(Frissítve: 2020.05.31.)
krealon
kico76
#158512
"Sokszor üresjáratban 100%-on pörög az SSD."
Probáld kikapcsolni "PCI Express Link State Power Management"-et.
Control Panel\Hardware and Sound\Power Options\Edit Plan Settings\Change advanced power settings\PCI express\Link state power management
És ha legközelebb Gaming PC-t építsz, kerüld a HMB-s SSD-ket.
krealon
tordaitibi
#158262
Letesztelni nem tudom, de elég pontosnak tűnik ez a leírás
(Az első 3 pont biztosan jó)https://www.google.com/search?q=bcdedit+add+ubuntu+to+windows+10
To add Ubuntu to the Windows 10 bootloader using
bcdedit, you'll need to first copy the existing Windows boot entry, then modify the copy to point to the Ubuntu bootloader file. After that, you'll need to add the new entry to the boot menu and set the display order.
Here's a step-by-step guide:1. Open Command Prompt as Administrator: Right-click on the Start button and select "Command Prompt (Admin)".
2. List existing BCD entries: Use the command
bcdedit /enum firmware
to see all entries related to UEFI. This will list all entries, including the Windows Boot Manager (usually labeled{bootmgr}).3. Copy the Windows Boot Manager entry: Use the command
bcdedit /copy {bootmgr} /d "Ubuntu"
. This will create a new entry with the specified description. Replace{bootmgr}with the actual identifier of your Windows Boot Manager, if it's different.4. Set the path to Ubuntu's bootloader: Use the command
bcdedit /set {new_guid} path "\\EFI\\ubuntu\\shimx64.efi"
. Replace{new_guid}with the unique identifier generated in step 3. Ensure the path is correct. If using a different bootloader (likegrubx64.efi), adjust the path accordingly.5. Add the new entry to the display order: Use the command
bcdedit /displayorder {new_guid} /addlast
. This adds the new entry to the end of the boot menu.6. Set the boot menu to be displayed: Use the command
bcdedit /set {bootmgr} displaybootmenu Yes
. This ensures the boot menu is displayed on startup.Important Notes: Make sure you have a bootable USB drive or DVD of Ubuntu installed, and that you can boot into it. If you encounter issues, try disabling Secure Boot in your BIOS settings. You may need to consult your specific Ubuntu version documentation for the correct bootloader file path. If you want to boot into Ubuntu directly, you may need to adjust the boot order in your BIOS.
By following these steps, you can add Ubuntu to your Windows 10 bootloader using
bcdeditand create a dual-boot environment.AI responses may include mistakes.
krealon
tordaitibi
#158236
"Megzakkant a felhasználói fiókod a gépen, azért nem tud beléptetni abba.
Az userpaswordsba is csak a rendszergazda látszik.
Hogy ezt hogyan lehetne helyretenni, azt nem tudom."A profil sérülést (temporary profile) tipikusan registry szerkesztéssel lehet javítani, egy másik admin jogu felhasználóval belépve vagy offline. Ez egy több lépéses folyamat, időt igényel, de kevesebbet mint egy újratelepítés / újrabeállítás.
krealon
Kis Tigris
#158235
"A control userpasswords2 parancsra ez ugrik fel, ahol érdemben semmit nem tudok csinálni, amitől megszünne az a fránya bejelentkeztetési ablak"
Ott a jelülőnégyzet (A számítógép használatához...), amivel ki tudod kapcsolni az autómata belépést.
Ha megvan, indítsd újra gépet, majd a jelölő négyzet állapotát állítsd vissza.
Ekkor a kijelölt fiók jelszavát elkéri és újra működni fog az autómata belépés.Persze a jelszó legyen felírva és biztonságos helyen tárolva, mert amit nem használsz, azt elfelejted. (Tapasztalatból mondom.)
krealon
Kis Tigris
#158232
Egészen véletlenül nem vagy Skype felhasználó?
A Teams-re váltásnál volt egy opció, hogy minden Microsoft-os alkalmazásba léptessen be autómatikusan.
A Settings --> Accounts alatt lehet ezt kikapcsolni.Ha gépinduláskor autómatikusan beléptet, akkor azt a
contol userpasswords2
paranccsal felugró menüben lehet szabályozni.
Ha változott a belépéshez használt jelszó, akkor a kikapcs-/bekapcs módszerrel lehet frissíteni. -
krealon
Sztlaci
#156187
"Más ami bosszant, hogy átjáró ház lett a WIN, mindenki jelzés nélkül beleturkálhat a gépembe. VLC frissített, jelzés nélkül és a Skype is. Csak onnan tudom, hogy frissültek, megelent az ikonjuk az asztalomon. Mivel azokat korában töröltem csak a háttérben észrevétlen módon történt frissítéssel kerülhetett vissza az asztalra. Szerintem ez pofátlanság!"
Véletlenül nem Avast Antivirust használsz?
krealon
astrojoe12
#155366
Vagy megnézed az esemény napló bejegyzéseket a boot-olás ideje környékéről. Oda is feljegyzésre kerülnek a hibák.
krealon
enginev3.0
#153984
"Ha bekapcsolom a bitlockert, és beállítok egy jelszót a hdd-re
Az azt jelenti hogy azon a gépen nem kér jelszót a hdd tartalmához"De, kérni fogja.
Viszont ha TPM-ben lehet tárolni ezt a jelszavat, akkor a felhasználónak már nem kell beírnia, a Windows autómatikusan használja az elmentettet."ha kiveszem a hdd-t és berakom egy másikra, akkor csak jelszóval lehet megnézni a fájlokat?"
Pontosan.
krealon
poolbig
#149502
"Hogy lehet a Win10-et úgy lebutítani egy adott felhasználónál, hogy csak egy bizonyos programot lehesen (pl. Chrome) indítani és semmilyen egyéb beállításhoz ne férjen hozzá a júzer?"
A megoldás:
Windows 10 Kiosk mode -
krealon
betyarr
#149500
"az itthoni gépeknél le van tiltva a jelszó kérése a win bejelentkezésnél (netplwiz)."
A fogalmi zavar okozza a kérdésedet.
Nem letiltva van, hanem el van mentve és automatikusan kitöltésre kerül bejelentkezéskor.Ha lezárod a gépet (Win + L), akkor a jelszavat be kell Írni, hogy használni tudd.
Ebből egyértelműen következik, hogy ha megváltoztatod a fiókhoz tartozó password-öt, akkor a rögzÍtett jelszó nem lesz megfelelő.
krealon
tordaitibi
#144810
"Konkrétan, egy rendszer vhdx fájlba másolásakor a fájlba megvan az efi, és a rendszerpartíció.
Ez akkor miért nem indul el bármilyen más környezetben?"A rendszer piszkálása (mentés, konverzió virtuális géppé, stb) ki kell kapcsolni a hibernációt.
Ha egy hibernált rendszerbe belepiszkálsz, az menthetlenül összedől.
krealon
Panthera
#144279
Erre van szükséged az Active Directory matatáshoz:
Remote Server Administration Tools for Windows 10
https://www.microsoft.com/en-us/download/details.aspx?id=45520 -
krealon
cintula187
#144182
Ha jól értem, nem tudod melyik alkalmazás dobja fel az ablakot.
Ezen a Process Explorer célzó kereszt ikonja tud segíteni, amit rá kell húzni az azomosítani kívánt ablakra.
Ha már tudod mi adja a hibaüzenetet, közelebb kerülsz a megoldáshoz.
krealon
Tomi_78
#144051
"Nem sikerült telepíteni a frissítéseket, de később újból próbálkozunk. Ha nem szűnik meg a hiba, és megoldást keresne az interneten vagy az ügyfélszolgálathoz szeretne fordulni segítségért, a hibakódnak (0x80073701) hasznát veheti."
TL;DR
[Start] --> gépeld
cmd--> [Ctrl] + [Shift] + [Enter] (futtatás rendszergazdaként) --> megerősíteni az emelt szintű futtatást-->dism /online /cleanup-image /startcomponentcleanup
Miután végzett, újra kell indítani a gépet.
Ezek után ujra kell probálni a windows update futtatását. -
krealon
"egy AD-ban levo gepen hogyan lehet letiltani a tavoli telepitest?"
Mi az a távoli telepítés?
"termeszetesen az AD-ban levo gepen van lokalis rendszergazdai felhasznalo is!"
Ha egy gépen egy felhasználó tudja a lokális rendszerga fiók jelszavát, akkor azon bármit megtehet.
krealon
#140275
"Használnom kellett a régi (W7) képnézegetőt W10 alatt.
Ezzel a módszerrel : [link]
aktiváltam , működik , minden fa..a.
Viszont már nincs rá szükség és egyébként is a laptopon életlenek ezzel a fotók nézegetés közben."ime az eredeti registry tartalom Win10 20H2-es rendszeren: (notepad-dal kell .reg kiterjesztésű fájlba másolni)
Windows Registry Editor Version 5.00[HKEY_CLASSES_ROOT\jpegfile]@="JPEG Image""EditFlags"=dword:00210000"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\32,00,5c,00,73,00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,\00,2c,00,2d,00,33,00,30,00,35,00,39,00,36,00,00,00"ImageOptionFlags"=dword:00000001[HKEY_CLASSES_ROOT\jpegfile\CLSID]@="{25336920-03F9-11cf-8FD0-00AA00686F13}"[HKEY_CLASSES_ROOT\jpegfile\DefaultIcon]@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,69,00,6d,00,\61,00,67,00,65,00,72,00,65,00,73,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,37,\00,32,00,00,00[HKEY_CLASSES_ROOT\jpegfile\shell][HKEY_CLASSES_ROOT\jpegfile\shell\printto]"NeverDefault"=""[HKEY_CLASSES_ROOT\jpegfile\shell\printto\command]@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,72,00,\75,00,6e,00,64,00,6c,00,6c,00,33,00,32,00,2e,00,65,00,78,00,65,00,22,00,20,\00,22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,\25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,\00,69,00,6d,00,67,00,76,00,77,00,2e,00,64,00,6c,00,6c,00,22,00,2c,00,49,00,\6d,00,61,00,67,00,65,00,56,00,69,00,65,00,77,00,5f,00,50,00,72,00,69,00,6e,\00,74,00,54,00,6f,00,20,00,2f,00,70,00,74,00,20,00,22,00,25,00,31,00,22,00,\20,00,22,00,25,00,32,00,22,00,20,00,22,00,25,00,33,00,22,00,20,00,22,00,25,\00,34,00,22,00,00,00[HKEY_CLASSES_ROOT\jpegfile\ShellEx][HKEY_CLASSES_ROOT\jpegfile\ShellEx\{e357fccd-a995-4576-b01f-234630154e96}]@="{C7657C4A-9F68-40fa-A4DF-96BC08EB3551}"Ez pedig a pngfile
Windows Registry Editor Version 5.00[HKEY_CLASSES_ROOT\pngfile]@="PNG Image""EditFlags"=dword:00210000"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\32,00,5c,00,73,00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,\00,2c,00,2d,00,33,00,30,00,35,00,39,00,38,00,00,00"ImageOptionFlags"=dword:00000001[HKEY_CLASSES_ROOT\pngfile\CLSID]@="{25336920-03F9-11cf-8FD0-00AA00686F13}"[HKEY_CLASSES_ROOT\pngfile\DefaultIcon]@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,69,00,6d,00,\61,00,67,00,65,00,72,00,65,00,73,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,38,\00,33,00,00,00[HKEY_CLASSES_ROOT\pngfile\shell][HKEY_CLASSES_ROOT\pngfile\shell\printto]"NeverDefault"=""[HKEY_CLASSES_ROOT\pngfile\shell\printto\command]@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,72,00,\75,00,6e,00,64,00,6c,00,6c,00,33,00,32,00,2e,00,65,00,78,00,65,00,22,00,20,\00,22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,\25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,\00,69,00,6d,00,67,00,76,00,77,00,2e,00,64,00,6c,00,6c,00,22,00,2c,00,49,00,\6d,00,61,00,67,00,65,00,56,00,69,00,65,00,77,00,5f,00,50,00,72,00,69,00,6e,\00,74,00,54,00,6f,00,20,00,2f,00,70,00,74,00,20,00,22,00,25,00,31,00,22,00,\20,00,22,00,25,00,32,00,22,00,20,00,22,00,25,00,33,00,22,00,20,00,22,00,25,\00,34,00,22,00,00,00 -
krealon
VGYke
#140050
A csonkolt nevű mappákat az UTF8 karakterkódolással nem kompatibilis, elavult programok hozzák létre, nem vírusok. (Bár elvileg vírusok is lehetnének, de ha olyan vacakok, hogy ilyen könnyen lelepleződnek, akkor terjedni sem lesznek képesek.)
Javaslat:
A felhasználói fiókok nevében ne használj ékezetes betűt.Hozd létre ékezetek nélkül, majd később írd át a Display Name-et tetszőlegesen.
krealon
Lenry
#140038
A helyes irásmód:
net use z: \\192.168.1.2\share jelszo /user:192.168.1.2\usernév /persistent:yesHa a
/useropciónál elhagyjuk a host részt, akkor az autómatikusan a.\usernévformára, vagyis ahelyigépneve\usernévformára vonatkozik és a távoli gép a helyi gépen próbál hitelesíteni és még ha sikeül is, a kiszolgáló gépen valószínűleg nincs hozzáférés engedélyezve kliensben hitelesített felhasználók részére.Szerk: formázás
krealon
gringoka
#139625
"4k remuxot lehetséges valamelyikkel?"
A virágboltból kölcsönzötekkel nem szokott gond lenni SMB használatakor.
Az extrém tesztvideó-állományok igényelhetnek csak nfs-t.Szerk: link javítás
krealon
gringoka
#139620
"win10-ről szeretnék streamingelni egy android boxra amin coreelec fut, melyik lenne a legalkalmasabb megoldás? Ftp? smb? vagy nfs?"
A felsorolt protokollok mind fájl megosztási módok, nem pedig stream szolgáltatások (mint amilyen a DLNA).
Alapvetően a Windwos beépített fájlmegosztása (SMB) megfelelő szokott lenni, csak nagyon elvetemült esetekben (extrém magas bitrátájú forrásanag) lehet szükség nfs (Linux Network File Sharing) beüzemelésére.
DLNA kapcsolatot a Windows Media Player tud megvalósítani. CoreElec-kel működö lejátszó esetén, ez a lehető legrosszabb megoldás.Szerk: nyelvhelyesség
krealon
junior11
#139618
Az Eseménynaplóban lenne érdemes kutakodni a terhelés indulása és leállása körüli időpontan.
Process Explorer-rel tudsz thread szinten leásni a system process lelki világába, hogy mit is csinál valójában.
[Itt] egy esettanulmány, hogy Performance Toolkit-tel hogyan lehet felderíteni a hibaforrást. -
krealon
Tommedli
#139593
https://www.diskpart.com/windows-10/multiple-recovery-partitions-windows-10.html
Elvileg a recovery partíció növelés elég az update probléma orvoslására.
krealon
Croft-21
#139395
"Kikapcsoltam a képernyőkímélőt, de ha elmegyek a géptől 10 percre és vissza jövök, akkor ugyanúgy azt tapasztalom, hogy fel van pörögve a CPU/GPU ventije, és ezt szintén csak úgy tudom megszüntetni, ha megrázom az egeret"
Elmenetel előtt nyisd meg a Feladatkezelőt (Ctrl + Shift + Esc , balra lent "Több részlet" ) és a CPU oszlop fejlécére kattintás után sorbarendezi a folyamatokat terhelés szerint.
Amikor felbőgtek a ventillátorok, nézd meg, hogy mi terheli a CPU-t (a legfelső sorban lesz megtalálható).
krealon
viperabácsi
#139099
A múlt héten egy HDD-SSD cserenél (Macrium klónozás) bukott ki, hogy a május óta nem frissülő Windows 10, Windows Update hibája mögött, a HDD-n keletkezett hibás szektorok állnak.
Szerencsére szoftveres úton rendbe lehett hozni, majd a klónozás után a Windows Update is működni kezdett. -
krealon
Win-T
#137838
"Az irodai gépem lassúcska G630-as prociját lecserélem egy tempósabb i5 3570-re a napokban, minden más marad ami eddig benne. Szerintetek ezt nagyon zokon veszi majd a Windows 10 vagy nem problémázik vele különösebben."
Ha kikapcsolod a hibernálást a hardveres matatás idejére, akkor biztosan probléma mentes lesz a processzor csere.
Adminisztratív parancssorban a hibernáció kikapcsolása:powercfg -h offA hibernálás visszakapcsolására a parancs pedig:
powercfg -h on -
krealon
V.Stryker
#136920
"Van egy program, amit a rácsatlakoztatott monitorra szoktam áthúzni. Most nem húztam vissza, itthon nincs másik monitor és nem tudom az ablakát a noti kijelzőjén megjeleníteni, csak a tálcán jelenik meg. Nyilván a külső monitorra akarja kirakni.
Plusz monitor nélkül, hogy tudnám visszahozni a noti kijelzőjére?"Ilyenkor jön jól az old-school (egér mentes, Windows billentűparancs) tudás.
Aktiváld a mozgatni kívánt ablakot a tálcán.
Alt + Space -re feljön az ablak kezelő alapmenü
M billentűvel aktiválható az aláhúzott M betűt tartalmazó elem, ami az angol nyelvű windwos esetén a Move (Mozgatás).Ezután az ablak a kurzorbillentyűkkel (nyilak) mozgatható, majd a végleges pozíciót az Enter-rel véglegesíthetjük
Magyar Windows-nál egy láthtó ablakon ki kell próbálni, hogy a Mozgatás parancsnak mi a gyorsbillentűje.
krealon
User42
#134007
"A Windows Intézőben a bal oldali menüben található "Hálózat" menü gyakorlatilag mit jelent? A nevéből ítélve nyilván egy helyi hálózatot lenne vagy ilyesmi, de konkrétan mik jelennek itt meg? Azért kérdezem, mert nekem van egy laptopom itthon, semmilyen más számítógép nincs a háztartásban, és soha nem is állítottam be semmilyen hálózatot. De mégis van itt a Hálózat menüponton belül egy olyan elem, hogy "DESKTOP-V8BGSHA". Néhány napja volt egy másik elem is, "LAPTOP-(számsor)" néven, de magától eltűnt. Ezek mik, két másik számítógép, ami ugyanazon a hálózaton van, mint az én gépem?"
Nem. [link]
"Ők látják az én fájlaimat?"
Nem.
"Kell, hogy aggódjak emiatt?"
Elvileg nem.
"Hogy lehet letiltani ezeket?"
Letiltod a radios csatolokat a gepeden (wifi, bluetooth).
krealon
MikeWazowski
#133997
"Vettem egy vezeték mentes BT-s fülest és azzal játszok STADIA-n. A gondom az, hogy a BT füles miatt akad a játék... lehet valahogy javítani ezen? Fura, mert a füles nem a netről működik, akkor meg miért akad a játék?"
A 2.4 GHz-es wifi és a Bluetooth is ugyanazt a frekvenciasavot hasznalja.
Kell tovabb magyaraznom?
Megoldas1: hasznalj kabeles internet kapcsolatot, vagy 5 GHz-es wifit.
Megoldas2: hasznalj kabeles fulest. -
krealon
pungora96
#133598
Jol latom, hogy
\\es a192.168.0.102kozott van egy szokoz?
Ha igen, akkor nem kene, hogy legyen.
Egyeb esetben a mar unalomig ismetelt SMB v1.0 hibanak tunik. (Felteve, hogy a192.168.0.102IP cim valoban jo.)Szerk:
Az samba config finomhangolasarol valoszinuleg egy linux-os topikban talasz reszleteket. (Rasbian-hoz meg nem volt szerencsem.) -
krealon
gabber01
#133584
https://www.ghisler.com/order.htm
"Total Commander for Windows is a Shareware (demo version) program. This means that you can test it for a period of 30 days. After testing the program, you must either order the full version, or delete the program from your harddisk."Vagyis 30 nap probaidore legalisan hasznalhatod, de utana meg kellene venned vagy le kellene torolnod.
Az, hogy nem szankcionaljak a warez hasznalatot, nem jelenti, hogy ingyenes. (Es egyben jol raszoktatjak a kozonseget.) -
krealon
krealon
VGYke
#133232
"Ha most újra fogok telepíteni és nem akarok szórakozni a háttértárak le és vissza csatlakoztatásával (tehát hagyom úgy ahogy van: 1rendszer SSD, 2mentés SSD, 3mentés HDD), mit kell tennem telepítés előtt/alatt hogy a win10 ne disznólkodjon rá a 2-3 háttértárakra? "
A tennivalo, hogy ne legyen boot-olasra alkalmas particio a gepben, ahova a Windows a boot managert telepithetne.
Ekkor kenytelen ujat letrehozni.Azert szokas ajanlani, hogy legyen minden, szuksegtelen hattertar kapcsolata megszuntetve, a telepites idejere, mert ez sokkal egyszerubb es biztonsagosabb, mint particiokkal buveszkedni, aminek konnyen lehet adatvesztes a vege, avatatlan kezben.
krealon
Kenderice
#133216
"Bluetooth gondom lenne.
Laptop, beépített 4.0-ás eszköz.
Párosítok egy eszközt. Működik rendben.
Használat után kikapcsolom a bluetooth-t a windowson.
Következő alkalommal bekapcsolnám, de nincs bekapcsolás gomb."Ilyesfajta problemat a Windows altal telepitett generikus drivereknel szoktam tapasztlni.
A notebook gyarto altal kozzetett driver problemamentes szokott lenni. -
krealon
Bibby
#133045
"Nem altatom, nem hibernálom, hanem lekapcsolom."
Ha a hibernalas vagy a gyorsinditas nincs letiltva, akkor bizony a kikapcsolas is hibernalas.
"Tehát éjjel kinyomom, reggelre veszít a töltésből (pl tegnap 60%-ról 47%-ig, kb 8 óra alatt)."
Ez annak koszonheto, hogy hajnali kettokor (2:00 AM) indulnak el az automatikus karbantarto folyamatok alapertelmezes szerint.
krealon
Hege1234
#132358
"most készülök újrarakni a gépet..
van a gépbe 5 hdd arra mi a megoldás hogy a programok amik a C:\ meghajtón lesznek
ne kelljen a jogosultságokkal bajlódni a többi hdd-n?
pl. Kodi alapból a C:\ meghajtón van de a másik meghajtókon már csak akkor látja a filmeket ha a jogosultságokat átrakom a jelenlegi felhasználóhoz
qbittorrent is és még jó pár program
mi lehet a probléma?"Az a problema, hogy a Windows NT-tol kezdodoen mar a Windows is tobbfelhasznalos rendszer.
Minden telepiteskor a rendszer general maganak egy globalisan egyedi azonositot (Global Uinqe Identity (GUID)).
A telepiteskor, a letrehozott felhasznalot a fenti GUID-bol generalt System ID (SID) azonositja.
A "nev"-kent megadott karaktersorozat, csak egy jelzo, amivel az ember szamara is konnyen azonosithatova valik a felhasznaloi fiok, de a rendszer a SID alapjan kezeli a hozzafereseket.Emiatt van, hogy egy adott felhasznalo kizarolagos tulajdonaban levo fajl vagy mappa, ujratelepites utan elerhetetlenne valik.
A MEGOLDAS, hogy leteznek a rendszerben elore, rendszer szinten definialt csoportok, amelyekbe az uj felhasznalok automatikusan bekerulnek (pl Felhasznalok (Users)).
Ezek a csoportok azonositoi elternek (nem a GUID alapjan generalodnak) a felhasznaloi azonositoktol.Ha ezekhez a csoportokhoz tarsitjuk a hozzaferesi jogokat, akkor azok az ujratelepites eseten automatikusan ervenyre jutnak es nem kell manualis jogosultsag allitasokkal bibelodni.
Alapertelmezeten peldaul a Windows altal letrehozott uj NTFS fajlrendszeru koteten letrehozott mappa es az az alatt letrehozott tobbi elem, minden olyan felhasznaloi fiok, ami a "felhasznalo" csoport tagja, kepes modositani (olvasni, irni, torolni).
A
cacls(Change Access Control ListS) es azicacls(Interactive CACLS) parancsokkal listazhato az aktualis hozzaferesi jog (es esetleg modosithato is).C:\>cacls \C:\ BUILTIN\Administrators:(OI)(CI)FNT AUTHORITY\SYSTEM:(OI)(CI)FBUILTIN\Users:(OI)(CI)RNT AUTHORITY\Authenticated Users:(OI)(CI)(IO)CNT AUTHORITY\Authenticated Users:(special access:)FILE_APPEND_DATAC:\>cacls \UsersC:\Users NT AUTHORITY\SYSTEM:(OI)(CI)FBUILTIN\Administrators:(OI)(CI)FBUILTIN\Users:RBUILTIN\Users:(OI)(CI)(IO)(special access:)GENERIC_READGENERIC_EXECUTEEveryone:REveryone:(OI)(CI)(IO)(special access:)GENERIC_READGENERIC_EXECUTEC:\>icacls \\ BUILTIN\Administrators:(OI)(CI)(F)NT AUTHORITY\SYSTEM:(OI)(CI)(F)BUILTIN\Users:(OI)(CI)(RX)NT AUTHORITY\Authenticated Users:(OI)(CI)(IO)(M)NT AUTHORITY\Authenticated Users:(AD)Mandatory Label\High Mandatory Level:(OI)(NP)(IO)(NW)Successfully processed 1 files; Failed processing 0 filesC:\>icacls \Users\Users NT AUTHORITY\SYSTEM:(OI)(CI)(F)BUILTIN\Administrators:(OI)(CI)(F)BUILTIN\Users:(RX)BUILTIN\Users:(OI)(CI)(IO)(GR,GE)Everyone:(RX)Everyone:(OI)(CI)(IO)(GR,GE)Successfully processed 1 files; Failed processing 0 filesC:\> -
krealon
peterattila
#131992
"három mappa tartalmaz video anyagokat, ezekből kettő hibátlan, a harmadiknál viszont csak a belső mappákat mutatja, a bennük lévő videokat már nem."
Van az utvonalban vagy a fajlnevben hosszu o" vagy hosszu u" betu?
krealon
havri1
#130770
"Mennie kell állandóan, energiagazdálkodásban alvó mód kikaocsolva. Hajnal fél 2 körül mégis alvóba ment."
disable_sleep.bat
tartalmapowercfg /change standby-timeout-ac 0powercfg /change hibernate-timeout-ac 0Az igy konfiguralt gepek nalam 0-24 mukodnek.
Sima felhasznalokent futtathato, nincs szuksseg emelt jogosultsagra. -
krealon
"Eddig soha nem tapasztalt jelenséggel kellett szembesülnöm, nevezetesen egyszer csak újraindult a gép és ezt a hibát írta ki. majd a betöltést követően kb. 3-4 percenként újraindult és mindezt számtalanszor megismételte."
Javithatatlan boot-loop-ot legutobb szektorhibas HDD eseten lattam, amit a gazdaja addig-addig probalt a beepitett eszkozokkel "javitani", amig teljesen menthetetlen nem lett a rendszer.
Szoval eloszor a HDD allapotat vizsgalnam.
krealon
The.Bali
#125478
"A VGA kábelt kipróbáltam egy HDMI-VGA átalakítóval HDMI portban, úgy tökéletes volt a kép"
Na errol egy szo sem esett az eredeti irasban, ezert visszavonom a javaslatomat.
Igy valoszinubb, hogy a notebook (varj egy pillanatot, felveszem a gondolatolvaso sipkamat es megtudom a tipusat
) VGA kimeneti fokozata nem tud tisztesseges jelet prdukalni. -
krealon
The.Bali
#125474
"Adott egy notebook egy HDMI és egy VGA csatlakozóval és rá van kötve két monitor."
Ket azonos monitor vagy kulonbozoek? Ha kulonbozoek, milyen tipusuak?
A kepen lathato arnyekok forrasa, az analog atviteli kabelen letrejovo jelvisszaverodes, koznapi neven szellemkep.
Visszaverodes akkor jon letre, ha nincs hullamimpedancia illesztettseg a kabel vegen (kontakthiba, nem megfelelo impedanciaju kabel) vagy a kabelen serules van, ami impedancia valtozast okoz. (Regen, az analog TV idoszakaban, ez egy gakori jelenseg volt a TV adasoknal.)
A D-sub csatlakozos, hagyomanyos VGA kabelen analog jel kozlekedik, ezert nagy felbontas eseten (nagy frekvenciaju analog jelnel) kritikus a kabel es a csatlakozok minosege.
TL;DR
Cserelj kabelt. -
krealon
edeleny
#125409
"Adott egy laptop. A problémája, hogy látszólag nem fut semmi, mégis folyamatosan 100 %-on használja a vinyót, e miatt gyakorlatilag az egér is darabosan mozog."
A mult heten egy hasonlo tuneteket produkalo asztali geprol derult ki, hogy a winyon gyenge szektorok voltak, ezert neha a HDD valszideje 10-15 masodpercre is felugrott (erdemes ellenorizni a Feladatkezeloben).
Nagynehezen klonoztam egy SSD-re, utana megtaltosodott a gep. -
krealon
borges7
#124174
"másik mappába átmásolva gond nélkül megnyitja őket"
Ha atmasolsz egy fajlt egy masik mappaba, akkor automatikusan az ott ervenyes jogokat kapja meg.
Ha ott mukodik, akkor az eredeti helyen, ahol nam mukodik, nagy valoszinusegel hozzaferesi jog hiany van.Ha egy fajlt athelyezel koteten belul, akkor megmaradnak a korabbi hozzaferesi jogok.
krealon
Gergello
#120595
"Azzal tisztában vagyok, hogy a telepítéshez kiválasztott meghajtóra csinál még "reserved" stb. partíciókat. Így valóban nem értem, hogy a másik meghajtóra, hogy kerülhetne bármi."
Ha mar van a gepen boot manager (windows kompatibilis), akkor abba koltozik be, nem pedig ujat keszit. (A Grub-ot persze nem szereti.
Bar lehet, jobb is ez igy.
krealon
#119800
"Szerettem volna hangosítani a mikrofonomon, ezért leszedtem az Equalizer Apo nevű programot. Nem tetszett az eredmény, ezért eltávolítottam arról a mikrofonról amit használok. De azóta halkabb, mint korábban volt. Ezzel mit lehet kezdeni?"
Peldaul Rendszervisszaallitas a telepites elotti allapotra.
"Egyébként más tipp hogy hangosabb legyen a mikrofonom? Kombinált jack csatlakozóval megy a gépbe, de hiába van a jelszint 100-on, az erősítés meg 30 dB-en, halk vagyok"
Pontos tipusokat irj.
Milyen gep, milyen csatlakozo, milyen hangkartya, milyen driver, milyen mikrofon es ha hasznalsz atalakito kabelt, akkor annak a pontos tipusa.Tipikus hiba a az OMPT (L-R-MIC-GND) es a AHJ (CTIA L-R-GND-MIC) 4 polusu jack csatlakozok keveredese.
krealon
vlevi
#119766
"Mert mi a legáltalánosabb Windows javítás? Indítsd újra a gépet.
Erre beletették azt a marhaságot, hogy ha ki is kapcsolod, akkor se kapcsoljon ki, gyűljön csak a sok szemét a memóriában, hogy aztán a következő kikapcsolásásnák is megmaradjon.
Cserébe mit nyerünk vele? Állítólag gyorsabb az indulás, de ez csak HDD-s gépeken mérhető, ellenben sokkal lassabb a leállítás, mert a memóriatartalmat ki kell írnia (mint egy hibernálásnál), a merevlemezre."Szemely szerint en sem kedvelem a gyorsinditast, de azt tapasztalom, hogy produkcios kornyezetben (ahol tipikusan egynel tobb biztonsagi szoftvert hasznalnak a gepen), jelentosen rovidebb a boot ido, mint gyorsinditas nelkul. (Shift + shutdown-nal szoktam a tartalek gepeket eltenni, es ezeknek az indulasa altalaban 1 perccel hosszabb. Lenovo T480, 8 GB RAM, SSD.)
krealon
FoLey-v
#119758
"Mindegy megjavult sokadik újraindítás után."
Akkor te is elkovetted a Windows ellenes fo bunt.
Hardver maceralas elott nem tiltottad a gyorsinditast (vagy vele egyenerteku hatasu muveletet). -
krealon
"Leállítottam start menüből rendesen a windows-t. Kihúztam a winyot és visszadugtam mindent úgy ahogy volt (még a kábeleket sem tudtam összecserélni mert minden sata kábel hátulról jön a winyók felett) és nem akart elindulni újra a régi rendszer."
Betartottad a Windows 10 hardver buzeralasi szentirast?
Legyen kikapcsolva a hibernalas, vagy
legyen kikapcsolva a gyorsinditas, vagy
Shift + Shutdown -nal legyen leallitva, hogy gyorsinditas nelkul aljon le, vagy
ujrainditaskor a BIOS/UEFI boot kozben legyen kikapcsolva. -
krealon
krealon
CirrMee
#117950
"Ha nem bíztam volna benne, meg sem próbáltam volna a két win10 alatt a cserét megejteni. A kettő közül az egyik már az első indításnál reccsent. A másik elindult szépen, ment is (volt is öröm, a másik kudarca után), tesztek is rendben futottak. Amikor jött egy restart, akkor dobta fel a bakancsot, a második indulásnál kb használhatatlan is lett."
Ez lett volna a lenyeg, hogy ki legyen fejtve a hardvercsere szempontjabol.
Az SSD+HDD kiszereles es a masik gepbe epites lepesei a fontosak.A hibernalas ki lett-e kapcsolva a taroloeszkozok kiszererelese eleott?
A SATA vezerlo at lett-e allitva Standard IDE modba?Mert a ket utobbi meg lett volna lepve, akkor siman tulelte volna a gepcseret a windows. (Tekintve, hogy AMD / Nvidia VGA valtas sem tortent.)
Az alapertelmezett gyorsinditas miatt, a windows szemszogebol, mukodes kozben cserelted ki a vasat. Erre a jelenlegi renszerek nincsenek felkeszulve.Szoval a Windows-nak felroni a felhasznalo tajekozatlansagat / figyelmetlenseget, nem sportszeru.
krealon
CirrMee
#117929
"a két, amúgy hibátlanul üzemelő családi gép azért sz*r, mert egy (szám szerint kettő) óperenciás rendszer szétcsúszott hardver csere miatt (i7 2600k -> Ryzen 2600X / i5 750 -> i7 2600k)?"
Ennek a tortenetet peldaul leirhatnad elrettento peldanak. (Reszletes konfiguracioval es lepes-listaval.)
krealon
adika4444
#117360
"Ha BitLocker-rel bevédem a C (rendszerpartíció) és a D (adatparti) meghajtómat, a Windows telepítő emlékeim szerint a grafikus felületen nem indítható el.
Ha megadná magát a Win, mi a legegyszerűbb újrarakási mód adatvesztés nélkül?"Ha nem mentetted el a titkosito kulcsot (nem hasznaltal microsoft account-ot), akkor a Bitlockerrrel titkositott adataidnak bucsut inthetsz.
"Diskpart-tal gyalulni mindent kivéve a datát?"
Ha nincs meg a kulcsod, akkor mindent gyalulhatsz.
"A BL okoz gyakorlati sebességvesztést?"
i5 vagy modernebb (dedikalt AES modullal rendelkezo processzornal) nem okoz eszreveheto lassulast.
krealon
A Tarolovezerlo alatt mi van?
A chipset driver felkerult?
krealon
"arra mi lehet a magyarázat, hogy az energiagazdálkodási lehetőségek beállításai ilyen szegényesek nálam: [kép]
Eleve csak kiegyensúlyozott mód van, se energiatakarékos, se teljesítménycentrikus.
A gép egy DELL Precision 5530 noti, WIN 10 Pro (1909), minden eszköz telepítve, driverek a legfrissebbek."Mutsd az eszkozkezelot!
krealon
svgyula
#116579
"Nálam amikor beraktam az SSD-t amire újratelepítettem a rendszert a 2TB! lemezt tiltotta a win."
Uj telepites, uj SID (system identification number).
Nincs azon semmi meglepo, ha egy uj felhasznalo (mas azonositoval rendelkezo) nem kap hozzaferest egy korbbi felhasznalo fajljaihoz, hiszen egy tobbfelhasznalos rendszerrol van szo.
Ha nem kizarolagos felhasnalasra szanjuk a fajlokat, akkor csoprtoknak is lehet jogot adni, igy csak a megfelelo csooporttagsagra van szukseg a jogok megszerzesehez.
"Ja és természetesen az egész meghajtót/particiót nem engedte
csak egyenként a könyvtárakat
Azt hittem onnét megyek nyugdíjba mert ugye az adatok meg kellettek.
"Parancssoros eszkozokkel (takeown, cacls) lehetseges a jogok allitasa melysegben is.
krealon
"Ubuntu 18.04. Win10. Dual boot."
Alapvetes, hogy ilyenkor a hibernalas vagy a gyorsinditas legyen kikapcsolva.
Remelem ez nalad is igy van.
A hibak 99%-a, a gyorsinditasra vezetheto vissza, dualboot rendszereknel. A windows 10 "nem szeret" osztozkodni a hardveren massal."Ha a winnel dolgozom pár órát, akkor elkezdi a könyvtárakat, fájlokat sőt az egész merevlemez tulajdonosi jogát átírni."
Na erre lennek kivancsi.
Win inditaskor listazd ki a jogokat, majd a leallitas elott is.
Ha ezek kulonboznek, akkor elfogadom az allitasodat."Mikor elindítom az Ubuntu-t amit 95% ban használok, nem tudok írni, törölni a merevlemezeken, mert nem én vagyok a tulajdonos.
Ilyenkor vissza kell állítanom az összes fájlon, könyvtáron a tulajdonosi jogokat a windows-ban, hogy ismét használhassam linux alatt a merevlemezeket."Ha rendesen van beallitva az NTFS jog es a megfelelo felhasznalo azonositoval van mount-olva az ubuntuban a particio, akkor nem szabadna problemanak elofordulni.
Az, hogy atallitanod kell a tulajdonosi azonositot es csak igy tudsz muveleteket vegrehajtani, azt mutatja, hogy nincsenek a jogok jol beallitva. -
krealon
Darko_addict
#116121
"Ha most használom a BitLockert egy erős jelszó mellett, és később vásárolok a gépbe egy TPM-et (hogy egyszerűbb legyen a jelszókezelés), akkora újra kell csinálni az egészet?"
Nem kell ujra csinalni.
A TPM csak egy kulcs tarolo.
Ha rakeresel, hogy "bitlocker TPM repair motherboard replace", akkor megtalalod a modjat. -
krealon
fecaga21
#116109
"A HP laptomon volt egy Windows 10 Enterprise"
Hova tunt?
"és most nem tudom ugyanazt visszatenni"
Fordulj a ceged rendszergazdajahoz.
"abban sok jó dolog volt amit nem találtam mostanában. Pl az akksi ikonra ha rákattintottam tudtam állítani a fényerőn 0, 25-75 illetve 100 %-ra, most ez sincs."
A HP-tol letoltotted a gyari kiegeszito szoftvereket? A Lenovo-nal Hotkey Features-nek hivjak a speci gombokhoz rendelt funkciokat.
Az Enterprise verzio "otthoni" megfeleloje a Professonal.
OEM Professional szukseges az Enterprise ceges hasznalatahoz.
A ACPI tablaba a Professional aktivalo kodjat egetik be, az ilyen, cegeknek, Windows-zal arult gepeken. -
krealon
access_denied
#115851
Microsoft apps are blurry? Here’s how to fix them
https://windowsreport.com/microsoft-apps-blurry/ -
krealon
access_denied
#115824
"A monitor tű éles képet ad minden alkalmazásnál, egyedül az Outlook az ami full homályos betűket produkál."
A "problema" oka, hogy nem 100%-os nagyitasban hasznalod a desktop-ot.
Win7-ig pontmatrixos magjelenites volt, az ujabb rendszerek nagyfelbontasu kijelzoin ez mar nem jarhato ut.A kompatibilitas megorzese miatt, a Windows 10 a nagyfelbontasu kijelzokon a hagyomanyos alkamazasok kepet felnagyitja, igy az alkalazas altal kirajzolt pixelek nem fognak egybeesni a kijelzo pixeleivel (atlognak a kornyezokbe), ezert lesz elmosodott a felnagyitott kep.
krealon
T0mBd1gg3R
#115821
" egyszer csak úgy dönt a start menü, hogy nem akar működni. Hiába kattintok rá, hiába nyomom meg a Windows gombot, nem csinál semmit. Programot indítani tudok a keresés gombbal vagy az asztalról, leállítani a gépet alt+f4-gyel, újraindítás után hibátlan. Van hogy magától meggyógyul, most pl működik de ebéd előtt nem működött, nem lett újraindítva."
"Nem csinal semmit" = "nem latom, hogy csinalna valmit".
Tipikusan az Explorer.exe var valamilyen halozati eroforras eleresere es ezert nem frissiti az ablakok es a start menu megjeleniteset.
Az egysegsugaru felhasznalo ezt hivja lefagyott allapotnak. Pedig nem az.Altalaban hosszadalmas kinyomozni, hogy konkretan mi okozza a problemat. Peldak
- Fajl elozmenyben halozati meghajtorol vagy megosztasbol megnyitott fajl, ami pillantnyilag nem elerheto.
- A korabban listazott gepek listaja nem elerheto
- Aktiv preview (betekinto) panel -
krealon
MegalodonS
#113984
"A rendszerem ,anno 2 particio volt.A Win 10 nem engedte a telepitest, igy ujaformazva,uj egesz particiora lett telepitve."
Ujratelepiteskor uj SID (System IDentification) jon letre es igy a regiek ervenytelenne valnak.
Azokon az NTFS meghajtokon, amik az ujratelepites utan nem lettek formazva, megmaradnak a regi SID-hez tartozo jogok, de az ujakhoz nem jon letre engedely.
Ha ezeket a jog-hozzarendeleseket rendbeteszed, megszunnek a problemak.
krealon
"HP laptop, windows 10.
Valamiért ha fut a rendszer akkor nem hajlandó tölteni az akkumulátort, hiába van bedugva a töltő. Ha kikapcsolom, vagy összecsukom és elmegy alvóba akkor tölti mert ha újra bekapcsolom akkor felmegy a töltöttség, de akkor megint azt írja, hogy akkumulátor üzem van.
A töltés jelző led szépen világít is az oldalán.
Tehát csak akkor nem tölt amikor fut a rendszer."Ha USB Type-C-s toltod van, akkor irany a szerviz.
En egy Lenovo T480-as szerianal futottam bele ebbe az esetbe.
Ha a hiba elofordulasa elott sikerul Thunderbolt firmware-t es szoftvert frissiteni, akkor nem jelentkezik a problema.
A tunetek megjelenese utan, alaplap cserevel javithato.Ha lenne Type-C dokkolod, akkor annak a hasznalata is lehetetlenne valik ennel a hibanal.
krealon
Piftuka
#112853
"Van a gépemre telepítve vírusirtó, amely a maleware programokat is megfogja, valamint egy jó minőségű tűzfal szoftver."
Es ezt mind ki tudja kapcsolni egy admin modban futtatott bongeszoben aktivalodott kartevo, ami az altalnosan hasznalt https protokol miatt a vedelmi programok segitsegevel nem szurheto.
Ellenben az UAC ezt a tamadast szepen meg is fogna.De Geth-nek igaza van, azt csinalsz a sajat gepeddel, amit akasz, csak ne hireszteld mint kovetendo peldat.
Vagy ha hireszteled, akkor a peldadat koveto szerencsetelnek vesztesegeit is vallald fel. -
krealon
Piftuka
#112833
"Solution 2: Disable User Account Control" --> "Never notify"
Miért rossz gyakorlat ez?Mert ez ahhoz hasonlo, mint amikor biztonsagi ov nelkul autozol vagy ejtoernyo nelkul ugrasz ki egy magasan szallo repulogepbol.
Nincs azonnali hatasa, de a becsapodaskor vege a dalnak.
krealon
Lauda
#112472
"Azt már csak úgy hozzáteszem, hogy gyakran a win7-nél sem távolítottam már el a külső vinyót, csak kihúztam. Azóta is minden adatom és lemezem köszöni szépen jól van."
A "worksforme" nem indok.
Remelem ezutan a kijelentes utan mindenkit kartalanitasz, akinek az USB eltavolitas nelkuli lecsatlakozasbol adatesztese lesz.
krealon
sas55
#112063
"másik gép ssd-jére telepítettem aztán azt kivetem a gépből de az enyémen maradt hogy kék képernyővel nyit és válasszak op rendszert."
Ez csak ugy tortenhetett meg, ha a sajat tarolod is a gepben maradt. (Szarvas hiba.)
A Windows 10 telepito ha talal a gepben egy boot manager-t, akkor abba feszkeli be magat es nem telepit az uj tarolora masikat.
Igy valoszinuleg az uj SSD-n nem fog boot-olni a rendszer, masik gepbe teve, tekintve hogy a rendszerindito resz a te winyodon maradt.
krealon
Doky586
#111996
"Win to Go (win10) USB meghajtón szeretném bekapcsolni a bitlockert a C: partíción.
Meglehet ezt csinálni?"Mivel nincs boot particiod, nem lehet megcsinalni.
A rendszerinditas csak kodolatlan teruletrol tortenhet, ezert is van kulon particion mar Windows 7 ota a boot, hogy a rendszerparticiot titkositani lehessen. -
krealon
AeSDé Team
#111781
"Van egy HP x360 1030 G3 notebook-om, amelyben van egy 256GB-os SSD. Az erre gyárilag telepített Windows 10 valamilyen csoda módon BitLocker-rel van letitkosítva, a gép beindításakor azonban mégsem kell megadnom semmilyen jelszót. Itt valamilyen hardveres kulcs szagot érzek."
A TPM-ben tarolodik a kulcs.
Ha van Microsoft fiokod (Skype, hotmail, OneDrive), akkor ott is eltarolodik a kulcs.
De legjobb ha feirod magadnak."Na most én szeretném lecserélni az említett SSD-t egy nagyobb, 512GB-osra. Ez esetben elég, ha valamilyen eszközzel (pl. Macrium Reflect, vagy dd
) egy image-et csinálok a régi SSD-ről, majd azt visszaállítom az újra"A dd masolat mukodik, de az uj drive-ot nem fogja automatikusan nyitni a TPM-ben tarolt kulcs.
A Reflect fajlrendszer szinten dolgozik, a Bitlocker nyitast nem tudja megoldani.A korrekt (biztosan mukodo) klonozas:
1,powercfg -h off(hibernalas kikapcsolasa, hogy a gyorsinditassal ne lehessen szetcseszni a fajlrendszert)
2, Bitlocker unlock
2a, Ha kisebb a celmeghajto, akkor csokkenteni a particionalt teruletet, hogy raferjen az uj eszkozre
3, Macrium WinPE-rol klonozas (Win10 19H2-tol a 7.2.valahanyas verzio hasznalata szukseges)
4, uj meghajto particionak novelese / athelyezese, ha szukseges
5, Bitlocker aktivalas az uj eszkozon
6,powercfg -h on -
krealon
mckay
#109599
"Mit használtam klónozni? Macrium Reflect-et. Azt szoktam.
Hogy ment a klónozás? Csiga lassan, 9 órán keresztül, gondoltam ilyen szar állapotban van a HDD."Ha a forras HDD CHS particionalt (63-as szektorban kezdodik az elso particio), akkor a 2048-es kezdocimu (advanced format) cel-particiora masolas valoban nagyon lassu tud lenni.
krealon
cigam
#108352
"- Kapcsold ki az SMB1-et a W10-ben.
- Intézőbe írd be a NAS nevét vagy IP címét ( \\NASneve )
- Mappold fel Z: meghajtónak, vagy a megosztásról készíts egy parancsikont az asztalra.
Így kikapcsolt SMB1-el is eléred. Nem tudom letesztelni, mert nincs smb1-es gépem."Onnan indult ki a tema, hogy egy elavult ZyXEL NSA320s NAS-t kellene elerni, ami csak SMB v1-et tud.
Igy a javaslatod sajnos hasztalan.
krealon
"Nem lehet egyszerűbben bekapcsolni a 8.3-as fájlnév kijelzést a meghajtón?"
TL;DR Nem.
Ez csak NTFS-en mukodik:
How to disable 8.3 file name creation on NTFS partitions
0 --> Enable
1 --> DisableA fajlnev alapjan nem Windows-on jott letre a fajl, igy a maghajto valoszinuleg FAT32 vagy exFAT rendszeru.
Universal USB Installer segitsegevel pofonegyszeru egy Linux Mint live-ot felpattintani egy USB pendrive-ra.
De az UNetbootin sem "agysebeszek" szamara keszult.
krealon
"A mappa neve: Pókember Idegenben, a benne lévő fájl neve:
Pókember: Idegenben.mkv
Törléskor ezt a hibaüzenetet kapom:
"Az elem nem található" "A kettospont nem megengedett fajlnev-elem Windows alatt.
A megoldas:
Paranccssor: [Win] -->cmd--> [Enter]
utana valtas a mappaba, ahol a hibas fajl van.cd /d
Ezutan kimasolod a Windows intezo ablak cimsorabol ( [F4] ) az eleresi utat ( [Ctrl] - C vagy jobbkatt masolas)
A parancs ablakon jobbkatt beillesztes. Ennek az eredmenye ilyesmi lesz:cd /d Z:/mappa/masikmappa/Pokember Idegenben
[Enter]dir /xA kimenetben ilyesmi lesz:
08/22/2018 08:25 PM 776,152,788 POKEMB~1.MKV Pókember: Idegenben.mkv
ebben a sorban aPOKEMB~1.MKV
a dos 8.3 kompatibilis fajlnev.
Ennek segitsegevel le lehet torolni a fajlt.del POKEMB~1.MKVHa a hibas nevu fajl letorlesre kerult, akkor utana a mappat is lehet mar torolni. Persze a parancsablak bezarasa utan, mivel ott benne allunk a mappaban, vagyis hasznaljuk, es amig hasznaljuk, nem torolhetjuk.
Szerk:
Jaj. Most latom csak, hogy a 8.3 kompatibilis fajlnev ki van kapcsolva a meghajton...
Akkor peldaul pendrive-rol bootolj be egy live-Linux-ot, es azzal torold. -
krealon
cigam
#108189
" újraindítást választottam, mert pendrive-ról akartam indítani a lemezkép visszatöltő programot."
Az a baj, hogy meg a lemezkep keszitese elott kellett volna eljatszani az ujrainditas / levalasztas kort.
A lemezkepben benne van a hibernacios fajl is. Ez okozza a problemat.
• OFF topik
• TILOS a warez!
- Hogwarts Legacy teszt
- Katasztrofális PC-piacra figyelmeztet az IDC
- Crimson Desert
- Tovább tarthat a memóriakrízis, mint gondolnánk
- Tőzsde és gazdaság
- Az Intel szerint mindenkit érint, illetve érinteni fog a CPU-hiány
- ThinkPad T14s Gen 2 i5-1135G7 16GB 512GB FHD 1 év garancia
- Apple iPhone 13 128 GB Midnight 100% Akkumulátor 1 év Garancia Beszámítás Házhozszállítás
- AKCIÓ! Acer Predator Helios Neo 16 PHN16 notebook-i9 13900HX 16GB DDR5 1TB SSD RTX 4060 8GB W11
- iKing.hu Apple iPhone 14 Pro Silver 128GB használt szép állapot 95% akku 6 hónap garancia
- HP Thunderbolt 4 kábel
