GAMEPOD témák
Keresés
Topikgazdák
Téma tudnivalók
● Tilos a warez!
- Bomba ár! Dell Latitude E7450 - i7-5GEN I 8GB I 256SSD I 14" FHD Touch I HDMI I Cam I W10 I Gari!
- Corsair Vengeance White RGB 2x16Gb 6000 cl36 bontatlan/új eladó (XMP/Expo)
- Dell Latitude 7290- I5 7 gen - 8Gb -256Gb
- Nikon D750 + 50mm f/1.4G + 24-120mm f/4G + Lowepro Mini Trekker AW szett
- GAMER PC - TUF B450, Ryzen5 5600x, Rtx 3070 8gb, 32gb DDR4, 1 TB Nvme
crok
mobilizmo
