McJames
[L]http://www.soyo.com.tw[/L] Products-->History products:
SY-5BT5
Description
430TX Baby AT Motherboard
Processor
- Intel Pentium Processor (75-233 MHz)
- Cyrix 6x86 (PR 120-200+), and 6x86 MX and 6x86MII (333)
- AMD K5 (PR-100-166) and K6 (100-233 MHz) and AMD-K6 -2 (266~366 MHz)
- Supports IDT WinChip 2(200~240)
- Supports Rise (PR233 ~ 266)
Chipset
Intel 82430TX PCI Bus Chipset
Expansion Slots
- 4 x 32 bit Bus Mastering PCI slots
- 3 x 16 bit ISA slots (One shareable PCI/ISA slot)
Secondary Cache
Write-Back cache controller
512KB Pipeline Burst SRAM on board
System Memory
- 2 x 168 pin DIMM memory slots
- 4 x 72 pin SIMM memory slots
- Supports 8/16/32/64MB 168 pin modules
- Supports 4/8/16/32/64MB 72 pin modules
Supports max 256MB with Fast Page/EDO/SRAM
BIOS
- Award PCI BIOS with green, plug and play, NCR, SCSI and DMI functions
- Supports multi-boot from E-IDE, SCSI, CD-ROM, FDD, LS120 or ZIP
- 1 Mbit Flash ROM
I/O on Board
- 1 FDD port (supports LS120, 3mode, 1.2/1.44/2.88 FDD)
- 2 RS-232 Serial Ports (16550 UART compatible)
- 1 Parallel Printer Port (SPP/EPP/ECP mode)
- 2 PCI Bus Mastering ATA E-IDE Ports
- 2 USB Ports with optional cable
- PS/2 Mouse Port with optional cable
- IrDA Port with optional cable for transceiver/receiver
Board Size
4 Layer PCB, 22cm x 26cm, Baby AT form factor
Features
- Supports AT and ATX power connector
- PC97 ACPI spec. compliance
- Ultra DMA/33 or ATA E-IDE interface
- Smart detect CPU voltage (2.1, 2.8, 2.9, 3.2, 3.3, 3.52 Volts)
- Switching voltage regulator
- Okos Otthon / Smart Home
- Háremet tartana az adattárolókból a Chieftec letisztult dizájnú háza
- Battlefield 6
- Androidos tablet topic
- Macska topik
- RAM Kingston FURY Beast 32GB DDR5 6000MHz KF560C36BBE-32
- ASUS H97-PLUS + Intel Core i7-4790 + HyperX Savage 16GB RAM
- Kingston FURY Beast 16GB (1x16GB) DDR4 3200MHz
- Kingston FURY 32GB (2x16GB) DDR4 3200MHz (Beszámítás)
- GIGABYTE Z790 EAGLE +2x16GB 6400MHz CL32 PATRIOT VIPER VENOM DDR5 kit egyben eladó! GAR/SZÁMLA!
- Honor laptop i5-12500H / RTX 2050 / 16GB RAM / 512GB SSD / 2K kijelző Erős, prémium gép!
- BESZÁMÍTÁS! Inno3D iChill X3 RTX 3080 Ti 12GB videokártya garanciával hibátlan működéssel
- Huawei Watch 5 Titanium 46mm
- HP Probook 445R G6,14",FHD,AMD Ryzen 5 3500U,8GB DDR4,256GB SSD,WIN11
- Keresünk iPhone 16/16e/16 Plus/16 Pro/16 Pro Max
