X-E5 tulajdonosok olvassák el: [link]
madstunt
excalibur36
#25733
photo mate
madstunt
A pro2 amúgy mennyire melegszik ?
madstunt
total90
#25677
igazabol a 4k24fps-re is az volt a kamu, hogy nem birja a hardver, aztán mégis meg lett valósítva...
Ugyanaz az X Processor, meg szenzor, nem valoszinu, hogy a tarsitott dramban lenne kulonbseg ezek mellett.
sokszor ugy erzem, inkabb csak a r&d-en valo sporolgatas akar ez lenni -
madstunt
Most keresgélve neten, ezekszerint én emlékeztem rosszul, hogy a 120fps a Pro2-nek is be volt lengetve, nem csak a T2-nek ?
madstunt
#25668
FUJIFILM X-Pro2 (Ver.5.0.0) – due May 2018
Enlarged and customizable indicators or information
The upgrade allows users to enlarge indicators and information in the viewfinder and/or LCD monitor. This upgrade will also enable users to customize the location of where the information is shown on the display.
Enhanced Phase Detection AF
Latest updates to the AF algorithm provide the following performance enhancements
(1) The low-light limit for phase detection autofocus has been improved by approximately 1.5 stops from 0.5EV to -1.0EV, raising the precision and speed of autofocus in low-light environments.
(2) The range at minimum aperture has been expanded from F8 to F11. For example, even when using the XF100-400mmF4.5-5.6 R LM OIS WR with the tele converter XF2X TC WR, phase detection autofocus can now be used.
(3) Major improvements have been made to the AF-C performance while operating the zoom, which provides major benefits when shooting sports and other scenarios in which the subjects moves unpredictably.
(4) Finely-detailed surface textures of wild birds and wild animals can now be captured at high speed and with high precision as a result of improvement in phase detection autofocus.
Addition of “Flicker Reduction”
For enhancing the quality of indoor sports photography, the upgrade allows users to reduce flicker in pictures and the display when shooting under fluorescent lighting and other similar light sources.
Addition of “Select Folder” and “Create Folder”
Enable to choose the folder in which subsequent pictures will be stored. And also enable to enter a five-character folder name to create a new folder in which to store subsequent picturesmeg én arra emlékeztem, a FHD 120FPS videó is ezzel jönne a pro2-re, de lehet rosszul emlékeztem ezek szerint
madstunt
total90
#25646
Ez igaz, de még idén tervben van a pro2 vásárlás, ha minden a tervek szerint megy (nem szokott) akkor még ősszel
Amióta kijött szemezek vele, de volt pár dolog amelyek miatt hezitáltam, de fw update javította.
Igazából már csak egy tilt screen hiányzik róla, meg pár apró hw feature, gondoltam kivárok a pro3-ra, de a türelmem elfogyott, mert ha valaha is jön, akkor biztos legalább még egy év. -
madstunt
A tesztek óta amúgy a Pro2 AF mennyire javult a való életben? Nyilvan a release notes elárulja technikailag mit javult, de a való életben felért a CAF egy XT2 körüli szintre?
madstunt
#25626
Nem tudom melyik jobb, Northrup, aki felkeszuletlensegbol allit hulyesegeket, vagy a Teoria Apufityisz, aki rogeszmekbol meg valami gyermeki sertodottsegbol es azzal jaro gőg miatt beszel meredek dolgokat.
Tony-ekbol legalabb hianyzik a masikban meglevo frusztralt duh, es ez legalabb sokkal nezhetobbe teszi őket. -
madstunt
Az újabb (Pro2, T2) vázaknál az androidos remote el tud videofelvételt indítani ? -
madstunt
Szinte kizárólag vintage manuálozásra, azon belül is csak fotóra (nem akarok vele videózni) melyik a jobb, a PRO1 vagy E2 ? Ahogy látom, használtpiacon kb egy árban vannak -
madstunt
Korábbi tapasztalatok alapján, a photoexpo-n novemberben meg lehet majd vizslatni élőben is az XT2-XPRO2 párost ? -
madstunt
XT1-en meg XPRO2-n el lehet a videofelvételt indítani az okostelefonos remote alkalmazással ?
látom, hogy a korábbiaknál volt rá lehetőség -
madstunt
DonRazzino
#14412
Nagyon köszi
Én az árba beletörődtem. Mondjuk így, hogy üveget is kell vennem hozzá meg battery gripet is, elég gyorsan ott vagyok, hogy ha kivárom míg mindenre költhetek, az EU és USA ár közti difi már egy oda-vissza NY repjegy
Fujinál amúgy mennyire okoznak problémát a különböző régiók ?
madstunt
rbalint88
#14406
meg a bebetonozott LCD, ami miatt szóba se igazán kerültek számomra, meg egy-két ergonómiai dolog ami az X-T sorozat javára dönti nálam a mérleget, meg az én céljaimra az X-T2 sokkal jobban illik funkcionalitásban mint a többi
BTW melyek a gyors fókuszú obik a Fuji rendszerben?
Ahogy látom 16-50, 100-400 meg 50-140 mindenképpen, de pl a 35-ös fix inkább megfontolt -
madstunt
Én elég nagy sony fanboy vagyok, de a pre production XT2 is meggyőzött arról, hogy inkább azt veszem év végén, mint a már év elején kiszemelt 6300-at az A6000 leváltására.
Én nem akarok FF-re menni, de a sony-nál mintha az APS-C vonal csak kötelező rossz lenne.
Kijött az A6300, de egy rakat dolog olyan rajta, mintha a kamerát csak muszájból csinálták volna, a felh igényeket mellőzve.
Sajnálom, mert amúgy az A6000/6300 design, a balra kitolt evf-rel sokkal jobban kézre/szemreáll számomra mint az A7 / X-T sorozat kialakítása -
madstunt
Fandango
#14262
Türelmes vagyok inkább, míg összegyűlik
Főleg mivel új belépőként érkezek a rendszerbe, és a sony rendszeremet meg nem akarom eladni, inkább odaajándékozom fateromnak, hogy használhassa a régi filmes manuálobijait
De obikból ami natív, az csak a két nagytele (100-400 és az 50-140) lenne ami kellene, a többire elég az oldschool filmes obijaim
A natívakat meg később veszem majd
madstunt
A battery gripekhez jól sejtem, hogy a fuji se ad akksit a retail csomagolásban, és azt utólag kell vadászni ?
- Samsung Galaxy A06 64GB, Kártyafüggetlen, 1 Év Garanciával
- Zotac Gaming RTX 5080 // Felbontott, új // SZÁMLA // GARANCIA //
- BESZÁMÍTÁS! ASUS TUF GeForce RTX 3080 Ti 12GB videokártya garanciával hibátlan működéssel
- Telefon felvásárlás!! Samsung Galaxy A50/Samsung Galaxy A51/Samsung Galaxy A52/Samsung Galaxy A53
így a luxus megvan
hemaka
