Kraptor
hbbalint
#101
Úgy simán sehogy, mert 65K a limit, de vannak okosságok amivel meglehet kerülni ezeket. Van egy progi amit Microsoft Office Spreadsheet 10.0 UserForm control-nak hívnak és ezzel elvileg létretudsz hozni 18,278 x 262,144-es lapokat.Ezt nem tudom, hogy mennyire igaz vagy nem.
Vagy vannak különböző makrók amikkel megtudsz nyitnyi nagyobb fileokat, csak akkor több lapba fogja megnyitni őket automatikusan.
Sub ImportLargeFile()
'Imports text file into Excel workbook using ADO.
'If the number of records exceeds 65536 then it splits it over more than one sheet.
Dim strFilePath As String, strFilename As String, strFullPath As String
Dim lngCounter As Long
Dim oConn As Object, oRS As Object, oFSObj As Object
'Get a text file name
strFullPath = Application.GetOpenFilename(''Text Files (*.txt),*.txt'', , ''Please select text file...'')
If strFullPath = ''False'' Then Exit Sub 'User pressed Cancel on the open file dialog
Application.ScreenUpdating = False
'This gives us a full path name e.g. C:\folder\file.txt
'We need to split this into path and file name
Set oFSObj = CreateObject(''SCRIPTING.FILESYSTEMOBJECT'')
strFilePath = oFSObj.GetFile(strFullPath).ParentFolder.Path
strFilename = oFSObj.GetFile(strFullPath).Name
'Open an ADO connection to the folder specified
Set oConn = CreateObject(''ADODB.CONNECTION'')
oConn.Open ''Provider=Microsoft.Jet.OLEDB.4.0;'' & _
''Data Source='' & strFilePath & '';'' & _
''Extended Properties=''''text;HDR=Yes;FMT=Delimited''''''
Set oRS = CreateObject(''ADODB.RECORDSET'')
'Now actually open the text file and import into Excel
oRS.Open ''SELECT * FROM '' & strFilename, oConn, 3, 1, 1
While Not oRS.EOF
Sheets.Add
ActiveSheet.Range(''A1'').CopyFromRecordset oRS, 65536
Wend
oRS.Close
oConn.Close
Application.ScreenUpdating = True
End Sub
Itt egy másik is:
Sub LoadData()
Const cCol1 = 20, cCol2 = 20, cCol3 = 20, cLimit = 50000
Dim intFreeFile As Integer, i As Long, j As Long, strTemp As String
Dim arr() As String
On Error Resume Next
intFreeFile = FreeFile
Open ''c:\test.txt'' For Input As #intFreeFile
i = 0: j = 1
ReDim arr(cLimit, 2)
Do Until EOF(intFreeFile)
Line Input #intFreeFile, strTemp
arr(i, 0) = Trim(Mid(strTemp, 1, cCol1))
arr(i, 1) = Trim(Mid(strTemp, cCol1, cCol2))
arr(i, 2) = Trim(Mid(strTemp, cCol1 + cCol2, cCol3))
i = i + 1
If i > cLimit - 1 Then
Cells(1, j).Resize(cLimit, 3).Value = arr
i = 0: j = j + 3
End If
Loop
Close #intFreeFile
End Sub
- CURVE - "All your cards in one." Minden bankkártyád egyben.
- Milyen külső akkumulátort mobileszközökhöz?
- Facebook és Messenger
- PC Game Pass előfizetés
- OPPO Find X9 Pro Titanium Charcoal 512GB használt karcmentes 6 hónap garancia
- HP Dell, üzleti kategóriás notebook kiárusítás - frissítve: 02.28
- Xiaomi 14T Pro 512GB,Újszerű,Dobozaval,12 hónap garanciával
- BESZÁMÍTÁS! 1TB Samsung 870 QVO 2,5" SATA SSD meghajtó garanciával hibátlan működéssel
hogy ezt akarta. Most már értem
nem lehet velük virust írni
Fferi50
