gyuszaa
Pár eredmény :
I7 4770K @ 4.3 Ghz - HT on
2X R920 CF @ stock
15.4 Grand Theft Auto V Optimized Beta DriverMinden very high-on, vagy lehető legmagasabb beállításon és 2X MSAA.
CF :
Gpu kihasználtság elég jó általában.
Benchmark elég érdekes, CF rendszerrel mikrolaggol bizonyos jeleneteknél, de játék közben még nem tapasztaltam, igaz csak pár percet játszottam. Egy kártyás rendszerrel benchmark is vaj simán fut.
R9 290 CF Benchmark :
1:
Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 55.062695, 104.766800, 81.363205
Pass 1, 23.038357, 131.593781, 95.504768
Pass 2, 32.179871, 147.480881, 95.830849
Pass 3, 34.076237, 140.844604, 106.941902
Pass 4, 2.417784, 187.638184, 95.0189292:
Pass 0, 58.145363, 109.622093, 85.149292
Pass 1, 21.473867, 134.139832, 93.266968
Pass 2, 45.164669, 144.518921, 94.170578
Pass 3, 39.280781, 153.625641, 116.287216
Pass 4, 3.614035, 170.194534, 93.382607Single R9 290 :
1:
Pass 0, 47.307537, 106.222168, 72.283401
Pass 1, 42.065311, 109.034607, 64.181351
Pass 2, 42.336246, 132.373535, 70.841187
Pass 3, 53.175533, 142.702774, 76.288071
Pass 4, 22.084351, 148.383621, 73.2564162:
Pass 0, 46.443604, 113.446075, 72.357162
Pass 1, 36.760777, 113.732971, 64.639954
Pass 2, 44.569263, 141.967804, 70.161057
Pass 3, 54.525131, 150.507141, 76.556213
Pass 4, 24.299158, 160.560730, 73.190880=== SETTINGS ===
Display: 1920x1080 (FullScreen) @ 72Hz VSync OFF
Tessellation: 3
LodScale: 1.000000
PedLodBias: 0.200000
VehicleLodBias: 0.000000
ShadowQuality: 3
ReflectionQuality: 2
ReflectionMSAA: 0
SSAO: 2
AnisotropicFiltering: 16
MSAA: 2
MSAAFragments: 0
MSAAQuality: 0
TextureQuality: 2
ParticleQuality: 2
WaterQuality: 2
GrassQuality: 2
ShaderQuality: 2
Shadow_SoftShadows: 4
UltraShadows_Enabled: false
Shadow_ParticleShadows: true
Shadow_Distance: 1.000000
Shadow_LongShadows: false
Shadow_SplitZStart: 0.930000
Shadow_SplitZEnd: 0.890000
Shadow_aircraftExpWeight: 0.990000
Shadow_DisableScreenSizeCheck: false
Reflection_MipBlur: true
FXAA_Enabled: true
TXAA_Enabled: false
Lighting_FogVolumes: true
Shader_SSA: true
DX_Version: 2
CityDensity: 1.000000
PedVarietyMultiplier: 1.000000
VehicleVarietyMultiplier: 1.000000
PostFX: 2
DoF: true
HdStreamingInFlight: false
MaxLodScale: 0.000000
MotionBlurStrength: 0.000000 -
gyuszaa
Úgy hallom jól sikerült a port, PS3 diavetítés után biztos megváltás lesz.
Először egy R9 290-el tesztelem, aztán délután beröffentem a CF-et.
Beállításoknál szépen belőtte magát very high-ra alapból.
gyuszaa
privacy99
#9756
Nem éppen, itt az elsődleges platform a PS3/X360 volt mindig is, melyekre egy időben fejlesztették közel 5 éven át (nem kell összekeverni az ubisoft és társaival), nyilván ezekre is adták ki először.
Utóbbi meg várható volt, most fog csak teljes pompájában kibontakozni, ráncfelvarrással.
gyuszaa
Darth_Revan
#9752
Ha eléri a csúcsot (2-3 nap), azt követően csak csökkenni fog (míg a konkurencia nőni
), és nem megy fel újra. Korábban írtam, hogy alvás mellett kell ezt csinálni a safehouse-ban, és autosave kikapcs.
gyuszaa
jonnyjoker01
#9695
Mekkora felbontásban?
gyuszaa
Bjørgersson
#9536
Várom a pre-order lehetőségét megint.
gyuszaa
.Szaki.
#6679
Ha be van kapcsolva az automatikus mentés akkor elég csak az autosave jelzővel ellátott mentést betölteni, az lesz a legfrissebb, mert bármilyen eseménynél ment és felülírja az előző állást. (Indítás után egyszer kérdezi meg, hogy felülírhatja-e az előző állást, onnantól nem fog rákérdezni csak teszi a dolgát.)
Magától össze vissza nem ment külön, 15 rendelkezésre álló slotod van ugye a telefonon elérhető gyors mentés funkciónál, azokat te irkálod felül csak maximum, ha nem egy új mentést kreálsz. Ugyan így volt ez a gta4 esetén is olyan tekintetben, hogy az autosave egy helyet foglalt.
Az autosave nem látható a gyors mentés funkciónál, csak ha pause/game - load game-re mész, ott a legelső állás lesz.
gyuszaa
L_YKing
#6589
Az összes honlapon szereplő épületnél szét kell verni a hirdetőtáblákat, azt hiszem 15 van összesen.
Utána fog adni még küldetéseket, amúgy a legjobb barátja volt akin bosszút akar állni ezzel, szintén ingatlanügynök és mindent elhappol előle, Tervor cserébe egy kis bouncy bouncy-t kap a tagtól![;]](//cdn.rios.hu/dl/s/v1.gif)
Ahogy már írták előttem a másik meg két zakkant idős brit , akik az interneten ismerkedtek össze közös szenvedélyük által (sztárok személyes tárgyait gyűjtik relikviaként). Nagyon humoros szövegek vannak benne.
Mind a két küldetés több részes, utóbbinál figyelni kell a térképet.
Hasonlóan mint a gyűjtögetős küldetéseknél, akkor zárul le, ha megszereztél/elvégeztél mindent. -
gyuszaa
RohamDroid
#6457
Egyik előnye psn plus-nak, hogy a felhőbe szinkronizálod a mentéseid. Ha nem tetted meg ezt nagy hiba volt.
Elég rosszkor történt ez, amúgy milyen fajta az utódja? Mennyi idős?
gyuszaa
Na végre sikerült kipróbálnom a multit, eddig pozitív.
Szerencsére én nem futottam össze idiótákkal, együttműködtünk a küldetések alatt. -
gyuszaa
jonnyjoker01
#6428
Amúgy ez az update egy útban egy patch is volt :
Játék teljesítése után vagy mission replay alatt a telefon Internetébe lépve már nem romlik el az interfész (hud).
Javítva a hiba, ami miatt néha be volt zárva a Vanilla Unicorn.
Javítva a hiba, ami miatt a karakter pénze néha mínuszban ragadt.
Az Epsilon Program küldetések normálisan folytatódnak az autók leszállítása után.
A Collector's Edition tulajdonosoknak már rendesen megjelenik az Atomic Blimp a telefon Contacts menüjében.
A garázsban tartott járművek végre nem tűnnek el, és a tuningot sem veszítik el.
Több, mapról való kidobást és kollíziós hibát javítottak, valamint egyéb bugokat is.
via -
gyuszaa
RohamDroid
#6258
Akkor este felé már játszhatnák csapatban is, de elég kevesen vagyunk úgy látom.Kapacitást állítólag bővítették, de a kezdeti rohamhoz még ez sem elég úgy néz ki.
Én csak megcsináltam a karakterem, tovább nem tudtam lépni, ez van 2-3 órája. -
gyuszaa
A gtaonline karaktered, ami mai naptól lesz elérhető.
Itt egy kis információ : [link]
Akinek CE van :
"Egyedi karakterek a GTA Online-ban - csak a Collector's Editionben
A szülői gének is befolyásolják a karakterek megjelenését a multiban, Még egyedibbé varázsolhatod hősödet a napi tevékenységek kiválasztásával. A családdal töltött idő, az illegális munka és a sportolás is befolyásolja a kinézetet és a képességeket. A gyűjtői kiadás mellé járó karakterek: Nico Bellic, Claude és Misty a Grand Theft Auto III-ból. " via
gyuszaa
Elég meredek, normál tempóban csak sztori majdnem ennyi körülbelül. Nem lehetetlen, de ahhoz előre el kell tervezni mindent és célszerűen haladni (egy adott feladaton belül is), hogy a legjobban oszd be az időt.
Bár én sose voltam a híve ennek, gyorsan ledarálni és a részleteket nem veszed észre, ez az ára ennek, sok dolgon át kell siklani.
gyuszaa
jonnyjoker01
#6169
Majd csinálok egy összefoglalót. -
gyuszaa
Majdnem 1,2 milliárd dollárom van mind három karakternél.
Igaz egy héttel ezelőtti mentésemet kellett visszatölteni, konkrétan a játék befejezése után lévőt..
Így buktam mindent amit elkövettem a 100% érdekében eddig, de ez megérte.. legfontosabb rohadt autosave-et ki kell kapcsolni mert az szívatott meg párszor, még jó, hogy csináltam mentést a sztori befejeztével.Nagyon figyelni kell a tőzsdét mert egyik pillanatról a másikra akár mínuszba is mehetsz, legjobb ha az alvást választod és minden egyes lefekvés után ránézel a tőzsdére, mert 2-3 után eléri a maximum profitot, onnantól már csak lefelé megy egyből, és ezt a hibát követtem el, hogy közben csináltam a dolgaimat, autosave meg rámentett mindig...
Ebből aztán lehet költeni, ugyan 10 milliós kocsik.. mi az.
Még többet is lehetett volna, ha bizonyos rablásoknál nagyobb részesedést kapok (kevésbé tapasztalt csapattagok-kisebb részesedés) meg ha játék közben nem csinálok meg egy random eventet, mert az is +30%-ot jelenete most a tőzsdén.
gyuszaa
RohamDroid
#5950
1. PS3
2. PSN : gyuszaa
3. Social : gyuszaa
gyuszaa
RohamDroid
#5907
Oksa.
(#5908) LaciCRM
Ameddig el nem enged újra a forrasztás, fos xenonok mind kidöglöttek. Kiolvasztja magát.
(#5910) manutdzoi
Nem kell elrabolni, csak simán álld el az útját és dobj hátsó ajtóra egy c4-et.
gyuszaa
RohamDroid
#5903
Nyilván nem egy moderátornak a dolga megírni, ha elkészült egy összefoglaló jelezni kéne a szándékot például radi8tor1 felé.
Majd később az azonosítókat szépen összeszedjük és kitöltjük.
(#5904) LaciCRM
Mesélj, nekem annak idején az IV alatt pusztult meg... rossz viszonyban váltam meg tőle.
gyuszaa
RohamDroid
#5897
Valaki szerkeszteni fog összefoglaló hozzászólást? Addig nincs sok értelme bármit szervezkedni, míg minden információ elvész a hozzászólások között.
Jó lenne egy lista psn id/xbox live, social club-ról. És lehetne akár tényleg egy crew-ot létrehozni.
gyuszaa
Nem tudom te mit hoztál össze abba a küldetésbe,
végén mondják váljanak szét.. egyből ezek után balra a part irányába kell menni, Lamar is arra megy.. még meg is jegyzi Franklin, hogy most eddig a te irányításod alatt voltunk, most én jövök és maradjon mögötte.. szépen felmész azon a kis dombon, ki kell nyírni 2-3 rendőrt és beszállni egyből az ott álló rendőrkocsiba.Többi küldetés alatt is teljesen jól viselkedik az AI, ez látszódik a közös küldetéseken is, egyáltalán nem kezd el rambozni egyik karakter sem, ha átváltasz róla.
gyuszaa
Vannak drága, 30-150 milliós megvásárolható létesítmények, ezek megszerzéséhez elengedhetetlen. Panaszkodtak a R*-nak, hogy az IV-ben nem lehetett mit kezdeni a pénzzel pont a játék végén, most tettek ez ellen, van pár lehetőség még ezen kívül ahogy írták.
Még hozzátenném ehhez, hogy lehet maximalizálni a profitot ennél a manipulálási módszernél, ha már elején bevásárolsz x cégnél, elkezded leamortizálni y cég járműveit, ha végeztél rögtön eladod x cég összes részvényét, ami így már profitot termelt, és innentől jön az amit már leírtam, bevásárolsz alacsony árfolyamon most a konkurenciától (y-tól) és visszaállítod az árfolyamot már az x cég szabotálásával, így be lehet forgatni a pénzt.
Gyakorlatban nem tudom mennyire éri meg ezekkel szarakodni, garázdálkodni a FlyUS reptérén, majd ugyan ezt megtenni az AirEmu-nál. Vannak különböző gyorsétterem raktárak is, ahol ott vannak a szállító járművek, de ugyan úgy forgalomban is megtalálhatóak különböző területeken, és ugyan ez igaz a futár cégekre.. bár én biztos nem keresgélném őket, elméleti alapon működik.. reagál ezekre az eseményekre a piac.
gyuszaa
TommyGun
#5794
Van benne persze.
SPOILER
És még egy gta iv-es szereplő felbukkan, egyik CIA ügynök, Michell főnöke.Utolsó nagy arany rablás ütött, én az alagút fúrást választottam.
Meg Packiet egyik tagnak.
Endgame SPOILER
Egyetértek Cthulhu Dawn-al, választási opciót feleslegesen raktak a végére, elég volt, hogy elküldi Franklin Devin Weston-t a picsába, meg előtte az FBI-os Steve Hains-et, Lamar megmentése után. Viszont a normális (C) befejezés nekem tetszik. Az jó, hogy visszajátszásnál ki lehet próbálni a 2 alternatívát, nem ment rá a játékra.Most jöhetnek a megmaradt dolgok, én is akarom a 100%-ot.
(#5792) figure85
Erről a tőzsdés dologról már írtam korábban, érdemes a játék végére hagyni az assasination-os küldetéseket, (nem tartozik a sztorihoz) így alapból nagyobb pénzmaggal tudsz befektetni, mind a három karakterrel.
Közben találtam egy listát, ahol szépen összeszedték a lusta embereknek :
The Hotel Assassination - BetaPharmasuticals
The Multi Target Assassination - Debonaire - Stock symbol is DEB
The Vice Assassination - iFruit
Construction Assassination - Gold Coast Development - Stock symbol is GCD
Mielőtt felveszitek az adott küldetést, mind a három karakterrel fektessétek be az összes pénzeteket.
gyuszaa
Cthulhu Dawn
#5751
Grat!
Kerek egy héttel a megjelenésre.
gyuszaa
Engem nem zavartak még nagyon a rendőrök, hamar le lehet rázni őket különböző sunyi helyeken, ezt tetszik benne. Ha csinálok valami balhét, úgy is meg lehet onnan pattanni, hogy nem vesz észre akár egy sem.
Franklinnel egy random event (nagynénje környékén) : Bolti rablás.. egyik tag nem gondolt menekülésre alkalmas járműre, így én segítettem nekik. Közben leosztotta a társát, erre ez jött válaszul : "Go back to Liberty City, you Irish prick." Hohó, tán kedvenc ír gengsztercsalád egyik tagjáról van szó? Próbáltam bekukkantani a kocsiba, de végül elköszönésnél világosan kiderült Patrick McReary-ről van szó
Innentől fel is lehet őt bérelni rablásnál, tapasztalt.
Lester egyből tudta ki ő. -
gyuszaa
FZsolt15
#5508
Így van, pont erre a küldetésre gondoltam, és ezután lesz több ilyen is.
Rádióban is adnak tippeket mint ahogy már leírtam.
Nem véletlenül kapod Lestertől sem a házat ezután a küldetés után, nagyon bírom azt a fószert.
Cthulhu Dawn nálad nem tudom miért nem működik, ezt még a fejlesztők mondták megjelenés előtt, hogy lehet rombolással is manipulálni.
gyuszaa
gyuribácsi88
#5403
Tegnap találtam egy infernus-t, egy az egyben úgy néz ki mint az iv-ben. Teljesen feltuningolva nagyon repeszt, annyi lehetöség van (külön járművenként is..) simán lekörözi a régi undergroundokat. Nagyon tetszett egyik kocsi rablásos küldetés, végig cikázni kellett a forgalomban, kissé filmes hangulata volt a motoros rendőrökkel
gyuszaa
gyuszaa
#5384
Hozzátenném még sok cég van, érdemes átböngészni melyik milyen területen van, és kik a riválisok.
Sok küldetés befolyásolja a piacot, mint a rablások, robbantások stb..
Segíthet abban hova ne fektessél be véletlenül, mint a játék elején a lifeinvader-es robbantás elég negatív eseménnyel járt. De az ammunation meg általában stagnál vagy nő egy picit, mert mindig van szükség fegyverekre, lassabban hoz hozamot, de biztosabban.De nem is érdemes ezekkel foglalkozni az előbb leírtak miatt, azok gyors és nagy hozamot jelentenek és te is hatással vagy rá.
gyuszaa
Akkor kell venni mikor alacsonyan van a részvény árfolyama, és eladni mikor magasan. Vagy ha tudod melyik cég fog profitot termelni, előtte kell beleinvesztálni.
Erre add lehetőséget a rádióban elhangozott hírek, tipped adnak.
Lehet manipulálni is a tőzsdét, kiválasztod például egy autógyártó céget, elkezded felrobbantani az autóikat, így csökken a részvényük értéke míg a rivális cégnek nő a profitja, szépen bevásárolsz alacsony áron a megkárosított cégtől, aztán fordítasz a helyzeten és a konkurencia járműit robbantod fel, így nő vagy visszaáll alaphelyzetre ezáltal már is termelt neked pénzt. Portfóliód alatt eladhatod a részvényeidet. Ugyan ezt el lehet játszani a két repülős cég járműveivel például.
Vagy küldetés alatt kell figyelned, hogy miről van szó, főleg Lester esetében, aki megbízza Franklin-t különböző bérgyilkosságokra, legelőször egy gyógyszercégnek egyik fejesét kell kinyírni, így előtte vásárolj a rivális cég részvényeiből, nagy profitra tehetsz szert. Ilyenkor nem lehet már elérni a honlapot, le kell adnod a küldetést (meghalni, kilépni.. stb.), plusz amúgy sem tudsz karakter váltani.
Be kell fektetni mind a három karakterrel (mert ugye ez is számít, saját vagyonuk van) akár az összes pénzüket, és utána felvenni a küldetést újra.Volt olyan random event is, mikor egy üzletembert kellett gyorsan elvinni a reptérre mert lerobbant a kocsija, üzleti útra ment liberty city-be és hálája jeléül azt tanácsolta fektessél be egy xy céghez, nem véletlenül
Ezekkel könnyen lehet milliókat kaszálni.
Fontos hozzátenni a BAWSAQ az online social club tagok által változik, ami gta online esetén lesz főként érdekes. Az offline single player piaci eseményeken az LCN alapul.
LCN Stock Market - Opposing Companies:
CoolBeans - BeanMachine
Burgershot - Up-An-Atom
Clucking Bell - TacoBomb
FlyUS - AirEmu
GoPostal - PostOP
Bilkington - DollarPills
Pisswasser - Logger
MazeBank - BankOfLiberty
Redwood - Debonaire
Slaughter, Slaughter & Slaughter - Bullhead
RadioLosSantos - WorldwideFM
eCola - Raine -
gyuszaa
negyven2
#5254
Külön nem, de szerintem online formában kapod meg/vonják le azt a kupont egy vásárlásnál.
Konzolvilágra meg no comment, ugyanúgy az ő hatáskörük, hogy kivel szerződnek és, hogy tartják velük a kapcsolatot.
Nekem még azt is tudták mit szállítanak, és jó játékot kívántak hozzá.. ami persze délelőtt érkezett meg aznap, eddig csak jó tapasztalatom van a G4S-el, írnak levelet, hogy átvették a terméket a Konzolokszervize-től és másnap hány óra között várjam a futárt, eddig mindig úgy volt ahogy mondták.Játékmenetre :
Most kaptam meg egy lakást vinewoodi hegyeken, gyönyörű a kilátás, naplemente, reggeli órák, este úgy szintén . Nagyon jól bántak a fényekkel, tükröződésekkel és a hangokkal is a srácok, remek atmoszférát teremtettek ahogy ígérték.
gyuszaa
gyuszaa
Most volt meg az első rablás, tökéletesen sikeredett. Hatalmas játékélmény! Micsoda alagútrendszer van, készül a 4-es metró.
Célkereszt nekem nagyon bejön, emlékszem régen cs source-ban is ez a pont mánia volt, nem véletlenül.
gyuszaa
Felvettelek, amúgy social club-os kérdésedre válaszolva :
Aki még nem hallott róla, ingame előnyök : GTA V: Mi jár akkor, ha Social Club tag vagy?
Itt is hasonlóan pontoznak minden egyes küldetést, mint ahogy a gay tony-ba behozták már.
Statisztikákkal nyomon követheted a játékosokat, lehet létrehozni csapatokat és közös célokat kitűzni, például összecsapni más crewokkal.A játék menüjében, a barátok rész alatt láthatod az ismerősöket egy karakterlap formájában különböző adatokkal.
Okt.1-után még nagyobb szerepet fog kapni, mivel a gta online erre fog támaszkodni, account nélkül nem férhetsz hozzá.
Játékmenetre :
Irreális a rövid féktáv, és a városban szélesebb utakon láthatóan beesik az fps, ami engem zavar már.
Nem értem miért ekkora a látótáv a részletgazdagabb területeken is, ha nem bírja. Viszont PS3-on egyáltalán nem pop up-ol, nem tudom másik fronton mi a helyzet. -
gyuszaa
"Egyből belecsapunk a lecsóba, semmilyen lassú felvezetés vagy lassú adagolás..."
Jogos, de ezt mondták pár hónapja, hogy sokkal intenzívebb lesz az elődöknél ilyen téren :
"Benzies a következőket mondta pontosan:
"Már az elején nagyon intenzív küldetésekkel akarjuk meglepni a játékosokat. A játék tempója sokkal gyorsabb az elődöknél. [...]
Fontos megjegyezni, hogy a három karakter már régóta Los Santos lakosai, tehát nem újonnan érkeztek, mint Niko és Tommy Vercetti, vagy CJ aki hosszabb szünet után tért vissza városába. Emiatt már megvannak a kapcsolataik, ismerik a környéket és elfoglalt az életük - ezek a tulajdonságok azonnal rabul ejtik majd a játékost."
viaHa belegondolsz van alapja.
gyuszaa
Ksz-ből rendeltem, egy kedves hölgy hozta ki, nem is futárkocsival.
Az egész hátsótér tele volt gta5-el, mondta őrület.. ez csak egy része. Országos szinten.
Ez a poszter kibaszott nagy!
gyuszaa
NeoExDeath
#4710
Nem natív 720p szerintem szimplán bullshit, konzolokszervize-ben sima verzió van raktáron.
Nekem ebben a percben fog érkezni, sziasztok.
gyuszaa
HD7870/ GTX660 - Ezek most jó vételek, s alá nem érdemes menni.
De ezeknek is esni fog az ára mire kijön pc-re, eddigi portokhoz mérten körülbelül fél évet várni kell (még hivatalos bejelentés sem volt).Ha annyira megmozgat nézzél árgépen valami olcsó ss ps3-at, vagy használtan.
gyuszaa
Ez beszarás, akiknek van blueprint térképe világítson rá uv lámpával :
gyuszaa
Ezt is megéltük.
gyuszaa
Cthulhu Dawn
#4628
Jó utat.
Milyen a spoiler stream?
gyuszaa
Bjørgersson
#4472
Én most fogom megrendelni.
Biztos megéri a pénzét, nagyon részletes.
Küldetés része tele van spoilerrel, azt nem nézzük.Remélem korán jön a futár holnap, ettől függ a jattja.
gyuszaa
L_YKing
#4437
Látható az utcanév is az elején, és már az is köztudott egy ideje, hogy a ballas területe már.
(#4436) kovsol
A még fel nem fedezett területek homályosak a térképen, de nincs elzárva semmi sem.
Viszont :
"A főhősök nem lesznek egyszerre elérhetőek a játék elején, haladnunk kell majd a történettel, hogy minddel játszhassunk." via -
gyuszaa
Nagyon jól eltalálták a városi alapzajt : [link]
Délkeleti gettó, Groove st.
gyuszaa
Itt egy rendes CE unboxing, amit tényleg először nyitnak fel.
gyuszaa
Így van, egyik fórumtárs kikapott egy gyári hibás új gépet, érdemes elolvasni, hogy jártak el nála és mi a tapasztalata. Ráadásul itt hivatalos sony garanciát kap az ember, lepecsételve.
(#4282) samfishR
Nem lett volna belőle probléma, erről szól a címe.
(#4285) Zjunior
Oké, kérem azon befektetők listáját akik hajlandóak 59 milliárdot áldozni erre a projektre, na meg a konkrét fejlesztő gárdát is.
gyuszaa
Konzolokszervizebe is garantálták az aznapi (ingyen) kiszállítást, még posztert is adnak mellé.
gyuszaa
privacy99
#4178
Nem sok mindent lehet kivenni, de azt vettem észre a rádiós beköszön, hogy jó reggelt. Érdekes apróság, sokat adhat a hangulathoz. Főleg ha feldobnának egy két témát is a számok között napszakhoz illően.
Országúti biciklizés is jó lehet a hegyekben, biztos lesz verseny. -
gyuszaa
Pont erről nyilatkoztak a legelsők között :
„Az autók kicsit jobban tapadnak a talajhoz. Úgy gondoltuk, hogy a Grand Theft Auto IV-ben nagyok, és hajószerűek voltak, és úgy érezzük, ez nagy előreugráson ment keresztül, hiszen most már képesek vagyunk kicsivel több fizikát összpontosítani rájuk. Inkább olyannak hat a vezetés, mint egy versenyzős játék. Nem sok magas szintű autóversenyzős játék van jelenleg, és ez a probléma orvoslásra kerül ezáltal a játék által, méghozzá olyan módon, ahogy az eddig GTA-ban nem fordult elő.”
Érdekes, lehet túl komolyan vették ezt az NFS-t
na de az meg az ellentéte annak amit mondanak, majdnem licenszelt jármű szerű törés, remélem nem túl árkádosra készült, mert a magas szintű említésnél gondolom szimulátorra céloztak.Csak pár videót néztem de ott lassabb ütközésnél, fékezésnél úgy viselkedett mint egy "tégla", nem is tudom... mint ha nem látszódna annyira a futómű és a lengéscsillapító hatása az előddel szemben.
Azt hozzátenném épp pár videóban láttam néhány másodperces, efféle jelenteket ezért nem veszek készpénznek semmit, na meg nézőpont kérdése.. majd ha a hivatalos játékkal játszok kedden.
gyuszaa
Cthulhu Dawn
#4144
Nagyon szép, de egy állvány nem ártott volna.
(#4145) privacy99
Azaz, köszi a választ!
(#4147) FragStaR
Úgy is csak a saját szemednek fogsz hinni akkor.
Youtube-on egyszerűen egy szűrőt kell alkalmazni, beírod a keresendő kulcsszót ami jelen esetben ugye a gta5 gameplay, majd a feltöltés dátuma/ utolsó egy órában feltöltött opciót kiválasztani és időrendi sorrendben megjelennek így. -
gyuszaa
Cthulhu Dawn
#4105
Ezt már eddig is leközölték, nincs benne spoiler.
Trevor-nak ilyen rage a képessége, hogy kétszer annyit sebez és fele annyit sebződik, és speciális közelharci mozdulatai vannak.
Michael-nek lövés közben lehet slow motion-t csinálni, jah.
Franklin-nél meg a vezetés közben csinálja ezt, ahogy elmondtad.Mellette ugyanúgy lehet növelni az állóképességeket, plusz a vezetési, repülési,lövési technikát mint az sa-ban.
Topik szabályok:
- MWC 2026: Újból érik a szeder az Unihertz kertjében
- Elegánsan vizezné be a munkaállomásokat az Artic
- Vicces képek
- Nem lesz Redmi Note 16, évet ugrik a sorozat
- LG 45GR65DC-B 45 / 5120x1440 / 200HZ / VA /
- Chieftec Smart Seriels GPS-500A8 80 Plus minősítésű 500W tápegység
- Apple iPhone 13 - 85% Akku - 128GB - Független - Hibátlan
- HONOR Magic8 Pro 5G 12/512GB (Black) - Új, Kártyafüggetlen, 2029-ig garanciális
- HIBÁTLAN iPhone 15 Pro 128GB Natural Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS4671
- AKCIÓ! Dell XPS 13 9305 13 FHD üzleti notebook -i5 1135G7 8GB DDR4 512GB SSD Intel IRIS XE W11
- MICROSOFT Surface Book 2,13.5", i5-7200U,8GB RAM,256GB SSD,WIN11
- BESZÁMÍTÁS! Részletfizetés 0% THM ÚJ GIGABYTE A16 3VH 16" notebook R7 260 16GB RTX 5060 3 év 27%
Made my day!
Mindenhol ott van a társadalomkritika, ezért is imádom.
CactuS
