zsiga667
lordjancso
#600
Egy ilyet találtam hirtelen:
"This is a guide to getting FF8 PC to work on any OS with any version. All this requires is that you have the 5CDs (or ISO equivalents) and a will to listen and read carefully.
After installing the game to whatever directory you choose (I will use E:\FF8 in my example since it is a non-standard installation path), mount/insert the first CD into your drive.
Take note to what drive (letter) you will be using to mount/insert the first CD (I will use S: ).
After having done so, open up your registry editor. (For those who are new to this: 1. click your start button 2. click run 3. type in regedit and hit enter)
In regedit, find the key: HKEY_LOCAL_MACHINE\SOFTWARE\Square Soft, Inc\FINAL FANTASY VIII\1.00
Again, for those of you new to regedit, simply browse through the following folders (in this order) until the pane on your right displays several items, of which one will be "DataDrive".
HKEY_LOCAL_MACHINE
SOFTWARE
Square Soft, Inc
FINAL FANTASY VIII
1.00Right click on the string value labelled "DataDrive" (it will have an icon with the letters ab on it to the left of it) in the right pane of the regedit browser.
Click "Modify"
In the field marked "Value Data" which is the only field you can change, it will probably display something like "c:"
This is where knowing your installation cd drive letter comes into play
Change the "c:" to whatever drive you installed FF8 with (for example "s:\")
Click OK
Close regedit.
Run ff8.exe or your appropriate shortcut.
That's it - all done. I have tried to make this guide as easy as possible as it took me about 2 hours to finally find out the no cd crack is even necessary for this game, just some regeditting fun. So hope you appreciate it and lay on the feedback/success!
zsiga667
lordjancso
#598
Nekem anno elindult a K: meghajtóról telepítve, szóval más lesz a gond.
- Fotók, videók mobillal
- Vezetékes FEJhallgatók
- Szerkesztett és makrofotók mobillal
- Mobil flották
- Milyen okostelefont vegyek?
- Különleges házzal jön a Colorful asztali PC-je
- Samsung Galaxy S24 256GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA! Épített KomPhone Ultra 7 265KF 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- Apple iPhone 17 Pro Max Deep Blue 256GB használt újszerű 100% akku (36 ciklus) garancia 2029.01.
- MSI Crosshair 16 i7-14700HX 14. gen 16gb ddr5 + RTX 4060 (140W) + 240Hz QHD+
- 268 - Lenovo Yoga Pro 9 (16IAH10) - Intel Core U9 285HX, RTX 5060
