esetleg egy pendrive-ra fel mehet az oprendszer, abból is van itthon egy marékkal.
- Viccrovat
- Filmvilág
- Poco X6 Pro - ötös alá
- MacOS 14, Win11, Asus Hero Z790, Intel 13900K, 64GB RAM, Asus RX 6950 XT, 4TB WD SN850X
- Rtx 2080Ti/ Ryzen 5 4600G/ 16GB G.Skill/ 1TB M2/ Win11/ Garancia
- Raspberry Pi 5 8 GB + Argon One V3 ház + 512GB SSD + Gyári adapter ELKELT, szállítás alatt!
- Dell ReadyRails A6 1U Rail Kit R210, R210 II, Dx600G, stb. szerverekhez (JWFR6, W6XNW, YNG10)
- Vízhűtéses gép eladó!
- 27% - Crucial 96GB (2x48GB) DDR5 5600MHz CT48G56C46S5 Notebook RAM!
- xBox One x 1Tb lemezes
- GYÖNYÖRŰ iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4322
- 27% - MSI G255PF E2 Monitor! 1920x1080 / 1ms / 180Hz / FreeSync !
- AKCIÓ! Apple MacBook Air 15 M4 32GB RAM 1TB SSD notebook garanciával hibátlan működéssel
