OpenWrt topic
ssgabee
vargalex
#1406
Kívülről elérhető, amit akarok, viszont a router mögül, ha a publikus ip cím alapján próbálom, akkor időtúllépéssel elszáll. A config pedig a következő:
root@OpenWrt:~# cat /etc/config/firewallconfig defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option drop_invalid '1'config zone
option name 'lan'
option network 'lan'
option forward 'REJECT'config zone
option name 'wan'
option network 'wan'
option input 'REJECT'
option masq '1'
option mtu_fix '1'config forwarding
option src 'lan'
option dest 'wan'config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
option target 'ACCEPT'config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
option target 'ACCEPT'config include
option path '/etc/firewall.user'config redirect
option target 'DNAT'
option src 'wan'
option dest 'lan'
option proto 'tcp'
option src_dport '5959'
option dest_ip '192.168.2.100'
option dest_port '5900'
option name 'VNC'config redirect
option src 'wan'
option dest 'lan'
option proto 'tcp udp'
option src_dport '5858'
option dest_port '5800'
option name 'VNC Web'config redirect
option src 'wan'
option dest 'lan'
option src_dport '8080'
option dest_ip '192.168.2.1'
option dest_port '80'
option name 'Router web'config redirect
option src 'wan'
option dest 'lan'
option src_dport '2222'
option dest_port '22'
option name 'Router ssh'Gábor
ssgabee
vargalex
#1394
Jók voltak a beállítások, amiket beállítottam.
Havernak minden gond nélkül sikerült elérnie a VNC-t és a router web-es felületét. Csak ezeket próbáltuk és működött. Nem port forward hiba hiba volt.
Nálam nem tudom, hogy mi lehet a gond, miért nem érem el ezeket a szolgáltatásokat?
Van egy publikus ip címem. Ami erre a ip-re érkezik egy DMZ-be továbbít a szolgáltató. Ezt a private ip-t a router-nek beállítottam és kész.
Kifelé viszont egy másik publikus ip-n látszódok, amin mindenki más is a szolgáltatónál.
A dolog érdekessége, hogy tp-link firmware-rel a router mögül elértem őket, most pedig amikor tesztelni akartam, hogy működik-e, openwrt-vel már nem értem el. Vagyis most nem érem el a router(openwrt) mögül azt, amit router(tp-link firmware) mögül elértem. Milyen beállítás kéne hozzá?Gábor
ssgabee
Most szántam el magam, hogy egy tl-wr841nd-re openwrt-t rakjak. Firmware csere gond nélkül lezajlott. A problémám ott kezdődik, hogy lan-ról elérem a nekem szükséges funkciót(értem ezalatt, ssh, webui, pingre válaszol). Ha a wan felől próbálom, akkor timeout mindenre(ssh, webui), wol csomagok nem érkeznek a gépre, pingre nem válaszol a router, vnc port fw-t sem megy. Port fw-ot hiába állítom be, nem teszi a dolgát.
Arra gyanakodtam, hogy nem érkeznek meg az ip csomagok a routerre. Ez kizárható, mivel a routert kihagyva közvetlen a gépre kötve az "internet"-et megérkeznek a csomagok.
Gyári firmware-rel működtek ezek a dolgok. Merre keresem a hibát? Mit csinálok rosszul?Köszönöm.
- Bambu Lab 3D nyomtatók
- Viber: ingyen telefonálás a mobilodon
- Milyen monitort vegyek?
- Elektromos autók - motorok
- Parfüm topik
- mefistofeles: Az elhízás nem akaratgyengeség 3. Végszó.
- Akció! HP ZBook Firefly 14 i7-1165G7 16GB 512GB Nvidia Quadro T500 4GB 14" FHD 1 év garancia
- MEGA Akció! Számla + garancia! Apple Macbook Pro 14 - Apple M3 Pro Chip!
- Xiaomi Watch S4,Újszerű,Dobozaval,12 hónap garanciával
- Ddr5 Laptop Ram 32 gb 2x16gb 5600Mt/s
- 5G Lenovo ThinkPad P14s Gen 3 Intel Core i7-1280P Nvidia T550 32GB 1000GB 1 év teljeskörű garancia
