harley
valaki esetleg,talán?
harley
mit jelent az hogy "hardware TnL" ?
harley
harley
harley
egyszerűen nem értem.
harley
System Information
Time of this report: 10/1/2008, 18:47:59
Machine name: HARLEY
Operating System: Windows XP Professional (5.1, Build 2600) Szervizcsomag 3 (2600.xpsp.080413-2111)
Language: Hungarian (Regional Setting: Hungarian)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq nx7400 (EY508ES#AKD)
BIOS: KBC Version 40.16
Processor: Genuine Intel(R) CPU T2250 @ 1.73GHz (2 CPUs)
Memory: 2040MB RAM
Page File: 945MB used, 2985MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode------------
DxDiag Notes
DirectX Files Tab: The file directx.cpl is a debug version, which will run slower than the retail version.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.--------------------
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)---------------
Display Devices
Card name: Mobile Intel(R) 945 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 950
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_27A2&SUBSYS_30A2103C&REV_03
Display Memory: 224.0 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Plug and Play monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4926 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/15/2008 21:12:06, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 2/15/2008 21:12:06, 5854752 bytes
Device Identifier: {D7B78E66-64E2-11CF-B260-A810A2C2CB35}
Vendor ID: 0x8086
Device ID: 0x27A2
SubSys ID: 0x30A2103C
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run -
harley
ezt írja:
System Requirements
-------------------Operating Systems: Windows 98SE, ME, 2000 or XP required.
Computer: 100% DirectX compatible computer required.
CPU: Pentium III 733 MHz or faster CPU required.
Pentium III 1GHz or faster CPU recommended.Memory: 128 MB RAM required. 256 MB RAM recommended.
Graphics Card: 32 MB Transform and Lighting (TnL) capable
graphics card required. 64 MB Vertex and Pixel Shader (VnPS)
capable card recommendedSound Card: PCI, USB, or Onboard Audio Device required.
CD-ROM: Quad Speed CD-ROM drive required.
Input Device: Keyboard and mouse required. 8+ Button Gamepad
supported.DirectX: Microsoft DirectX 8.1b is included on this CD. You
will be prompted to install DirectX during installation of
this game if a more recent version isn’t already properly
installed on your system.NOTE: DirectX may require the "latest" updates for your
operating system. This may also include the latest drivers
for your particular motherboard, sound and video hardware.telepítettem a drivert a directx-et de nem telepíti, mert azt írja legújabb van a gépen.
eddig nem volt ilyen gondom játékkal, csak a win98-as kiadásuakkal.
de ez 2003-as játék.elindítom, de azt írja telepítsem a directx-et meg a d3d-t
harley
harley
üdv
az a gondom, hogy az Indiana Jones játék nem indul el.
azt írja, hogy a D3D nem jó, és tegyek fel egy directX 8.1-et vagy újabbat.
de DX 9c van a gépen!!!most mit csináljak??
- Pedzegeti az új Xbox irányát a Microsoft
- Star Trek Online -=MMORPG=-
- Windows 10
- A természettel együtt ébredeznek a hardverek
- Airsoft
- PC Game Pass előfizetés
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7800X3D 32/64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- ÓRIÁSI AKCIÓK! GARANCIA, SZÁMLA - Windows 10 11, Office 2016 2019 2021,2024, vírusírtók, VPN
- Eladó Apple iPhone 12 64GB / 12 hó jótállás
- Honor 200 Pro 512GB, Kártyafüggetlen, 1 Év Garanciával
- Xiaomi 12T 128GB, Kártyafüggetlen, 1 Év Garanciával
