Sanya
elmégy ide a dvd olvasó ügyében:
[L]http://forum.rpc1.org/dl_firmware.php?download_id=24[/L]
itt megkeresed a 2.2-es bin formátumot majd letöltöd. valami ismerős haverral, aki ért hozzá, azzal lefordíttatod a readme-t:
''Firmware version 2.2 for the ASUS DVD-ROM E616
Flash in Windows with MTK WinFlash (http://digi.rpc1.org) and point to ''2.2_full.BIN''
Or Flash in DOS with the included mtkflash
Boot into DOS, then navigate to the folder where the firmwares and mtkflash are extracted
Type ''upgrade'' and proceed to tell the batch file where the drive is located using the numbers 1-4
Your current firmware will be backed up to the folder as back00.bin and back01.bin''
az írónál könyebb a helyzet, a te legújabb firmware-ed:
[L]http://tdb.rpc1.org/firmware/4XMAX260.ZIP[/L]
ennek meg ez a readme-je:
MSI DVD Dual BIOS Update Procedure
1. Create a bootable floppy disk that be able to boot
to DOS console capable of executing normal MS-DOS batch
and executable files in accordance with the instructions.
2. Download and unzip the xxxx.zip file corresponding to
your model from the MSI website to the floppy disk or
Hard Disk.
3. Boot from your DOS floppy disk to the Real DOS mode.
4. At the command prompt.
|Type ''DVFLASH <Firmware>''. |
|Usage: DVFLASH <filename.xxx> |
5. Reboot the system,when finish updating process.
Note: You should not update your firmware unless you have
have flash experience with your optical drive.
- MWC 2026: Kezünkben a most bemutatott Nothing Phone (4a)
- Anime filmek és sorozatok
- Windows 11
- Arc Raiders
- ÁRGARANCIA! Épített KomPhone Ultra 7 265KF 32/64GB RAM RX 9070 XT 16GB GAMER PC termékbeszámítással
- Asus ROG 17 WQHD 240Hz G-Sync Ryzen9 7945HX 32GB 1TB SSD Nvidia RTX 4090 16GB 175W Win11 Garancia
- Apple iPad Air 2 (A1567) 16GB Wi-Fi + Cellular Asztroszürke
- Lenovo ThinkPad T590 15,6" - i5 8265U, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- HP Victus 16 i5-11400H 16 GB RAM 512SSD RTX 3050 4 GB FHD 144Hz
