Kérdés feltevése előtt kérlek olvasd át figyelmesen az alábbi leírást!
Hunsaman
Mr Dini #16279 üzenetére
Az új leírásod alapján sem sikerül
pip install youtube-dl
parancsra:
/usr/local/zy-pkgs/ffproot/ffp/bin/python3.5: symbol 'SSL_select_next_proto': can't resolve symbol/usr/local/zy-pkgs/ffproot/ffp/bin/python3.5: symbol 'SSL_CTX_set_next_proto_select_cb': can't resolve symbol
/usr/local/zy-pkgs/ffproot/ffp/bin/python3.5: symbol 'SSL_CTX_set_next_protos_advertised_cb': can't resolve symbol
/usr/local/zy-pkgs/ffproot/ffp/bin/python3.5: symbol 'SSL_get0_alpn_selected': can't resolve symbol
/usr/local/zy-pkgs/ffproot/ffp/bin/python3.5: symbol 'TLSv1_2_method': can't resolve symbol
stb, stb, stb...
Hibaüzenet két oldalon keresztülAzután felraktam a te youtube-dl -edet, és:
ytp https://www.youtube.com/watch?v=3wjb3HtD32c
Parancsra:
Traceback (most recent call last):
File "/ffp/lib/python3.5/runpy.py", line 170, in _run_module_as_main
"__main__", mod_spec)
File "/ffp/lib/python3.5/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/ffp/bin/youtube-dl/__main__.py", line 16, in <module>
File "/ffp/bin/youtube-dl/youtube_dl/__init__.py", line 15, in <module>
File "/ffp/bin/youtube-dl/youtube_dl/options.py", line 7, in <module>
File "/ffp/bin/youtube-dl/youtube_dl/downloader/__init__.py", line 3, in <module>
File "/ffp/bin/youtube-dl/youtube_dl/downloader/common.py", line 8, in <module>
File "/ffp/bin/youtube-dl/youtube_dl/utils.py", line 10, in <module>
File "/ffp/lib/python3.5/ctypes/__init__.py", line 7, in <module>
from _ctypes import Union, Structure, Array
ImportError: File not foundMi lehet a gond?
Hunsaman
Mr Dini #16178 üzenetére
Kiadom ezt a parancsot:
ytp https://www.youtube.com/watch?v=3wjb3HtD32cEzt a hibaüzenetet kapom:
File "/ffp/bin/youtube-dl", line 7, in <module>
from youtube_dl import main
File "/ffp/lib/python2.7/site-packages/youtube_dl/__init__.py", line 15, in <module>
from .options import (
File "/ffp/lib/python2.7/site-packages/youtube_dl/options.py", line 8, in <module>
from .downloader.external import list_external_downloaders
File "/ffp/lib/python2.7/site-packages/youtube_dl/downloader/__init__.py", line 3, in <module>
from .common import FileDownloader
File "/ffp/lib/python2.7/site-packages/youtube_dl/downloader/common.py", line 10, in <module>
from ..utils import (
File "/ffp/lib/python2.7/site-packages/youtube_dl/utils.py", line 11, in <module>
import ctypes
File "/ffp/lib/python2.7/ctypes/__init__.py", line 10, in <module>
from _ctypes import Union, Structure, ArrayMindent a leírásod alapján csináltam. Mi lehet a gond?
Válaszod előre is köszönöm!
Hunsaman
Tudna valaki segíteni, hogy a syncthing-inotify-t ( https://github.com/syncthing/syncthing-inotify/releases/tag/v0.6.7 ) hogyan lehetne beüzemelni NSA-310-en?
Előre is köszönöm!
Hunsaman
Hunsaman
Szia tudsz segíteni?
Ez alapján (http://forum.nas-central.org/viewtopic.php?f=249&t=16597) raknám fel a deluge-t, de hibát dob:
root@NAS:~# pip install cryptography==0.6 service-identity twisted pyopenssl pyxdg chardet setproctitle mako pillow
-sh: pip: command not foundköszi
Hunsaman
NSA310-en megoldható, hogy rádugok egy usb hangkártyát, és internetes rádióként működik?
Hunsaman
Abban tudtok segíteni, hogy az admin felületen amikor az eject gombbal leválasztom az usb kötetet, az milyen
parancsot hajt végre?
Szeretném tudni leválasztani az usb winyót terminálból is.
köszi -
Hunsaman
Van egy ilyen NSA310-em. Benne egy winyó, + hátsó USB-n is egy külső.
Viszont erre az USB-s winyóra nincs mindig szükségem, nem akarom folyamatosan járatni.
Ha ugye ki akarom kapcsolni, akkor a NAS admin felületén előbb le kell választanom.
Tudtok-e valami egyszerű megoldást a leválasztásra?
Gondolok itt olyanra, hogy egy egyszerű ikon az asztalon (akár parancssor parancsikonja) amivel leválasztanám a fent említett külső HDD-t.Válaszaitokat előre is köszönöm!
- AKCIÓ! LG 27MP58VQ-P 27 FHD 75Hz 5ms monitor garanciával hibátlan működéssel
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7800X3D 32/64GB RAM RTX 5080 16GB GAMER PC termékbeszámítással
- Apple iPhone 14 Pro Max / 256 GB / 88% akkumulátor / 1év Garanciával / Gyári Független
- LG 65G4 - 65" OLED evo - 4K 144Hz & 0.1ms - MLA Plus - 3000 Nits - NVIDIA G-Sync - FreeSync Premium
