St3ven
További infó a honlapjukról:
"Census. When using Zorin OS, your computer may send us a ping which only includes the number of users, an anonymous indicator for the installation, Zorin OEM partner batch (if applicable), and your OS version on an hourly basis. We use this information to count the number of active users of Zorin OS. The indicator is only used by the census to prevent double-counting and does not personally identify you unless you (or someone acting on your behalf) discloses it separately. Below is a sample of the contents of the ping:
{id:"68f2d95b-f51f-4a5d-9b48-a99c28691b89", usercount:"1", oembatch:"", version:"15"}
You may choose to disable these pings by selecting the "Don't participate in the census" option in the Zorin OS installer or entering this Terminal command after installing Zorin OS: sudo apt remove zorin-os-census"
Tehát utólag is el tudod távolítani a census csomagot. -
St3ven
Ahogy a linkelt 2019-es cikk kommentjeiben is írják, egy pipa kérdése a telepítés során, hogy részt veszünk-e a cenzusban.
”Zorin 15.1 just arrived. I installed it, and the "census" question appears on the same screen with "install 3rd party software." The 3rd party software is ticked by default, so that it is installed. But the census question is NOT ticked by default, so you must tick the box yourself to disable the app (which I did).”
St3ven
Az mitől lehet, hogy az alábbi két parancs rendre két különböző értéket hoz a CPU hőmérsékletre? Nem ritkán 10 fokos különbségekkel. Melyik érték a valós?
neofetch --cpu_temp C && inxi -sCPU: Intel i5-6200U (4) @ 2.800GHz [37.0°C]System Temperatures: cpu: 26.0 C mobo: N/A -
St3ven
V.Stryker
#80147
Én 2012 óta használom, Zorin 5.2 verzióval kezdtem. Azóta már a 16-nál tartanak.
A 16-os verzió konkrétan 2025-ig támogatott.
How long will Zorin OS get software updates for?
Zorin OS 16 will receive software updates and security patches until at least April 2025. We normally release major versions every 2 years, so you'll have plenty of time to upgrade to future versions to extend support. -
St3ven
St3ven
St3ven
I02S3F
#79592
Ez látod érdekes, mert most bemásoltam a mókolt parancsikont a többi közé a mappájukba, meg is jelent a start menüben, és onnan indítva használja is a dedikált videokártyát, eddig rendben.
Viszont innen ezt a mókolt változatot a tálcán rögzítve majd onnan elindítva megint csak az integrált videokártyát használja.
@májkimiki
Tudom rögzíteni, így, viszont hiába fut akkor éppen a dedikált kártyával, valamiért ebben az esetben is az alapváltozatot rögzíti. Azaz legközelebb a tálcáról indítva nem a dedikált kártyával fut. -
St3ven
leviske
#79590
Köszönöm, ez lett a megoldás! Gnome felület, ezt elfelejtettem írni.
Már csak annyi a gondom, hogy az asztalon kint van a működő parancsikon, viszont az alsó Gnome panelra azt nem tudom rögzíteni ráhúzással: vagy a Zorin (start) menüből tudok rögzíteni alkalmazást így, vagy az éppen futó alkalmazást így. Utóbbi még jól is hangzik, de az is az "alap" FF indítóparancsot rögzíti, nem pedig a tuningoltat, hiába fut éppen a dedikált videokártyával.
St3ven
Helló!
Lehetséges egy olyan parancsikont kreálni, amire kattintva a Firefox a képen látható módon indulna (a dedikált videokártyát használva)?
Magyarán megtakarítanék minden FF indításkor egy jobbkatt-egérmozdítás kombinációt.
A Google csak szemetet dob ebben a témában, de az is lehet, hogy nem jól keresek.
A rendszer Zorin OS 15.3, nem tudom milyen infó szükséges még. -
St3ven
Két ünnep között a fű sem terem ebben az országban, nemhogy egy PC utazgasson kereskedő-szerviz-kereskedő viszonylatban.
@hcl
Valóban, marad az, csak az üresjáratban érdekes lett volna próbálkozni ezzel-azzal.
Kíváncsi vagyok, mit mondanak majd.Köszönöm a segítséget mindenkinek.
St3ven
- Kiszeded a winyót/SSD-t/amin az OS van
Igen, ez az, amit nem tudok vállalni, főleg így, hogy még garis, pedig amit közvetlenül utána írtál, az frankó lenne SSH-val.
Nyilván diagnosztikai célzattal, ahogy írtátok.@Frawly
Kipróbáltam a zseblámpás módszert, sajnos nem látni semmit.
- Ha helyhiánnyal küzd, vegyen laptopot, ha nem, akkor vegyen rendes asztali gépet.
Azzal küzdök, laptop viszont már van.
St3ven
Köszönöm, hogy utánanéztél a szétbontásnak. Ha szét is lehet valahogy szedni, nem hiszem, hogy azt magam tudnám vállalni.
Az adapter kikerülése jó ötlet, meglátom, mire jutok úgy, tudok-e szerezni monitort. Aztán legrosszabb esetben még mindig jöhet az átalakító.
- Azt mondtad, távolról eléred a Winfost a telefonról (Safe mód után normálban is el kéne indulnia...)
Valamiért a Safe mód óta már nem érem el, pedig direkt nem pipáltam be a Make all boot settings permanent kapcsolót.
- Ha nem, akkor továbbra is, akár live Linux (Bootolható Ubuntu pendrive, amire tettél persistent storage-t, SSH szervert feltenni, bemenni SSH-ról (a gép IP-jét a routeren meg tudod nézni), és megnézni, mit mond a dmesg, lspci, stb stb.
Ezt talán még meg tudom csinálni, csak előtte meg kell oldanom, hogy lássam a képet. Ha összejön, szerintem még jelentkezem az SSH-val kapcsolatban (az nincs telepítve, legalábbis szerver biztosan nem).
- Esetlegesen egy másik gépben felbootolni valamielyik Linuxot a géped háttértáráról, és úgy tenni rá SSH szervert. (Meg esetleg akkor már a Win indítást is ki lehet javítani.)
Na ez nagyon jól hangzik, mert másik gépem legalább van, bár az egy száz éves laptop. Mi lenne ennek a megoldásnak a feltétele?
St3ven
- Ha ugyanazon a gépen 2 OS-sel rossz, akkor az általában nem szoftver gond.
De ha nagyon másik OS verziót akarsz indítani, akkor kiszeded a winyót, , vagy távoli eléréssel átírod a GRUB sorrendet win alól, és úgy elindul az, amit beállítottál.Amiket elmondtatok, azok után nem tudom, érdemes-e ezt megpróbálnom. Mármint tényleg két OS-t elindítottam már, semmi kép, ráadásul ugye már a legelején az ASUS logó sem jelenik meg.
De ha rosszul értem, hogy mi lenne a cél, akkor kérlek javíts ki, és megpróbálom valahogy ezt a GRUB átírást.
St3ven
& colomb2
Köszönöm a gyors válaszokat.
- Milyen gép ez pontosan? Lehet benne VGA-t cserélni?
Ez egy ilyen gép, az i3-as változat, 2 GB GDDR3 NVIDIA GeForce 930MX karival. Sajnos nem tudom, cserélhető-e.
- Nézd meg távolról, hogy látszik-e az Eszközkezelőben a VGA kártya.
Ezt hogy a legegyszerűbb megtenni?
- Ad-e képet másik kimeneten?
- Monitor jó-e?Van egy régi VGA-s csatlakozójú monitorom, a gépnek meg van egy HDMI kimenete. Ezzel az átalakítóval ki tudom tenni a képét? Csak azért kérdem, mert vannak ilyen átalakítók 8-10 ezerért is.
St3ven
A szakik segítségét szeretném kérni.
Egy évig jól megvolt egy all-in-one ASUS asztali gépen egymás mellett egy Ubuntu 16.04 LTS, egy Zorin és egy Win10, most azonban bekapcsolom a gépet, és csak üres (szürkés fekete) képet látok, még csak a BIOS sem villan fel. Nvidia videokártyám van.A legutolsó Ubuntu (kernel) frissítésre gyanakszom, igaz, a Windowsból történő újraindítás után jelentkezett a dolog.
Egy teljes napig próbálgattam Windows oldalról a google által kidobott találatokat, eredménytelenül.
Ami biztos, hogy feláll a rendszer, mert a grub menüben (vakon) kiválasztva az Ubuntut hallom a dobpergés szignált, amikor betöltött. Az alapból induló Windowsba is be tudok (vakon) jelentkezni, sőt, a WinPhone-omon látom is a képernyőt, ha rácsatlakozom a gépre wifin.
Illetve utóbbi csak múlt idő, mert sikerült elérni (5. pont), hogy az MS oldalán is javasoltak szerint Safe módban induljon a Windows, ami nem hozta vissza a képet, de legalább már a telefonommal sem tudok rácsatlakozni.
Próbáltam a javasolt billentyűkombinációs dolgokat, fényerőnövelést, eredeti Win helyreállító lemezről bootolni, de semmi kép.Linux oldalról próbáltam:
1. Ctrl+Alt+F1, de semmi nem történik, a legtöbb itt leírt dologhoz meg pont kellene a kép.
2. Live rendszer USB-ről nem indul. Egy ideig villog a pendrive, de nincs kép, szóval még az sem biztos, hogy nem indul...Mi lehet a gond? Hogyan tudnék egy korábbi Ubuntut elindítani? Így talán kiderülne, hogy szoftveres, vagy hardveres probléma áll fenn.
Itt állok most, legyalulni a gépet nem szeretném, illetve jelen állás szerint nem is tudnám hogyan, mert nem látok semmit.
St3ven
zoltanz
#59252
Syl fórumtárstól származik, azokból az időkből, amikor a WP topikban minden hibára ezt ajánlották, mert egész egyszerűen nem volt más lehetőség. (Például nem frissül az óra csempe meg ilyen szintű problémákra.
És ez nem az oprendszer történetének hőskorában volt, hanem bőven a "csúcson".
St3ven
Egy kis érdekesség, amiben a segítségeteket kérném.
Szeretném, ha Ubuntun képernyőkímélő gyanánt a Firefox indulna el egy adott honlappal teljes képernyősként. Pont, ahogy ebben a posztban írja a kolléga.
What I want is for the application to be run whenever no keyboard/mouse input has been received for N minutes and to disappear (or minimize) after pressing a key.
Kapott rá egy korrektnek tűnő választ, aminek a lépéseit megcsináltam, kivéve az 5. pontot, amit nem értek. Nem a linkelt szkriptet futtattam, hanem manuálisan mentem végig a pontokon, mert szeretném megérteni, hogy mi mit csinál.
Ami nem világos: hogy lesz ebből automatikus indítás mondjuk 5 perc idle állapot után?
Mert most nem történik semmi, bár nem is látom, hogy honnan kellene tudnia a rendszernek, hogy el kell indítania egy programot.
St3ven
ubyegon2
#59012
Hát ja, de mindenhol azt írják, hogy a fizikai RAM méretének kétszerese legyen a swap, ezért állítottam ekkorára.
Más. Most a grubot melyik rendszerről szerkesszem? Mert ugye az újonnan feltelepített 2. Linux felülírta az eddigit. Ha most elindítom az Ubuntut (1. Linux), akkor meg az abban megszerkesztett lesz az érvényes?
St3ven
St3ven
#58989
Itt ha sda6-ra is telepítek egy Linuxot (sda8-on már van egy Ubuntu), akkor swap-nak megadhatom neki ugyanúgy az sda7-en levő 8 gigát?
Tehát nem gond, hogy két disztró is ugyanazt a swap területet használja? Gondolom mivel egyszerre mindig csak az egyik használja, nem probléma, de azért jobb, ha megkérdezem.
St3ven
King Unique
#58995
Köszönöm, hasznos volt, amiket írtatok.
Most keresek valami másik disztrót játszani.
St3ven
King Unique
#58993
Igen, olvastam a hibaüzenetet, azért is kérdeztem meg, hogy növeljem-e meg, vagy jó az is, ha csak formázom. A hibaüzenet szerint ugyanis a 45 MB kevés neki, szóval lehet, hogy a 100 MB elég lenne.
De mindegy is, nekem ekkora kockázatot nem ér meg belenyúlni a partíciós táblába.
Plusz nem is vagyok egy nagy backup-guru, nincs külső vinyóm sem. Inkább nézek másik disztrót.Egyébként meg nem kell túlbonyolítani! Az Ubuntu-alapú rendszereknél működni szokott UEFI-s telepítésnél nemcsak az ESP-re rakott rendszerbetöltő, hanem akár magára a lemezre telepített is.
Akkor át kellene költöztetnem a rendszerbetöltőt? Érdekes egyébként, hogy itt a Solus telepítőjében nem is lehet kiválasztani, hogy hová menjen. Az a két képernyő követi egymást, amit fentebb beraktam, semmi legördülő menü, hogy hova tegye, hacsak nem a 2. képen látható inaktív legördülő lenne az.
Illetve a Solus nem is feltétlen Ubuntu-alapú, legalábbis a DistroWatch adatlapja szerint független.
St3ven
Köszi, megnéztem a linkelt hsz-eket. Bevallom, nem egészen értem, miért kellene belenyúlnom.
A sorrend nem mindegy? Amúgy ez a kimenet:BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0000,0002
Boot0000* Windows Boot Manager
Boot0001* ubuntu
Boot0002* UEFI: KingstonDataTraveler 2.0PMAP, Partition 1 -
St3ven
Meglévő Win10 és Ubuntu mellé szeretném feltenni a Solust, külön partícióra, az alábbiak szerint:
A dual boot tökéletesen működik, ehhez szeretném majd harmadik opcióként hozzáadni a Solust. Viszont a következő lépésnél a bootloadernek nem talál megfelelő helyet:
Innen nem is enged továbblépni. Mit kellene tennem, hogy felmenjen a Solus? Növeljem meg a boot partíciót? Nem szívesen nyúlok bele a fentiek szerint kialakított elosztásba.
Vagy formázzam Live alól azt a 100 MB-ot, mert úgyis létrehozza majd a Solus a grub fájlt a Win10-et és az Ubuntut felismerve? Ez utóbbit meg kockázatosnak látom, mert mi van, ha nem.
St3ven
Köszönöm mindenkinek a visszajelzést. Én is megnéztem, tényleg nem vészes, és viszonylag friss is a 7.1.2.
Nem játékra használnám, inkább csak érdekességképpen.
Egyébként mennek mindenféle launcherek meg widgetek rajta? Csak live USB-n néztem rá, nem adtam meg Google acc-ot sem, volt egy pár leállt ez - leállt az üzenet.
St3ven
Ezzel szerintetek érdemes foglalkozni? Próbálta már valaki?
Ubuntu/Win10mellé, játszásiból.
St3ven
Jelenleg Ubuntu 16.04.4 LTS (Unity) van a gépemen, ha jól olvastam, 2021-ig támogatott.Tetszene az Ubuntu Budgie felülete is, de nem tudom, ezen az oldalon melyiket kellene letöltenem, hogy hasonlóan biztos, hosszú távú támogatást kapjak?
17.10.1 is the current stable release and follows Ubuntu support cadence - Oct 2017 to Jul 2018.
16.04.3 is community supported - it is supported until upstream ends support (no current plans) and thereafter, as long as budgie-remix users wish to maintain its support.A fentiek alapján a 16.04.3 támogatottsága nem tűnik valami konkrétnak, a 17.10.1 viszont csak idén júliusig támogatott.
St3ven
Remix OS-t szeretnék telepíteni dual bootban Ubuntu mellé. Itt akadtam el, és azóta sem tudok rájönni, mit rontottam el.
Röviden: szükséges (?) fájlok felmásolva, grub menü OK, látszólag el is kezd betölteni a rendszer, de az alábbi képnél megáll a folyamat:
Ebből ki tud olvasni valami topiklakó szaki valami olyat, amivel tovább tudnék lépni?
St3ven
zolka95
#30810
Erre a felhasználási területre a Zorin OS tökéletes, ráadásul elég kezes disztribúciónak mondható. Van külön fóruma is, segítőkész szakikkal.
(#30811) EarL 007
Nekem régebben más disztró alatt sok gondom volt a hanggal - többek között a dobozhangú recsegés jelensége - már alap rendszeren is, úgyhogy most, hogy jól működik, nem is merek hozzányúlni. -
St3ven
Ubuntu alapokra építkező Zorin OS 9-en mit kellene engedélyezni, hogy rendesen menjen a Skype?
Látszólag simán bejelentkezik, de pl. a Test Call teljesen süket.
Valamilyen tűzfalbeállítás kellene?Aztán lehet, hogy a hangokkal is gond van: ahol lehet tesztelni a különböző esemény-értesítéseket (login, üzenethang, stb.) ott meg sem mukkan a hangkártya.
St3ven
Ha már Office meg Windows.
Azt látom a Wine-ban, hogy telepíthető a Microsoft Office 2010 is. Ez most valami ingyenes változat? Egyáltalán legális ez?
St3ven
Balul sult el egy Zorin frissites, igy most csak Live rendszerrol megy a gepem, es a legnagyobb baj, hogy nem latom a particioimat, adataimat. Elozmenyek itt, az utolso hsz a lenyeg.
Ezt latja a Gparted:
Viszont az egyik forumtars altal javasolt linken szereplo Testdisk nevu progi meg ezt:
Kerdes: Mire nyomjak most, hogy megmentsem az adataimat?
St3ven
CPT.Pirk
#21389
Most telepít minden frissítést, amit talált. Bár nem látom, éppen hol tart, mert elment minden kép, csak a háttérképet mutatja.
Előbb-utóbb egyébként mindig ez a vége, egy ideig tudom "törölgetni" az asztalt az éppen aktív ablakot cibálva, de akkor is elő-előjönnek a rég bezárt ablakok szellemképei, míg össze nem tojja magát az egész desktop.
St3ven
St3ven
#21384
Hogyan tudok esetleg VGA drivert frissíteni? Mert szerintem ez lehet a gond, már többszöri újraindítás árán, de ki tudtam kapcsolni a Compiz effekteket, meg minden csicsát, de nincs változás. Szóval itt valami rendszerszintű probléma van.
VIA Chrome karim van, és Ubuntu alapokon nyugvó Zorin OS 6.4.
St3ven
CPT.Pirk
#21317
Ha a Zorin OS 6.4-et feltolom az 5.2-es helyére, akkor elég a home könyvtárat elmenteni, majd utána berakni a friss rendszer "alá", hogy megmaradjon minden beállításom, codec-em stb.?
St3ven
CPT.Pirk
#21302
5.2-es verzió van fent.
A csomaginformációk frissítésénél azt írja, hogy
Nem sikerült letölteni minden tároló indexfájlját
Lehetséges, hogy a tároló már nem létezik vagy hálózati problémák miatt nem érhető el. Ha a le nem tölthető indexnek elérhető egy régebbi verziója, az kerül felhasználásra. Egyébként a tároló mellőzve lesz. Ellenőrizze a hálózati kapcsolatát és győződjön meg róla, hogy a tároló címe helyes.
Majd alatta kis ablakban ilyen jellegű hibák tömkelegét dobja:
Sikertelen letöltés: http://hu.archive.ubuntu.com/ubuntu/dists/natty-updates/restricted/binary-i386/Packages 404 Not Found
A rendszert magát még soha nem sikerült frissítenem emiatt a hiba miatt.
Más letöltési forrást is kipróbáltam (mert szemmel láthatóan ez a baja) a Beállítás -> Szoftverforrások fülön (az összes választható magyart és néhány külfüldit is), de ugyanez a hiba.(#21303) bob.zxr:
Megtalálja a Google Chrome-ot, mint frissíthető elemet, de nem enged pipát tenni elé, így nem is érhető el a Telepítés gomb. -
St3ven
A Chrome-ot szeretném frissíteni Zorin alatt, de az Ubuntu Szoftverközpontban nem találok erre lehetőséget.
Ezért letöltöttem a Google-től egy google-chrome-stable_current_i386.deb nevű fájlt, amit ha "elindítok", bejön a Szoftverközpontban az adatlapja, ahol inaktív a Telepítés gond, és ez szerepel alatta:
A következő függőség nem elégíthető ki: gconf-service
1. Ezzel mit tudok kezdeni, hogy ki legyen elégítve (ha már az kell neki ennyire...)?
2. Hogy lehet egyáltalán frissíteni a programokat, ha nem a Szoftverközpontban? -
St3ven
Köszi CPT.Pirk, colomb2, bob.zxr, istenek vagytok!
St3ven
CPT.Pirk
#19070
Igen, van olyan menüpont, ott a jogosultságok fül alatt root szerepel, és nem is állítható semmi, minden ki van szürkítve.
@colomb2:
Ez lesz a megoldás, de mit jelent ez?
"mind a kettőnél -R kapcsolóval tudod rekurzívan futtatni"Azaz mit kell nekem beírni a terminálba, hogy adott mappához hozzáférjek? Pl. azt a kapcsolót, amit nem tudom, mit jelent, hova írjam?
És köszönöm mindkettőtöknek!
St3ven
Akkor kérdezek mást.
A fájlkezelőben (Nautilus) látok mappákat megjelölve egy piros körben lévő iksszel. Az ezekben a mappákban lévő fájlokat nem tudom megnyitni ("Hozzáférés megtagadva"). Hogyan állíthatom be a hozzáféréseket?
Természetesen a root jelszót tudom, én hoztam létre, nem is értem, hogyhogy nem tudok indítani, de legalább szövegszerkesztőben megtekinteni bizonyos fájlokat....
St3ven
Nem tudja valaki, hogy Ubuntu alatt hol találhatók a LibreOffice ideiglenes fájljai?
Egy szerkesztés alatt álló doksim egy rendszerfagyás miatt elszállt, és csak egy 0 bájtos fájl maradt belőle, ennek szeretném egy korábbi állapotát valahogy visszahozni, ha mást nem, legalább a szövegét.
A /tmp-ben nincs semmi ilyen jellegű állomány, csak csupa illesztőpont típusú 0 bájtos fájl.
St3ven
ViZion
#17659
& kispx:
Köszönöm mindkettőtöknek, törlöm is őket.
@ViZion:
Én a Zorin 5.2-es verzióját használom, kisebb bugokkal találkoztam. Néha villódzik a "tálca" jobb oldala (az óra és annak környékén található modulok), a Médialejátszóval pedig ha valamit megnyitok, úgy 95%-ban kidob a bejelentkező képernyőhöz, minden ablakot bezárva. A Chrome meg néha fogja magát, és csak úgy magától egy szempillantás alatt eltűnik, mintha meg sem lett volna nyitva.Szóval igen, vannak bugok.
St3ven
Szinte mindegyik partíción található egy $RECYCLE.BIN és egy RECYCLER mappa. Ezeket a linux használja (Zorin OS), vagy még a windowsos korszakból maradhattak hátra?
Úgy is kérdezhetném, hogy törölhetők?
St3ven
St3ven
#17060
Ha bekapcsolt wifinél adom ki a sudo hostapd hostapd.conf parancsot, akkor pedig ezt írja ki:
Configuration file: hostapd.conf
Failed to set interface wlan0 to master mode.
nl80211 driver initialization failed.
ELOOP: remaining socket: sock=5 eloop_data=0x8d67a30 user_data=(nil) handler=0x8087b60 -
St3ven
Ubuntu (pontosabban ZorinOS) alatt szeretnék virtual router-t készíteni ez alapján, ám az utolsó lépésnél a következő hibaüzenetet kapom:
ioctl[SIOCSIFFLAGS]: Operation not possible due to RF-kill
nl80211 driver initialization failed.Mit kellene tennem, hogy tovább tudjak lépni?
St3ven
Rimuru
#16380
Működik!
Igazából nem tudom pontosan, hogy az utasításaid alapján valójában mit csináltam, de örök hála - csakúgy, mint CPT.Pirk-nek még korábbról.
Érdekes egyébként, hogy az ext4-es partíciót is átírva a fenti szintaktikával nem működött a dolog - alig akart elindulni a gép - de visszaírva erre már minden simán ment:
#Data
/dev/sda8 /media/Data ext4 users,rw,noatime,exec 0 0 -
St3ven
CPT.Pirk
#16135
# /etc/fstab: static file system information.
# Use 'blkid -o value -s UUID' to print the universally unique identifier
# for a device; this may be used with UUID= as a more robust way to name
# devices that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda1 during installation
UUID=50d0224c-2593-48e6-a0c9-184791aa3263 / ext4 errors=remount-ro,noatime 0 1
# swap was on /dev/sda9 during installation
UUID=e796f189-ce06-4827-9769-8578cdedc605 none swap sw 0 0
#Data
/dev/sda8 /media/Data ext4 users,exec,rw,noatime 0 0
#Misc
/dev/sda7 /media/Misc ntfs-3g users,exec,rw,noatime 0 0
#Backup
/dev/sda5 /media/Backup ntfs-3g users,exec,rw,noatime 0 0
#Steve
/dev/sda6 /media/Steve ntfs-3g users,exec,rw,noatime 0 0Átírtam az fstab-ot, hogy a media alá csatolja a partíciókat, de így sem enged semmit sem a Kukába rakni.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Xbox tulajok OFF topicja
- Call of Duty: Black Ops 7
- Milyen videókártyát?
- Milyen okostelefont vegyek?
- AliExpress tapasztalatok
- Mindenkinél több és erősebb AI gyorsítót ígér Elon Musk
- Árváltozás+játék!The Witcher 2 Assassins of Kings Collector's Edition
- GYÖNYÖRŰ iPhone 13 128GB Pink -1 ÉV GARANCIA - Kártyafüggetlen, MS3431, 100% Akkumulátor
- Thinkpad L13 Yoga i5-10210U 16GB 1000GB 13.3", Touch gyári magyar világítós bill 360 Gar.: 1év
- Bomba ár! Lenovo X1 Yoga 1st - i5-6G I 8GB I 512SSD I 14" FHD Touch I HDMI I W11 I CAM I Garancia
- BESZÁMÍTÁS! ASUS TUF A17 FA707NV notebook - R7 7735HS 16GB DDR5 1TB SSD nVidia RTX 4060 8GB WIN11
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RX 7800 XT 16GB GAMER PC termékbeszámítással
Hát, lehet, hogy akkor inkább tableten fogom használni a Skype-ot. Most van egy nagyon jól belőtt rendszerem, nem akarom tönkrevágni a hangot.
