Debian GNU/Linux
petersonal
Üdv nagy linux mesterek!
Adjatok tanácsot nekem egyszerű usernek.
Két kérdésem lenne. Spec: Ubuntu server, transmission daemon + web ui. A tr daemon nem fér hozzá a fájlrendszerhez, permission denied, amikor már az others csoportnak is adtam minden jogot a mappához amihez hozzá szeretne férni. Mit nézek be?
Második kérdés: A web ui gyakran elszáll, connection failed-el. Miért?
settings.json:{
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/srv/raid/torrent",
"download-limit": 100,
"download-limit-enabled": 0,
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/srv/raid/torrent",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 1,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 1,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{asdasdasdasdasdsd",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "transmission",
"rpc-whitelist": "127.0.0.1,192.168.0.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 2,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
- Milyen autót vegyek?
- Diablo IV
- Eredeti játékok OFF topik
- Hogyan verte le egy telefon chip az egész laptop ipart? – x86 vs ARM
- Bomba ár! HP EliteBook 840 G9 - i7-1270P I 16GB I 512SSD I 14,1" WUXGA I Cam I W11 I Gar!
- Laptop felvásárlás , egy darab, több darab, új , használt ! Korrekt áron !
- Xiaomi Mi 11i 256GB, Kártyafüggetlen, 1 Év Garanciával
- LG 27UP650K-W - IPS LED - 3840x2160 4K - 60Hz 5ms - DisplayHDR 400 - AMD FreeSync
- Infinix Hot 11s / 4/128GB / Kártyafüggetlen / 12Hó Garancia
