Keresés
  • nukeleo
    Ittlenne a kódom: nem tudom miert csak egy sort olvas be a forrásfájlbol, a bufferba? Segitsetek, lehet a beolvas függvényem nem jo, vagy a buff tárolo, nem tudom...
    /*csomo felesleg is van most benne amit nem használtam még, tekintsetek el töle*/
    THX nagyon elöre is; nukeleo
    #include <cstring>
    #include <iostream>
    #include <fstream>
    using namespace std;
    class buffer {
    char* buff;
    int size;
    public:
    buffer():buff(0),size(0){}
    buffer(const buffer&);
    buffer& operator=(const buffer&);
    buffer& operator+=(const buffer&);
    bool operator==(const buffer&);
    buffer& buffer:: operator=(const char*);
    buffer& buffer:: operator+=( const char*);
    bool buffer:: operator==(const char*);
    friend void beolvas(buffer &);
    friend void kiir(buffer &);
    //void beolvas(const char*);
    friend ostream& operator<<(ostream& s, const buffer b);
    friend istream& operator>>(istream& s, const buffer b);
    ~buffer(){ delete[] buff; }
    /*void beolvas(const char* file)
    fstream fp(file,ios::in);
    char *c = new char[500];
    fp.close();
    fp>>c;
    cout<<c;
    buffer::buffer(const buffer& e)
    buff=new char[(size=e.size)+1];
    if (e.buff)
    strcpy(buff,e.buff);
    buffer& buffer:: operator+=( const char* value)
    char* temp=new char[size = strlen(buff)+ strlen(value) +1];
    strcpy(temp,buff);
    strcat(temp, value);
    delete[] buff;
    buff = temp;
    return *this;
    buffer& buffer:: operator+=(const buffer& e)
    char* temp=new char[size+=(e.size+1)];
    strcpy(temp,buff);
    strcat(temp,e.buff);
    delete[] buff;
    buff=temp;
    return *this;
    buffer& buffer:: operator=(const char* value)
    delete[] buff;
    if( size=strlen(value))
    buff=new char[size+1];
    strcpy(buff,value);
    return *this;
    buffer& buffer:: operator=(const buffer& e)
    if( this!= &e)
    delete[] buff;
    buff=new char[size=e.size];
    return *this;
    bool buffer:: operator==(const char* value)
    if(size==strlen(value)) return true;
    else return false;
    bool buffer:: operator==(const buffer& e)
    if(size==e.size) return true;
    else return false;
    //for(int i=0;i<b.size;++i)
    if(b.size)
    s<<b.buff;
    return (s);
    int karakterek_szama()
    fstream fp(''adat.txt'' ,ios::in);
    char d;
    int k=0;
    while(!fp.eof())
    fp.get(d);
    ++k;
    fp.close();
    return k;
    istream& operator>>(istream& s, buffer b)
    int k=karakterek_szama();
    delete[] b.buff;
    b.buff=new char[(b.size=k)+1];
    s>>b.buff;
    return (s);
    void beolvas(buffer& b)
    delete[] b.buff;
    while(!fp.eof())
    fp.getline(b.buff,b.size);
    fp.close();
    cout<<k;
    void kiir(buffer& b)
    fstream fp(''adat2.txt'',ios::out);
    fp<<b.buff;
    fp.close();
    char menu ()
    char n;
    cout<<'' MENU \n\n'';
    cout<<''1: File beolvasás \n'';
    cout<<''2: Szöveg hozzáadása a fájlhoz \n'';
    cout<<''3: Aktualis buffer tartalma\n'';
    cout<<''4: Mentés\n'';
    cout<<''0: Exit \n'';
    cin>>n;
    return n;
    int main(){
    char m;
    buffer a;
    buffer b;
    char *c = new char[20];
    char *d = new char[500];
    while ((m = menu())!= '0')
    switch (m)
    case '1':
    beolvas(b);
    cin.get();
    cin.get();
    break;
    case '2':
    cin>>d;
    b+=d;
    break;
    case '3':
    cout<<b;
    cin.get();
    cin.get();
    break;
    case '4':
    kiir(b);
    break;
    system (''CLS'');
  • nukeleo
    A kérdésem az lenne, hogy itt van ez a beolvas függvény:
    delete[] b.buff;
    fstream fp(''adat.txt'',ios::in);
    while(!fp.eof())
    fp.close();
    Hogy kellene módosítani ezt(vagy lehet mást is ajánlani), hogy paraméterként elötte lehetne a fájl nevét bekérdezni, és azt a fájlt
    nyitná meg utána????
    köszi a válaszokat.
  • nukeleo
    Bocs az elözző üzenetemért, csak nagyon kész vagyok ,mert holnapra kell leadnom a házimat,és ilyenkor szoktam hülyeségeket beszélni!
    Az utlsó elötti üzenetemben mar irtam mit szeretnék, de most akkor konkrétabban leírom:
    Azt szeretném megcsinálni, hogy egy beolvasott fileban (szöveges) lekérdezni hány sor van, és tudjak beszurni / törölni sorokat a megadott sorba!
    Azt az utasítast kaptam hogy : operator[] (indexelő operatort ) használatával!
    Ha tudtok vmi függvénnyel segíteni, vagy mar kész progit mutatni, köszönöm!
  • nukeleo
    hali
    Azt szeretném , hogy mielott kiirom a fileba az adatokat, törölje ki az adat2.txt -bol ami benne van_???
    Hogy lehetne?
    fp<<b.buff;
    fp.close();
    THX
  • nukeleo
    Sürgős segiítség kellene C++-ban:
    az a feladatom , hogy egy beolvasott fileban (szöveges) nézzem meg hány sor van, és tudjak beszurni / törölni sorokat a megadott sorba !
    Valamint a fájlban tudjak keresni egy megadott szot, és kiirja hogy hanyadik sorban van a keresett szo!
    Azt az utasítast kaptam hogy operator[] (indexelő operatort ) használjak!
    Aztán még , két txt fájlt tartalmát kiirni egy harmadik fájlba!
    ugy hogy használjak egy buffert is!
    nagyon köszönöm a válaszokat
