Gorneck
legenda
Cpu fesz normal, ram 2.0V, fsb 420, 1:1, 5-7-7-20-Auto eddig, de most húzok melózni...
slayer006:
[Szerkesztve] -
Gorneck
legenda
XS:
''I think I have found the main reason for our cold boot problem. I hooked up a dmm to the read point for vmch.
I started out with plans this afternoon of being vdroop, vmch, and vdimm. Vdroop so I could get a more reasonable vcore at idle. Vdimm since mine was 0.1v lower than what was set. Plus, I figured if I made starting vdimm at 2.1v, it may eliminate some boot issues. Results show vdimm boost didn't help boot issues though, but it's nice to have +0.2v have it at 2.3v.
Vmch. Here's the interesting guy. It's been brought up many times before, and people have done actual reads based on different fsbs and all settings normal, +0.1, +0.2, and +0.3. I should have done this as a baseline for comparison but I didn't think to at the time. I ran out of qtips for the time being, but I need to erase the pencil for vmch anyway.
But here's what I found. I recall setting it so that base vmch was 1.35v. Then I proceeded to try and do 450fsb. I tried +0.2v setting as my preference, since I read I think a vrzone article saying they stopped seeing cold boot issues after keeping vmch at 1.55+. However, this +0.2v resulted in a setting somewhere around 1.7v. What the... Maybe the graphite heated up and become less resistive. I'll check that in a bit. I try normal and +0.3v and both send me to 1.8v vmch. Yikes. +0.1 sets me very close to my original target of 1.55 though so I figured I'd just try to keep it there.
One thing I noticed was that each time the system went for a reboot, I saw a first vmch setting of 1.45-1.49v regardless of what vmch is set to. Then it pulls it up to what the setting was. However, I haven't been able to boot 450fsb ever since I did the mod. Got it to post maybe once or twice, with insane vmch iirc. But even then it didn't boot successfully into windows.
I'll try to get rid of the graphite, and see if I can determine any characteristics of it at stock.
Perhaps if there was a way to clamp vmch at 1.55 - 1.6v, everything would be peachy? The problem is that I'm not sure how to approach this. Since with however much graphite I put on, it looks like the effective baseline vmch is being set to 1.45-1.49, which rarely do I see applied. The problem is that ''normal'' goes to the +0.3v equiv at the fsb's we want to be focusing on. And the problem with that comes in that there is no +0.0. The best compromise would be +0.1v. If things do work out properly, this would mean it'd always turn on at 1.55v, and once it gets ready to post it pulls it up to 1.65v. With adequate cooling, 1.65 should be ok. However, this still has the problems of normal/+0.3 sending vmch to nearly 1.9v (seems the +0.3v setting is slightly more than a 0.3v jump). On recovery posts, I believe it always forces max vmch, so there should be frequent shocks for us tweakers.
I'd imagine that clamping vmch would require soldering, beyond the pencilmods I did.
edit: Oh yeah, I nuked my windows again. Agh. I shorted out the read point for vmch with one of the legs, powering off the system. On boot up again, bios settings are retained, except time gets reset. I didn't realize this, and proceeded to try and boot windows. I was greeted with ''trial period over'' again. Grrr, back to safemode to backup and format once I get it up I guess
update: bleh didn't help with instability. guess the board was returned for a reason. but woohoo, got my rev2 working again.'' -
Gorneck
legenda
410-től elkezdem majd a felfelé lépkedést...szépen. Sztem véglegeset, majd hétfőn tudok mondani (30-60 percet min rászánok egy beállításra), de ha tudsz vegyél A-Data Vitesta-t...jó az a ram nagyon. Lehet időzítésben semmivel se mutat jobbat, mint egy Cors, Geil...
[Szerkesztve] -
Gorneck
legenda
Biztos (lehet nem is volt mit javítani), ahogy biztos az is, hogy már az elején ez megtörtént (persze, ha kellett mit javítani), mert erről már volt szó a topikban és elég régen...jött ki pár bios azóta amik sokkal használhatóbbak...de amúgy tényleg kár görcsölni...én úgy gondolom ilyen baj ha volt is gigának nem sokáig.
Gorneck
legenda
detroitrw
#4520
Ha végre hazajutok innen fel is rakom...
bim: Megnézem sztem holnap az ultrákat mit bírnak, de ennél a Vitestánál kevesebbet mennek ez szinte biztos (sajna akár 4 fajta chip is lehet rajta...d9ből 3 fajta (aszhem írtam is a topikban) és elpida is elképzelhető. Anno sajna nem lehetett őket kapni, pedig ilyet akartam. Csere gondolata már megfogant bennem, de elég combos kiadás lenne...szal igazából nemtom hogy mit is kéne tennem, mert ne hiányzik, de nem lenne rossz. -
Gorneck
legenda
Stalker-2572
#4516
Ez van...de próbáltad intellel is?
Gorneck
legenda
Stalker-2572
#4491
Mi nem? Proci terheltségről volt szó...10-16%-ról amit kétlek, hogy megérezne egy 2.4-2.8on muzsikáló core2.
germanh: Nekem audigy-vel sem volt semmi változás. Egyszer akadt a BF2 vagyis kétszer...
1. 512 rammal.
2. Nem épp a legjobb drivert használtam hozzá vga szinten.
Hang miatt sose akadt csak szebbek lettek a hangok audigy2-vel.
[Szerkesztve] -
Gorneck
legenda
Stalker-2572
#4489
Pff...ez most hogy jön ide?
Gorneck
legenda
detroitrw
#4473
Már írtam...de az oldalam tökéletes útmutató...
Vhogy így...450-től...
mch +0,1v (sztem itt sok függ a ramtól és procitól, hogy kell több 480 környékén kell)
cpu 1.4v (Ez nem biztos, hogy kell, de ezen nem múljon)
mem +0.3v (2.1et fog kapni)
5-5-5-12-Auto. vagy 5-5-5-15-Auto.
Amúgy kis teszteled rendesen?
EPP-t sztem nem. -
Gorneck
legenda
detroitrw
#4467
Én nem a terhelésről beszéltem hanem a 380 mellett 2.1v-ról 400 felett meg 1.9v...érted? Cpu meg természetes.
Akkor meg toljad neki...eddig elég jól teljesít ram...bár ahogy más úgy én is az alacsonyabb időzítésekre vagyunk kíváncsiak és az ehhez követelt feszre...bár igazából 2*1gb-ra pályázik már a ''nép'', az meg tuti másképp fog menni... -
Gorneck
legenda
detroitrw
#4465
Mármint a biosba állítottál 1.3at?
Ezt hívják dropp-nak...mármint a feszültség ingadozást alapon és terhelve...
Sztem jó lenne fix értékekkel dolgoznál már végre...így, hogy ugrál a ram fesz ki tudja valójában hol és milyen feszen stabil a cucc. Szal, 5-5-5-12-auto; 2.0v; 1.325v. -
Gorneck
legenda
detroitrw
#4463
Az zavart meg, hogy szinkronba ment a ramod akkor is a proci-val vagyis fsb-vel így nem értettem mit is akarsz azzal a képpel...most se!
Elviekben úgy van, hogy fsb emelés esetén auton adagolja a feszt...mondjuk aszhem ez lett is tán javítva...nem emléxem. Amint állítottál fix feszt minden ok lett. Emlékeim nem csalnak, akkor te is fixre lőtted a cpu feszt?!
Egyébként egy egészséges beállítás nem ártana a ramnak...nem lesz semmi baja.
[Szerkesztve] -
Gorneck
legenda
Tegnap rászántam az időt...de eredménytelen maradt próbálkozásom...
Húgom hajszárítója volt az egyik célszerszám (nem gondoltam, de tud ''sima'' levegőt is fújni...mint egy venti). Az NB környékét vettem célba egy kis légárammal...eredménytelen maradt a próbálkozásom. A lap hőmérője vagy egész más helyen van és egy felületi érzékelő ami nem az NB környékén van vagy az NB borda alatt helyezkedik el. Az uccsó lehetőségnél maradtam, mert ebben láttam rációt. Szal win alatt 36-ról szépen ugyanúgy felkúszott a hőmérséklet 39-re, pedig a bordát telibe fújtam. -
Gorneck
legenda
Yushchenko
#4320
Neeeem...
Közöltem vele, hogy tudom hol lakik...
Gorneck
legenda
Yushchenko
#4314
No para, engem 3szor. 4dik alkalommal beszéltem a tanárommal...át is mentem.
Gorneck
legenda
#4309
G(MCH) Voltage, FSB Voltage...sztem nem is kéne adnod ezeknek semmit. Nem kell oda víz.
Ki szokták kapcsolni, én nagyon csípem pedig a c1e-t és az eist funkciókat is...fesz + órajel visszavétel, ha nincs terhelés. Igazából én nem próbáltam, mert nekem jó ha azok vannak, de fesz visszavételhez kell a cpu fesz: normál. Nemtom, én nem állítottam, mert instabil lett a cucc tőle, de Robi fast-on használja aszhem a memory performance-t. Nem egy számottevő a növekedés. -
Gorneck
legenda
realist
#4299
stitchie: Elvileg nem lehet nagy eltérés S3/DS3 között, de DS4 egy picit más tészta, de nem lepődnék meg ha nagy általánoságban 35-40 között mozogna mindenkinek...Amúgy engem inkább az izgat, hogy hol van ez a senzor, mert az ES2 egy nagyon bika chipset hűtő, de a lap hőfoka 1 centit se ment lejjebb. Szal az nem az NB hőfokát mér az tuti...bár ezt eddig is tudtuk, de akkor mit és hol?!
[Szerkesztve] -
Gorneck
legenda
Geil Ultra tulajok...''Elpida (seit Dez. 06), Micron D9GCT (?), Micron D9GMH (?)'' valszeg ezért olyan eltérő a Geil Ultra tuning a lapokba.
Gorneck
legenda
Asszony miatt nem volt időm nagyon foglalkozni a témával, de mióta a zalman panel átvette a TT ES2 ventijének irányítását teljesen hangtalan lett. Nem értem mitől lehet, mert fullon sincs olyan hangja, mint eddig volt...lehet a kevés fesz miatt hangoskodott a kicsike?
Nagyon pozitív eddig a véleményem erről a TT termékről...ajánlom bárkinek. 7v-on meg nem is hallom... -
Gorneck
legenda
LSL1337
#4275
Én most a 10es az alól raktam fel...
DS3/S3 Change list
1. Enhance FSB frequency flexibility
2. Fix OC für Allendale CPUen
3. Micron D9 1000 MHz 4-4-4-12 2.2V
4. Micron D9 1100 MHz 5-5-5-15 2.3V
5. Micron D9 1200 MHz 5-8-8-20 2.35V
6. Fix Kaltstart
7. Fix Vdrop in C1E Funktion
8. Neues Features ´High Speed DRAM DLL Setting´
9. Intel® HPET Support
10. FSB 1333 MHz support (Auto ab Rev.3.3)
11. JMicron ROM update
12. BIOS Profilspeicherung möglich
13. Q-Flash jetzt mit USB-Stick möglich
Ha jól átolvasod, akkor rájössz, hogy volt mit javítani...sajna az uccsó két bios csapnivaló lett...pl ennél a lapnál is előjött ez a cold boot bug (kaltstrat). -
Gorneck
legenda
Gorneck
legenda
Oldal frissítve...[link] egy kis tuning (wusy féle) és rev1 vs rev 2...
- MIUI / HyperOS topik
- Káprázatos űremléket állított Jeff Bezos az édesanyjának
- Álláskeresés, interjú, önéletrajz
- CURVE - "All your cards in one." Minden bankkártyád egyben.
- Óra topik
- Milyen okostelefont vegyek?
- Arc Raiders
- G.SKILL Trident Z RGB 64GB (2x32GB) DDR4 3600MHz F4-3600C18D-64GTZR
- Corsair Vengeance RGB RS 32GB (2x16GB) DDR4 3600MHz C18 Memória!
- Új asus rog crosshair x870e hero garancias! AKÁR FÉLKONFIGKÉNT!
- Gigabyte H81M-S2PV alaplap + Intel i5-4460 + 2+4GB DDR3 + hűtő 19e
- 16GB DDR5 RAM-ok garanciával, számlával!
- Apple iMac 19.2 i5-8500 Radeon Pro 560X 4GB 16GB 256GB SSD 21.5" 4K Retina
- BESZÁMÍTÁS! Intel Core i7 4790 4 mag 8 szál processzor garanciával hibátlan működéssel
- Gamer PC-Számítógép! Csere-Beszámítás! I5 12600K / RTX 3070Ti / 32GB DDR5 / 512 SSD!
- 0% THM 4 havi részlet beszámítás! 5060Ti/5070/5070Ti/5080/5090 videokártyák készletről KAMATMENTESEN
Most nézegetem...egy biztos, hogy 410en nem megy neki a 4-4-4-12-Auto 2.0V-tal.
4*512-vel is simán megy a tuning...
Amúgy eddig facca...
Frissítem aszhem...
