strategos
AKINEK VAN NEW I7 I9, VAGY AMD LEGUJJABJAIBOL MEGNÉZNÉ MIT TUD Firefox Nightly 59.0a1 ALATT
A https://nimiq.com/miner/# - RELELŐRE IS KÖSZÖNÖM!
strategos
strategos
#31374
Ctrl+shift+j - ide kell beirni
Xeon E5-2630 Crome alatt($.miner.threads = 6) - 3.6 khs / 25% cpu usage
($.miner.threads = 12) - 5.6 khs / 47% cpu usage
($.miner.threads = 24) - 9.7 khs / 85% cpu usage
($.miner.threads = 40) - 10.8 khs / 100% cpu usage---------------------
strategos
strategos
#31372
Ctrl+shift+k - ide kell beirni
Xeon E5-2630 Firefox Q-val
($.miner.threads = 6) - 5.45khs / 25% cpu usage
($.miner.threads = 12) - 8.4khs / 47% cpu usage
($.miner.threads = 24) - 13.6khs / 85% cpu usage
($.miner.threads = 40) - 15.5khs / 100% cpu usageTehát nem lineárisan növekszik a hatásfok...
Szétválaszott cpu (2-3 magonként), lenne majd ideális (több win futtatása egy gépen, persze ha ip figyelése ezt engedni fogja) -
strategos
siemenss65
#31249
https://docs.google.com/spreadsheets/d/1RjU6aQnRcXj6RQOGkG8DAscFjWyV1axdSECJbWy0c7c/edit#gid=0
itt van már lista
i7 6700k -val - nem huzott 3 kH
E5 Xeon 2630 - 7.8 khelvileg a Ryzen 1800X 9 kh - tud valaki tesztet ezzel?
köszönöm
strategos
madpapa
#26675
http://whattomine.com/asic?utf8=%E2%9C%93&sha256f=true&factor%5Bsha256_hr%5D=14000.0&factor%5Bsha256_p%5D=1370.0&scryptf=true&factor%5Bscrypt_hash_rate%5D=124.55&factor%5Bscrypt_power%5D=1370.0&x11f=true&factor%5Bx11_hr%5D=2000.0&factor%5Bx11_p%5D=400&qkf=true&factor%5Bqk_hr%5D=450.0&factor%5Bqk_p%5D=75.0&qbf=true&factor%5Bqb_hr%5D=450.0&factor%5Bqb_p%5D=84.0&factor%5Bcost%5D=0.1&sort=Profitability24&volume=0&revenue=24h&factor%5Bexchanges%5D%5B%5D=&factor%5Bexchanges%5D%5B%5D=bittrex&factor%5Bexchanges%5D%5B%5D=bleutrade&factor%5Bexchanges%5D%5B%5D=btc_e&factor%5Bexchanges%5D%5B%5D=bter&factor%5Bexchanges%5D%5B%5D=c_cex&factor%5Bexchanges%5D%5B%5D=cryptopia&factor%5Bexchanges%5D%5B%5D=poloniex&factor%5Bexchanges%5D%5B%5D=yobit&dataset=&commit=Calculate
X11- Asic coinokra
Brutálisan erős ebben, és keveset is fogyaszt.
strategos
http://wccftech.com/nvidia-pascal-gpu-cryptocurrency-mining-price-specs-performance-detailed/
ennek az árnak már lenne értelme...
strategos
stratum_recv_line failed
Stratum connection interruptedcpu miner error
ötlet, valaki?
strategos
CPU miner problémát ír:
Stratum connection interrupted30 percenként dobálja
körbenéztem de nem találtam jó megoldást rá.
Tud valaki segíteni? -
strategos
http://www.ufominers.com/ethereum-rhinominer-prime
vélemények?
strategos
Valaki felvetette hogy venne
https://as-shop.su/shop/bitmain-antminer-l3-250mhs-400w/itt találtam normal "áron" - szerintetek mennyire kockázatos (lehet használt, felújított)
strategos
siemenss65
#25767
Aha, kösz az infot, akkor tök homály, hogy mi fog itt számítani teljesitményben....
strategos
strategos
#25761
Azt irja WebAssemblyfogja használni (is)
Erre itt egy benchmark
http://kripken.github.io/Massive/beta/#benchmarks"Isn’t mining on a browser less efficient than the usual way?
Not necessarily. With WebAssembly you can get near-to-native performance. Our Betanet is based on WebCrypto API, which is native as well, but we can’t put the whole mining logic into it. So we have a lot of context switches and slow tasks in JavaScript, which are affected by UI work. Our final client will use WebAssembly for the whole mining and WebWorker to offload the work from the UI thread."Hát majd kiderül mi kell neki, ha elindul.
strategos
siemenss65
#25755
igazad van
"Our Betanet PoW is plain sha256 so you could easily set up a miner with high hashrates. This is fine for testing purposes. The final PoW will be memory-latency-bound and implemented in (or compiled to) WebAssembly, which reaches close to native performance in modern browsers."
(tegnap indult el a Crowdsale, már 50% megvan!!!)
strategos
paperboy
#25733
Ha kis amd gépet raknánk össze, leggyorsabb (olcsó) procival
AMD A6 6420K Processzor - Dual Core - 4GHz - FM2 - AD642KOKHLBOX
10 700
http://smartshop.hu/amd-a6-6420k-processzor-dual-core-4ghz-fm2-ad642kokhlbox.html
https://www.pcland.hu/asrock-a88m-itxac-alaplap?forras=3
21.860
ALAPLAP - ASROCK A88M-ITX/AC ALAPLAP - wifi
KINGSTON FURY BLACK 4GB DDR3 1866MHZ CL10
8.140
https://www.pcland.hu/kingston_4gb_ddr3-1866mhz_non-ecc_cl_10_dimm_-hx318c10fb4?forras=3
FUJITSU RADEON HD 5450 512MB GDDR3 (288-1E127-030FS) VIDEOKÁRTYA
3000
https://www.konzolokszervize.hu/pc/kiegeszitok/fujitsu-radeon-hd-5450-512mb-gddr3-288-1e127-030fs-videokartya
Approx APP500LITEB01 500W
3.480
https://www.arukereso.hu/tapegyseg-c3158/approx/app500liteb01-500w-p332994357/
http://www.easy-shop.hu/lc-power-matx-2009mb-micro-atx-mini-itx-fekete-szamitogep-haz.html
Ház 4760
49.700ft / ? kh/sPersze le kéne testelni mennyit tud
Egyébb ötlet? (azon kivül hogy a cégben az összes gépet elindit)
strategos
X5670 2.93GHZ - 2,2-3 kh/s - xeon amúgy is lomha
strategos
strategos
#25675
http://www.friendlyarm.com/index.php?route=product/product&product_id=123
ez nagyon olcsó, és nem elég kompakt és lassucska 1,4ghz
merthogy ugye telefonon is lehet futtatni:
Xperia™ Z5 Premium (64 bites, nyolcmagos processzor; négymagos, 2,0GHz+; négymagos,1,5 GHz)- 1kh/s -
strategos
Ha jó lértelmezem az adatokat igy hírtelen, akkor cpu sebessége számít (nem a magok száma) - és ehez jól igazodó ram, aminek csak az időzitése számít (latency) - nem vagyok ram tunningos, ha valaki ért hozzá lefutathatna egy memoria modositást úgy, hogy a latency a legkisebb legyen cpu mem között.
Látnánk hogy van e érdembeli különbség.Teljesen gondolati sikon:
Lehet elég 1 magos 1-2 ghz körüli procikbol építeni riget
pl https://www.youtube.com/watch?v=z5EXNfHYPfQ
persze itt gondolom számít az alaplap bus sebessége stb stb -
strategos
Más, NIMIQ mining
https://nimiq.com/betanet/ - itt fut egy test belőlepár hónap és elindul - cpu és memory késleltetéssel lehet majd bányászni,
- nem fogyaszt áramot pluszba!
- nem terheli a gépet! (de ha fut alkalmazás ami leköti a cpu-t akkor kisebb a termelés)arra gondoltam ha van kedvetek ráfeküdhetnénk a témára, lehet e "riget" építeni köré.
Átlagos pc 9-18 kh/s tud.Összeirhatnánk kinek mennyit tud a gépe, legyen rálátásunk mitöl függ, igazán.
cpu: i7 6400k
alaplap: z170A
mem: Kingston 3067 hz (16gb)20-28 kh/s
strategos
LógaGéza
#25663
Hatalmas potenciál van benne, 2 hónap és kijön vray 3.0 cpu + gpu render egyben, egy ilyen 6-os mining géppel a renderidő elpárolog, ez rengeteg pénzt jelent egy-egy munkánál!!!!!
Szinte eltörpül amellett hogy mit lehet kibányászni vele!
Felvetem a cégben hogy építsünk ezekböl render parkot, vagy én építek és bérbe adom...Csatlakozik valaki?
(lehet ezt le se kellett volna irnom)
strategos
A speciális mining videokártyák okán jutott eszembe hogy számoláshoz, rendereléshez lehet e használni.
3dmax vray gpu render-hez tökéletes lehet (olcsó és sok lessz majd).
ha valaki vesz ilyet, kérném tesztelje le ha módjában áll.
(GTX természetesen)
Köszönöm. -
strategos
Az lehetetlen hogy nem találsz, legalább viszonyítási alapot, amúgy letöltése a miner 5perc, és kiderül
strategos
https://nimiq.com/betanet/ - egy kis érdekesség (na ez kb az aminek kéne...)
strategos
http://bitbaza.com/shop/27/desc/pangolin - már lehet is venni....
strategos
Oazis-ban látok RX 470- 8G -et
strategos
Sidorovich
#24764
Exodus
strategos
Ki milyen altcoin kereskedő oldalt használ? Mit ajánlotok?
- Egyszerű használat, átláthatóság, megbizhatóság stb szempontok szerint? -
strategos
Titeket nem zavar ez a sok nagy GPU-"Csarnok" megjelenése?
Valahol pont a lényeg veszik el az egészben.....Nem lehetne egy olyan coint készíteni ami már az átlag emberekről szól?
pl., hogy a miningnél már 1 ember 1 gép (ip alapján stb) korlátozni...sokkal szétszórtabb lenne, daraboltabb a birtoklása...sokkal szimpatikusabb lenne mindenkinek, és stabilabb is az árfolyam.
Technikailag kérdem hogy szerintetek hogy lehetne lekorlátozni a csákányozást ?
Csak gondolati síkon......Most az bontakozik ki hogy néhány nagy "csarnok" előbányász mindent ami van, majd eladja amikor kilő az árfolyam, vagy maguknak rántják fel az árfolyamot....
strategos
Közvéleménykutatás!
Mennyit fogyaszt havonta rig több kártyás megoldás?Ft:
strategos
3 hónap múlva ilyen diff növekedés mellett már nem fogja megérni ETH csákányozni....
Van esetleg más altcoin ami new és érdemes bányászni? -
strategos
Tudtok esetleg new altcoin-ról, ami nemrég indult, vagy csak tervezik elindítani?
strategos
A GPU terhelését próbálom beálítani :
# WARNING! Remove "#" characters to enable lines, with "#" they are disabled and will be ignored by miner! Check README for details.
# WARNING! Miner loads options from this file only if there are not any options in the command line!#-epool eu1.ethermine.org:4444
#-ewal 0xD69af2A796A737A103F12d2f0BCC563a13900E6F
#-epsw x
#-dpool stratum+tcp://yiimp.ccminer.org:4252
#-dwal DsUt9QagrYLvSkJHXCvhfiZHKafVtzd7Sq4
-ethi 4
-gser 2
-erate 1
-estale 1
-colors 1
#-dpsw x
#-esm 1
#-mode 0
#-tt 60
#-asm 0De nem álítja a program (win7 gtx1080) - mindig 100% dolgoztatja
(Claymore's Dual Ethereum+Decred_Siacoin_Lbry_Pascal AMD+NVIDIA GPU Miner v9.4) -
strategos
Sziasztok a
Claymore's CryptoNote GPU Miner v9.7 - nél hogy tudom legegyszerübben csökkenteni a terhelést a config.txt - beállítással?Előre is köszönöm a választ!
strategos
A NiceHash - minnernél, van arra lehetőség hogy a videokártyákat kevesebb%-ban dolgoztassa mint 100%?
strategos
Akkor mégegyszer..
Probáltam beálitani ütemezett inditasként win7 alatt a cudaminert, a set.bat -adtam meg neki, teljes hozzáférést biztositva (full uac). De csak felvillan az ablak majd eltünik.
Valaki használja Task Scheduler-t? Ötlet?
Kösz előre is..
A cudamineröl van szó, a legujabb versio, automatan beállit mindent...
1db kártya van a gépben...
ha manualban inditom a bat filet, kifogastalanul megy minden....Ötlet?
strategos
Kedves, de cudamineröl van szó, a legujabb versio, automatan beallit minden...
ha manualban inditom a bat filet kifogastalanul megy minden.... -
strategos
Valaki használja Task Scheduler-t? Ötlet?Kösz előre is..
- szinteÚJ Nubia REDMAGIC 11 Air (NX799J) 1év gar
- Akciós kisWorkstation! Dell Precision 3570 i7-1255U 4.7GHz / 16GB / 512GB / Quadro T550 4GB FHD 15"
- GYÖNYÖRŰ iPhone SE 2020 256GB Black-1 ÉV GARANCIA - Kártyafüggetlen, MS4003
- G.Skill Aegis 32GB (2 16GB) DDR4 3200MHz ÚJ, AZONNAL KÉSZLETRŐL
- iPhone 17 Pro Max Silver - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok !!
