WordPress tartalom kezelő rendszer (CMS) topik
aujjobba
Nem tudom betolteni az admin oldalt, elszall hibaval.
Talalkoztatok mar ilyennel?172.68.50.12 - - [05/Apr/2022:07:08:54 +0000] "GET / HTTP/1.1" 200 9088 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15"172.68.50.226 - - [05/Apr/2022:07:08:54 +0000] "GET /wp-content/themes/resumee/style.css?ver=5.9.2 HTTP/1.1" 200 13039 "https://example-website.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15"172.68.50.138 - - [05/Apr/2022:07:08:54 +0000] "GET /wp-content/plugins/resume-builder/dist/main.css?ver=3.1.1 HTTP/1.1" 200 7464 "https://example-website.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15"172.68.50.12 - - [05/Apr/2022:07:08:55 +0000] "GET / HTTP/1.1" 200 9075 "https://example-website.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15"[Tue Apr 05 07:09:03.004259 2022] [php7:error] [pid 22] [client 172.68.50.80:0] PHP Fatal error: Uncaught Error: Call to undefined function get_current_screen() in /var/www/html/wp-includes/script-loader.php:2356\nStack trace:\n#0 /var/www/html/wp-includes/class-wp-hook.php(307): wp_global_styles_render_svg_filters('')\n#1 /var/www/html/wp-includes/class-wp-hook.php(331): WP_Hook->apply_filters(NULL, Array)\n#2 /var/www/html/wp-includes/plugin.php(474): WP_Hook->do_action(Array)\n#3 /var/www/html/wp-includes/general-template.php(3074): do_action('wp_body_open')\n#4 /var/www/html/wp-content/themes/resumee/functions.php(297): wp_body_open()\n#5 /var/www/html/wp-settings.php(555): include('/var/www/html/w...')\n#6 /var/www/html/wp-config.php(133): require_once('/var/www/html/w...')\n#7 /var/www/html/wp-load.php(50): require_once('/var/www/html/w...')\n#8 /var/www/html/wp-admin/admin.php(34): require_once('/var/www/html/w...')\n#9 /var/www/html/wp-admin/edit.php(10): require_once('/var/www/html/w...')\n#10 {main}\n thrown in /var/www/html/wp-includes/script-loader.php on line 2356172.68.50.80 - - [05/Apr/2022:07:09:02 +0000] "GET /wp-admin/edit.php?post_type=page HTTP/1.1" 500 3137 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15"NGINX proxy mogott van a cucc, ebben a konfigban lenne valami gond?
server {client_max_body_size 500M;root /var/www/html;index index.html index.htm index.nginx-debian.html;server_name example-website.com;listen [::]:443 ssl ipv6only=on; # managed by Certbotlisten 443 ssl; # managed by Certbotssl_certificate /etc/nginx/ssl/fullchain.pem; # managed by Certbotssl_certificate_key /etc/nginx/ssl/privkey.pem; # managed by Certbotinclude /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbotssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbotssl_client_certificate /etc/ssl/certs/cloudflare-client.crt;ssl_verify_client on;gzip on;gzip_vary on;gzip_min_length 1000;gzip_proxied any;gzip_types text/plain text/css text/xml application/xml text/javascript application/x-javascript image/svg+xml;gzip_disable "MSIE [1-6]\.";proxy_set_header Host $host;proxy_set_header X-Real-IP $remote_addr;proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;proxy_set_header X-Forwarded-Proto $scheme;proxy_set_header Sec-WebSocket-Extensions $http_sec_websocket_extensions;proxy_set_header Sec-WebSocket-Key $http_sec_websocket_key;proxy_set_header Sec-WebSocket-Version $http_sec_websocket_version;# Websocketsproxy_http_version 1.1;proxy_set_header Upgrade $http_upgrade;proxy_set_header Connection "Upgrade";# Buffering off send to the client as soon as the data is received from Plex.proxy_redirect off;proxy_buffering off;location / {try_files $uri @apache;}location ~ ^/\.user\.ini {deny all;}location ~* \.(svg|svgz)$ {types {}default_type image/svg+xml;}location = /favicon.ico {log_not_found off;access_log off;}location = /robots.txt {allow all;log_not_found off;access_log off;}location @apache {proxy_set_header X-Real-IP $remote_addr;proxy_set_header X-Forwarded-For $remote_addr;proxy_set_header X-Forwarded-Proto $scheme;proxy_set_header Host $host;proxy_pass http://127.0.0.1:90;}location ~[^?]*/$ {proxy_set_header X-Real-IP $remote_addr;proxy_set_header X-Forwarded-For $remote_addr;proxy_set_header X-Forwarded-Proto $scheme;proxy_set_header Host $host;proxy_pass http://127.0.0.1:90;}location ~ \.php$ {proxy_set_header X-Real-IP $remote_addr;proxy_set_header X-Forwarded-For $remote_addr;proxy_set_header X-Forwarded-Proto $scheme;proxy_set_header Host $host;proxy_pass http://127.0.0.1:90;}location ~/\. {deny all;access_log off;log_not_found off;}} -
aujjobba
CharlieDrop
#7675
Köszi, a Resume Builder pluginnal és a Resumee sablonnal sikerült összehozni.
aujjobba
CV oldalhoz milyen sablon ajánlott?
Lehet olyat, hogy összekattintgatom az adott szakaszokat vizuálisan, pl előző munkahelyek, tapasztalatok, iskolák, stb?
- Xiaomi Redmi Note 12S 256GB, Kártyafüggetlen, 1 Év Garanciával
- AKCIÓ! LENOVO ThinkPad P15s Gen2 munkaállomás - i7 1165G7 16GB DDR4 512GB SSD Quadro T500 4GB W
- iKing.Hu - Apple iPhone 13 Pro Alpine Green ProMotion 120 Hz, Pro kamerák 128 GB-100%
- HIBÁTLAN iPhone 15 Pro 128GB Natural Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS4538
