Ubuntu Linux Összefoglaló
Hivatalos Ubuntu dokumentáció
lspci
lsusb
missmarple
CD-ről próbálok telepíteni egy ubuntu-12.04.3-server-i386.-t. és a Select and install software részen egy piros képernyőt kapok "Installation step failed" üzenettel. Több CD-t már próbáltam már, MD5SUM-al a (többször) letöltött fájlt már ellenőriztem rendben. Esetleg valakinek van ötlete? illetve segítene megfejteni az alábbi syslogot (ez a vége, ezt adja a hibaüzenet megjelenésekor.)
Dec 4 20:28:18 kernel: [ 4989.084001] sr 1:0:1:0: [sr0]
Dec 4 20:28:18 kernel: [ 4989.084072] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Dec 4 20:28:18 kernel: [ 4989.084079] sr 1:0:1:0: [sr0]
Dec 4 20:28:18 kernel: [ 4989.084085] Sense Key : Illegal Request [current]
Dec 4 20:28:18 kernel: [ 4989.084096] sr 1:0:1:0: [sr0]
Dec 4 20:28:18 kernel: [ 4989.084115] Add. Sense: Illegal mode for this track
Dec 4 20:28:18 kernel: [ 4989.084122] sr 1:0:1:0: [sr0] CDB:
Dec 4 20:28:18 kernel: [ 4989.084126] Read(10): 28 00 00 04 fa bb 00 00 02 00
Dec 4 20:28:18 kernel: [ 4989.084148] end_request: I/O error, dev sr0, sector 1305324
Dec 4 20:28:25 in-target: Failed to fetch cdrom:[Ubuntu-Server 12.04.3 LTS _Precise Pangolin_ - Release i386 (20130820.2)]/pool/main/t/tmux/tmux_1.6-1ubuntu1_i386.deb Hash Sum mismatch
Dec 4 20:28:25 in-target: 0 upgraded, 169 newly installed, 0 to remove and 0 not upgraded.
Dec 4 20:28:25 in-target: Need to get 0 B/38.6 MB of archives.
Dec 4 20:28:25 in-target: After this operation, 121 MB of additional disk space will be used.
Dec 4 20:28:25 in-target: E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Dec 4 20:28:25 in-target: tasksel: aptitude failed (100)
Dec 4 20:28:26 main-menu[375]: WARNING **: Configuring 'pkgsel' failed with error code 1
Dec 4 20:28:26 main-menu[375]: WARNING **: Menu item 'pkgsel' failed.
Dec 4 20:28:33 main-menu[375]: INFO: Modifying debconf priority limit from 'medium' to 'low'
Dec 4 20:28:33 debconf: Setting debconf/priority to low
Dec 4 20:28:35 main-menu[375]: DEBUG: resolver (libnewt0.52): package doesn't exist (ignored)
Dec 4 20:28:35 main-menu[375]: DEBUG: resolver (ext2-modules): package doesn't exist (ignored)
Dec 4 20:28:35 main-menu[375]: DEBUG: resolver (efi-modules): package doesn't exist (ignored)
Dec 4 20:28:50 main-menu[375]: INFO: Menu item 'save-logs' selected -
missmarple
Valaki meg tudná mondani milyen van e olyan parancs amivel ki tudom listázni a xinetd-ből futtatott folyamatokat (csak azokat).
Kösz a választ.
- Vélemény Ubuntu 20.04 LTS
- Teljesen M5 SoC-családra vált az Apple Macbook Air és Pro
- Milyen routert?
- Az Office-t is elengedi a terméktámogatás nélküli Windows 10-en a Microsoft
- Xbox Series X|S
- Milyen nyomtatót vegyek?
- Spórolós topik
- Battlefield 6
- 600 Mbps-os tempót ígér 2,4 GHz-en az ASUS RT-N18U High Power routere
- Filmvilág
- The Elder Scrolls Online Imperial Collector s Edition
- Vállalom Xiaomi Okoskamerák szoftveres javíttását
- Bomba áron dobozos Hp Laptop! /AMD Ryzen 5-7520U/8 GB/256 SSD/FHD/Garancia
- BESZÁMÍTÁS! Gigabyte B450M R5 2600X 16GB DDR4 512GB SSD GTX 1650 4GB ZALMAN T3 Plus Deepcool 400W
- 196 - Lenovo Legion Pro 5 (16IAX10) - Intel Core U7 255HX, RTX 5070 (ELKELT)
- Dell P2419H / P2719H Full HD LED IPS 24"-27" LCD monitorok
