SirL
Szia ! Nekem ezek az eredmenyek jottek ki :
12233 pont GF4 TI4200 128MB 315per604 1024x768 Turbo memoria 13x158proci
Itt vannak a fontosabb adatok....
3DMARK2001 PROJECT FILE
DISPLAY
Platform NVIDIA GeForce4 Ti 4200 with AGP8X
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate Default
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 12233
Game 1 - Car Chase - Low Detail 175.5 fps
Game 1 - Car Chase - High Detail 61.8 fps
Game 2 - Dragothic - Low Detail 225.6 fps
Game 2 - Dragothic - High Detail 123.6 fps
Game 3 - Lobby - Low Detail 155.3 fps
Game 3 - Lobby - High Detail 71.4 fps
Game 4 - Nature 76.7 fps
Fill Rate (Single-Texturing) 1056.7 MTexels/s
Fill Rate (Multi-Texturing) 2395.8 MTexels/s
High Polygon Count (1 Light) 57.1 MTriangles/s
High Polygon Count (8 Lights) 12.8 MTriangles/s
Environment Bump Mapping 84.6 fps
DOT3 Bump Mapping 151.5 fps
Vertex Shader 102.8 fps
Pixel Shader 128.6 fps
Advanced Pixel Shader 98.8 fps
Point Sprites 30.9 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Duron(tm)
Internal Clock 2.01 GHz
Internal Clock Maximum 2.01 GHz
External Clock 158 MHz
Socket Designation Socket A
Type <unknown>
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version Unknown CPU Type
CPUID 0x00000681
CACHES
Level 1
Capacity 128 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type External
DIRECTX INFO
DirectX Version 8.2
DIRECTDRAW INFO
DirectDraw Version 4.08.01.0881
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA GeForce4 Ti 4200 with AGP8X
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 64 MB
Display Driver nvdisp.drv
Display Driver Version 4.14.01.4201
Driver WHQL Certified No
Max Texture Width 4096
Max Texture Height 4096
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 4
Vertex Shader Version 1.1
Pixel Shader Version 1.3
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0281
Sub-System ID 0x2931107d
Revision 0xa1
DIRECTSHOW INFO
DirectShow Version 6.03.01.0400
MEMORY INFO
Total Physical Memory 256 MB
Free Physical Memory 134.89 MB
Total Pagefile Memory 1.75 GB
Free Pagefile Memory 1.71 GB
MEMORY ARRAYS
Max Module Capacity 768 MB
Location System Board
Use System
Supported Error D&C None
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 256 MB
Form Factor DIMM
Frequency 0 Hz
Slot A0 [Bank0/1]
Manufacturer
Type <unknown>
Type Details <unknown>
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer http://www.abit.com.tw/
Model KD7 (KT400-8235)
Version 1.x
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Release Date 08/12/2002
BIOS Properties Plug and Play, Flash, AGP
Number 0
Designation AGP
Type AGP
Characteristics 5.0V
Data Bus Width 32
Details In Use, Long
Device Class Display Adapter
Device Name NVIDIA GeForce4 Ti 4200 with AGP8X
Device Manufacturer NVIDIA
Device Driver Date 12-11-2002
Device Vendor ID 0x10de
Device ID 0x0281
Device Sub-System ID 0x2931107d
Device Revision 0xa1
IRQ 11
Revision 3.5
Rate 4x, 8x (2x enabled)
Aperture Size 64 MB
Sideband Addressing supported (enabled)
Fast Write not supported
OPERATING SYSTEM INFO
Operating System Microsoft Windows 98
Version 4.10.1998
Service Pack
Locale HU
Desktop Width 1280
Desktop Height 1024
Desktop BPP 32
Udv: SirL -
SirL
Sziasztok !
Istencsaszar ez a 2100+ os XP proci.
Az alap 13x133@1.6v at sikerult mar felvinnem 13x162@1.7v - ra, azaz 2106MHZ-re. Igy mar a PIV 2.66GH esnek felel meg lassan. (SiSoft Sandra 2003 szerint ALU-7939 es az FPU-3180 pontot ment).
Udv mindenkinek !
SirL -
SirL
Szia !
Valoszinuleg azert is alacsonyabb a homerseklete a procinak mert uj maggal szerelt (Tberd A-s vagy B-s. Valszeg B-s.). Ennek a procinak alapbol 39c volt a homerseklete ezzel a hutovel tuning nelkul. Akkor ment le 33-36c koze amikor meg 2db 8cm -es haz huto ventillatorral rasegitettem a haz hutesere (Igy mar 3db volt a gepben). Volt nallam nemreg egy 1700+ -os proci. Az a regi palomino maggal volt szerelve. Ugyanebben a kornyezetben (Abit KD7-Raid rez procihuto) annak a homerseklete mindenfele tuning nelkul, terheletlenul 44c volt ! A huto tipusat nem tudom. Ha erdekel utannanezek.
Tovabba sokat jelent a hogy a haz az nem zart.
Udv -
SirL
Sziasztok !
Most vettem egy XP2100+ os procit (Tbred magos. Viszont meg nem tudom hogy A-s vagy B-s. Valoszinuleg B-s. A proci sarkaban levo szam a nyil mellet azthiszem 27293). Meg probalgatom a vegso hatarait, hogy mit bir. Ugy nez ki szorzozarmentes. Alapbol 13x133@1.6v-on megy (1733valos MHZ). Eddig kiprobaltam 13.5 es 14x szorzoval is. Ezeken is ment. Max amit eddig meg be sikerult nekem allitanom ugy hogy ment es lefutott vele a 3DMARK 2001 SE az 13x154@1.65 azaz 2002valos MHZ = Tesztekbe (sisoft sandra) igy egy 2400+ procinak felelt meg. Alapesetben az abit (KD7-Raid) alaplapom 1.6v feszultseget ad neki (regi biosz van benne valoszinuleg frissitenem kellene). Eddig max 1.675 ig mertem felemelni. Nem tudtam mennyi az a max feszultseg amitol meg nem karosodik (Latom itt joparotok 1.85v-ig is elmegy, ugyhogy valoszinuleg tovabb fogom akkor az 1.675v-ot engedni). Meg valoszinuleg van meg tartalek a prociban. Alap orajelen a procihomerseklet (nyitott haz eseten nem terhelt allapotban) 33-36fok (rez hutoborda van rajta). Tulhajtva (13x154@1.675v) a homerseklete 39fok terheletlenul. Egy 8perces 3DMARK 2001 SE lefuttatasa utan 41 fok a homerseklete.
Udv nektek !
