Diablo18
Diablo18
Diablo18
Diablo18
gondoltam fel teszem
mert nem láttam fent ESI topicotsajnos most a képfeltöltés nem elérhető majd pótlom a képeket
még saját véleményem nincs
a termékekről mert nem sikerült hozzá jutnom pont előttem vitték el a ph n fel lelhető 1 normális juli@ darabot
szóval véleményeket tapasztalatokat
kérnék
a termékekről
hátha van más is akit érdekelés van ilyenje
Diablo18
ESI Juli@:
Features
2 analog input channels, 2 analog output channels
24-bit/192kHz AD converter with 114dB(a) dynamic range
24-bit/192kHz DA converter with 112dB(a) dynamic range
swappable socket (Unbalanced RCA with -10dBv or Balanced TRS with +4dBu )
coaxial S/PDIF digital input
synchronisation to digital S/PDIF input signals
optical S/PDIF digital output with automatic shutter (max.96kHz)
coaxial S/PDIF digital output (max 192kHz)
1 MIDI input (16 channels) / 1 MIDI output (16 channels)
support for DirectWIRE 3.0
4 inputs and 4 outputs can be used with 24bit/192kHz simultaneously (incl. MIDI I/O) - full duplex
PCI card is compatible with 3.3V and 5V PCI slots
independent monitoring control for analog and digital input signals and playback
EWDM driver: MME, DirectSound, ASIO 2.0 and GSIF 2.0 support
Windows 98SE/ME/XP/2000/Vista/7 compatible
compatible with Mac OS X 10.1 and newer (Power Mac G4/G5)
Linux compatible (ALSA)MAYA44:
Supports up to 24-bit / 192kHz output and 96kHz input
4 analog input and 4 analog output channels
4-in / 4-out full duplex recording and playback
balanced microphone input with +48V phantom power
headphone output with gain control
unbalanced stereo line input (1~2) can be switched to balanced mono microphone input
optical and coaxial (S/PDIF) digital output
optional MIDI I/O via MI/ODI/O extension
optional S/PDIF digital input via MI/ODI/O ext.
3.3V / 5V compatible PCI card
Windows 7/Vista/XP/2000 and Mac OS X compatibleMAYA44 XTe:
24-bit / 96 kHz 102dB(a) A/D converter and 24-bit / 96 kHz 108dB(a) D/A converter
4 simultaneous input and 4 simultaneous output channels
microphone preamp with +48V phantom power
Hi-Z instrument input to directly input guitar signals
simultaneous full-duplex recording and playback
S/PDIF optical output, S/PDIF optical input
headphone output
PCIe x1 interface card, works in x1 and any other PCIe slot
full DirectWIRE support
low-latency EWDM driver: MME, WDM, DirectSound and ASIO 2.0 support, plus CoreAudio
compatible with Microsoft Windows XP, Vista 32-bit, Vista 64-bit, 7 32-bit, 7 64-bit and Mac OS X
bundled with Cubase LE 5 from Steinberg
- Samsung Galaxy Book PRO 2 /i7-1260P/16GB/512SSD/AMOLED/13.3/Intel Iris Xe/Gari
- Dell Vostro 3425 6magos Ryzen 5 5625U 8GB RAM 256GB SSD
- 227 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- Új MSI 15 Katana FHD IPS 144Hz i7-13620H 10mag 16GB DDR5 1TB SSD Nvidia RTX 4060 8GB Win11 Garancia
- Telefon felvásárlás!! iPhone 14/iPhone 14 Plus/iPhone 14 Pro/iPhone 14 Pro Max
