Mikrotik routerekkel foglalkozó téma. Mikrotik router típusok, hardverek, router beállítások, programozás (scriptek írása), frissítés, és minden Mikrotik routerrel kapcsolatos beszélgetés helye.
Lenry
Lenry
What's new in 7.18.2 (2025-Mar-11 13:59):
*) console - fixed issue with file-name completion (introduced in v7.18);
*) container - fixed repository name handling to prevent redirect issues when basic authentication is used;
*) lte - additional fixes for eSIM management support;
*) lte - AT modems, improved redialing when modem lost connectivity without notifying host about APN status change;
*) netinstall - fixed socket reset (introduced in v7.18);
*) queue - fixed system failure when CAKE kind queue was configured but queue type definition does not exist anymore (introduced in v7.18);
*) wifi - improved stability for wifi interfaces;
*) winbox - improve graphing efficiency when communicating with WinBox; -
Lenry
What's new in 7.18.1 (2025-Feb-28 13:31):
*) bridge - improved stability in case of configuration error (introduced in v7.15);
*) bridge - show warning instead of causing error when using multicast MAC as admin-mac (introduced in v7.17);
*) cloud - fixed issues when BTH is toggled fast between enable/disable;
*) cloud - improved "BTH Files" web page design;
*) console - fixed issue with files when using scripts (introduced in v7.18);
*) console - improved file add/remove process stability;
*) dhcpv6-relay - clear saved routes on DHCP release;
*) dhcpv6-relay - show client address;
*) disk - add "sector-size" property in print detail;
*) disk - improved stability when formatting crypted partitions;
*) l3hw - remove VLAN tag before VXLAN encapsulation (fixes pvid behavior for bridged VXLAN);
*) lte - fixed modem recovery after firmware upgrade for R11e-LTE modem;
*) lte - fixed Router Advertisement processing issue for AT modems when an APN with "ip-type=ipv6" was configured;
*) ovpn - disable hardware accelerator for GCM on MMIPS CPUs (introduced in v7.18);
*) poe-out - fixed health showing 0V voltage when using PoE-in for RB960;
*) poe-out - upgraded firmware for 802.3at/bt PSE controlled boards (the update will cause brief power interruption to PoE-out interfaces);
*) route - show BGP session name instead of cache-id;
*) switch - improved stability when enabling IGMP snooping with VXLAN (introduced in v7.18);
*) system - improved internal "flash/" prefix handling for different file path related settings;
*) winbox - fixed missing SMB client on non-ROSE devices; -
Lenry
hogyan tudok wifis eszközt deautholni? csak annyit szeretnék, hogy eldobja egy pillanatra aztán csatlakozzanak is újra (és megkapják az új dhcp konfigot)
Wifi / registrationnél érdemes törölni? vagy a dhcp clientek közül? -
Lenry
RouterOS 7.18
A changelogot most nem másolom ide, mert nagyon hosszú lenne, de alább olvasható -
Lenry
What's new in 7.17.1 (2025-Jan-30 12:29):
*) bgp - improved stability;
*) bridge - fixed endless MAC update loop (introduced in v7.17);
*) dhcpv4-server - fixed lease assigning when server address is not bind to server interface (introduced in v7.17);
*) igmp-proxy - fixed multicast routing after upstream interface flaps (introduced in v7.17);
*) ipsec - fixed chacha20 poly1305 proposal;
*) ipsec - fixed installed SAs update process when SAs are removed;
*) ipv6 - fixed an issue where bridge, IP, IPv6 and discovery settings were lost after upgrade due to conflicting IPv6 properties (introduced in v7.17);
*) ovpn - added requirement for server name when exporting configuration;
*) ppc - fixed HW encryption (introduced in v7.17);
*) queue - improved system stability when many simple queues are added (introduced in v7.17);
*) resolver - fixed static FQDN resolving (introduced in v7.17);
*) system,arm - automatically increase boot part size on upgrade or netinstall (fixed upgrade failed due to a lack of space on kernel disk/partition);
*) winbox - show warning messages for static DNS entries; -
Lenry
What's new in 7.17 (2025-Jan-16 10:19):
!) device-mode - after upgrade, mode "enterprise" is renamed to "advanced" and traffic-gen, partition (command "repartition"), routerboard and install-any-version features will be disabled;
!) webfig - redesigned HTML, styling and functionality;
*) 6to4 - fixed issue where 6to4 relay would not forward traffic unless destination address is set;
*) adlist - improved logging;
*) adlist - improved system stability;
*) adlist - optimized import on system with low disk space;
*) api - fixed REST API serialization of binary data;
*) arm64 - fixed for bare-metal servers to be able to access more than 2GB RAM;
*) arm64 - show CPU frequency on bare-metal installations;
*) arm64/x86 - added missing PCI id for mlx4 driver;
*) bonding - hide mlag-id property on non-compatible devices;
*) bridge - add HW offload support for active-backup bonds on 98DXxxxx, 88E6393X, 88E6191X and88E6190 switches;
*) bridge - added interface-list support for VLANs;
*) bridge - added message for inactive port reason;
*) bridge - added priority setting to manually elect primary MLAG peer;
*) bridge - correctly display PPP interfaces in VLAN menu;
*) bridge - disallow duplicate static VLAN entries;
*) bridge - disallow multicast MAC address as admin-mac;
*) bridge - enable faster HW offloading when detect-internet is disabled;
*) bridge - fixed first host table response for SNMP;
*) bridge - fixed incorrect HW offloaded port state in certain cases on MSTI add;
*) bridge - fixed missing slave flag on port in certain cases;
*) bridge - fixed MVRP registrar and applicant port options;
*) bridge - fixed port monitor with interface-lists;
*) bridge - fixed port move command;
*) bridge - fixed setting bridge MTU to L2MTU value;
*) bridge - fixed VLAN overlap check;
*) bridge - ignore disabled interfaces when calculating bridge L2MTU;
*) bridge - improved port handling;
*) bridge - improved stability;
*) bridge - prioritize MAC selection from Ethernet interfaces when using auto-mac feature;
*) bridge - re-synchronize MLAG system-id when bridge MAC changes;
*) bridge - removed support for master port config conversion (used before version 6.41);
*) bridge - update dynamic MSTI priority value when changing configuration;
*) bth - improved stability on system time change;
*) certificate - do not download CRL if there is not enough free RAM;
*) certificate - do not show not relevant values for certificate template (CLI only);
*) certificate - fixed handling of capsman-cap certificates (introduced in v7.16);
*) certificate - removed unstructured address field support;
*) chr - added Chelsio VF driver for PCIID 5803;
*) chr/arm64 - fixed kernel crypto use without crypto extensions for RPi CM4;
*) cloud - changed ddns-enabled setting from "no" to "auto" (service is enabled when BTH is enabled);
*) cloud - improved DDNS and VPN state stability;
*) console - added :range command;
*) console - added group-by property for print command;
*) console - added json.no-string-conversion to :serialize;
*) console - added lf/crlf options to :convert transform;
*) console - added more argument definitions for mac-protocol property;
*) console - added password property to "/system/ssh-exec" command;
*) console - added to/from=num option for :convert command;
*) console - allow clearing history for a specific user;
*) console - allow setting width to supout.rif output;
*) console - clear history when removing user;
*) console - disallow autocomplete hints for user without read policy;
*) console - execute :return command without error;
*) console - fixed endless loop when closing input prompt;
*) console - fixed missing arguments in wifi menu in certain cases;
*) console - force print paging when output does not fit terminal width;
*) console - improved printing output in some menus;
*) console - improved scripting system stability;
*) console - increased w60g scan-list size to 6;
*) console - print warning in CLI after enabling protected bootloader;
*) console - removed "chain" names from print parameter list and show all print parameters in "/ipv6/firewall/filter" directory;
*) console - show system-id in export for CHR;
*) console - updated copyright notice;
*) container - allow import from .tar.gz file;
*) container - do not log start, end events unless logging is enabled;
*) container - fixed user and group ID range;
*) container - improved "start-on-boot" stability;
*) container - improved container shell;
*) crypto - improve crypto speeds;
*) crypto - use hardware accelerator for GCM cipher in TLS connection on Alpine CPUs;
*) defconf - changed wireless installation from "indoor" to "any";
*) defconf - disable 5GHz secondary channel on RB4011;
*) defconf - do not add default password for CAP mode configuration on older Audience devices without a password;
*) defconf - fixed new port name recognition;
*) detnet - remove dynamic DHCP client creation;
*) device-mode - added "allowed-versions" list which are allowed to be installed without "install-any-version" mode enabled;
*) device-mode - added "basic" mode;
*) device-mode - added routerboard, install-any-version and partitions features;
*) device-mode - allow feature and mode update on x86 via power button and reboot/shutdown from AWS;
*) device-mode - fixed feature and mode update on ARM64 Hetzner;
*) device-mode - fixed feature and mode update via power-reset on MIPSBE devices;
*) device-mode - limit "/tool/ping-speed" and "/tool/flood-ping" under "traffic-gen" feature;
*) device-mode - limit device-mode update maximum allowed attempt count which can be reset only with reboot or button press;
*) device-mode - provide more precise device-mode update action printout;
*) device-mode - show all features and active restrictions with "print" command;
*) dhcp-relay - added "local-address-as-src-ip" property;
*) dhcp-server - use interface ID for NAS-Port and added interface name to NAS-Port-ID attribute in RADIUS requests;
*) dhcp-server - use single RADIUS accounting session for IPv4 and IPv6 when dual stack is used;
*) dhcpv4-client - correctly handle adding/setting emtpy dhcp-options;
*) dhcpv4-client - fixed crash when releasing disabled DHCP client;
*) dhcpv4-client - respect Renewal-Time (58) and Rebinding-Time (59) options;
*) dhcpv4-server - do not remove options set config when DHCP network is changed;
*) dhcpv4-server - properly detect DHCP server address when underlying interface has multiple IP addresses configured;
*) dhcpv4-server/relay - added additional error messages for DHCP servers and relays;
*) dhcpv4/v6-server - added address-list parameter to which address will be added if the lease is bound;
*) dhcpv6-client - added prefix-address-list parameter;
*) dhcpv6-client - improved system stability when DHCPv6 client is enabled on non-existing interface;
*) dhcpv6-client - log message when response with invalid transaction-id received;
*) dhcpv6-client/server - added support for DHCPv6 reconfigure messages;
*) dhcpv6-server - added IPv6 address delegation support;
*) dhcpv6-server - do not require "prefix-pool" to be specified;
*) dhcpv6-server - fixed DHCPv6 server "address-pool" property showing in command line as "unknown" when real value is "static-only";
*) dhcpv6-server - improved system stability when removing actively used DHCPv6 server;
*) dhcpv6-server - include all existing prefixes (with lifetime 0) in renew reply and new prefix if RADIUS returns different prefix;
*) dhcpv6-server - properly display "static-pool" value in server print output for "prefix-pool" argument;
*) discovery - added support for LLDP DCBX;
*) discovery - use LLDP description field to populate platform, version and board-name;
*) disk - added "type=file" for file-based block devices, useful for using file as a swap, or when having file-based filesystem images (CLI only);
*) disk - added btrfs filesystems list (CLI only);
*) disk - added mount-read-only and mount-filesystem options to allow read-only mounts and prevent mounting device at all (CLI only);
*) disk - added sshfs client to "/disk" menu (CLI only);
*) disk - added support for SWAP, currently allowed on any block device with "set x swap=yes" when container package is installed (CLI only);
*) disk - allow to configure global and per disk mountpoint template - [slot],[model],[serial],[fw-version],[fs-label],[fs-uuid],[fs] variables supported;
*) disk - auto mount iso and squashfs images;
*) disk - fixed managing and cleaning up mount points;
*) disk - fixed raid role auto selection for up to 64 drives;
*) disk - improve slot naming and improvements for visualizing complex hardware topology;
*) disk - improve test to report zero byte iops;
*) disk - improved system stability;
*) disk - read/show exfat filesystem label;
*) disk - recognize virtual sd* interfaces;
*) disk - remove 32 character slot name limit;
*) disk - save raid superblock and raid bitmap superblock on member devices in 1.2 format/location;
*) disk - show detailed mountpoint users when unable to unmount;
*) disk - show usage as percentage (CLI only);
*) disk - try all NFS versions (4.2,4.1,4.0,3,2) when mounting NFS in that order;
*) disk,nvme - show nvme namespaces if configured more than one on a nvme drive;
*) dns - added option to create named DNS servers that can be used as forward-to servers;
*) dns - do not look up local cache when executing ":resolve" command with specified "server" parameter (introduced in v7.16);
*) dns - DoH whitelist support for adlist using static FWD entries;
*) dns - refactored DNS service internal processes;
*) dns - whitelist support for adlist using static FWD entries;
*) ethernet - improved interface stability for RB4011 devices;
*) ethernet - improved linking after reboot for hAP ax lite devices ("/system routerboard upgrade" required);
*) ethernet - improved stability after reboot for Chateau PRO ax;
*) ethernet - improved system stability for CCR2004-1G-2XS-PCIe device;
*) ethernet - log warning only about excessive broadcast (do not include multicast) and reduced log count;
*) fetch - fixed certificate check when provided hostname is IP address;
*) fetch - fixed large file (over 4GB) fetch in HTTP/HTTPS mode;
*) file - correctly identify mounted disks;
*) file - do not needlessly scan large filesystems, could prevent unmounting;
*) file - improved handling of changes to the file system;
*) file - improved service stability when accessing files list from other system services;
*) file - support files over 4GB size;
*) file - update file size before trying to request content;
*) firewall - added none-dynamic and none-static arguments for IPv6 address-list-timout settings;
*) firewall - added support for random external port allocation;
*) firewall - added warning log for TCP SYN flood;
*) firewall - fixed "dst-limit" and "limit" mathers when using zero value for burst argument;
*) firewall - improved matching from deeply nested interface-lists;
*) firewall - removed default mangle passthrough=yes configuration from export;
*) ftp - added VRF support;
*) gps - changed default GPS antenna setting for LtAP mini with internal LTE/GPS combo antenna;
*) graphing - fixed graphing rule removal;
*) graphing - fixed queue graph storing on disk;
*) health - added cpu-overtemp-check on ARM, ARM64 devices (CLI only);
*) health - changed PSU state from "no-ac" to "no-input";
*) health - hide settings in CLI if there is nothing to show;
*) health - removed board-temperature on RB5009UPr+S+IN device;
*) igmp-proxy - refactored IGMP querier;
*) ike2 - improved performance by balancing multicore CPU usage for key exchange calculation also for initiator;
*) iot - added additional debug for LoRa logging;
*) iot - added an option to print out LoRa traffic in CLI (not GUI-only option anymore);
*) iot - added new LoRa traffic FCnt packet counter parameter;
*) iot - added support for USB Bluetooth dongles (LE 4.0+) which enables Bluetooth functionality;
*) iot - bluetooth peripheral device menu now displays correct iBeacon major/minor values;
*) iot - fixed duplicate LoRa payloads in the traffic tab;
*) iot - fixed incorrect LoRa joineui filter export behavior;
*) iot - fixed LoRa behavior, where join eui or dev eui could be incorrectly converted during forwarding;
*) iot - improved system stability for LoRa;
*) iot - improvements to LoRa device's stats tab;
*) iot - LoRa LNS improvement;
*) iot - LoRa traffic tab RSSI now shows proper values for ARM architecture;
*) iot - modbus rework which improves Tx Rx switching behavior;
*) iot - mqtt improvement to support large payloads and gracefully discard payloads above size limit;
*) iot - removed crc-disabled and crc-error options from the LoRa forwarding;
*) iot - removed LoRa pause traffic option/setting;
*) iot - removed some LoRa radio related parameters (e.g. RSSI-OFF and Tx-enabled) that were not meant to be changed;
*) ippool - removed maximum "63 bit" prefix length limitation;
*) ipsec - ike2 improved process for policies;
*) ipv6 - added comment property to "/ipv6/nd/prefix" menu;
*) ipv6 - added IPv6 settings related to stale IPv6 neighbor cleanup;
*) ipv6 - added support for manual link-local address configuration;
*) isis - do not disable fast-path when isis is enabled on an interface;
*) isis - fixed console flags;
*) isis - fixed invalid L2 LSP type;
*) isis - make it work when MTU is larger than 1500;
*) isis - update interface MAC address on change (caused neighbor to stuck in init state);
*) kid-control - use time format according to ISO standard;
*) l3hw - improved system stability;
*) l3hw - rate limit error logging;
*) leds - fixed issue where interface LEDs might not properly disable in some cases;
*) log - added basic validation for "disk-file-name" property;
*) log - added hostname support to remote logging action;
*) log - added regex parameter for log filtering in rules;
*) log - fixed e-mail logging (introduced in v7.16);
*) log - use time format according to ISO standard;
*) lte - added option to check/install modem firmware from early-access/testing channel (CLI only);
*) lte - added provider specific firmware update (FOTA) for Cosmote GR networks on Chateau 5G;
*) lte - disabled ims service for Chateau 5G on operator "3 AT" network (PLMN ID 23205);
*) lte - drop operator selection support for R11e-4G modem as it is unreliable;
*) lte - fixed "default-name" property in export when multiple LTE interfaces are used;
*) lte - fixed "lte monitor" signal reporting for RG520F-EU modem when connected to 5G SA network;
*) lte - fixed "operator" setting for EC200A-EU modem;
*) lte - fixed long "PLMN search in progress" for SXT 3-7;
*) lte - fixed LTE band setting for SXT LTE 3-7;
*) lte - fixed roaming barring (allow-roaming=no) for EC200A-EU modem;
*) lte - fixed signal info reporting for FG621-EA modem in UMTS network;
*) lte - fixed SMS sender parsing;
*) lte - improved modem FW upgrade for Chateau 5G;
*) lte - improved R11eL-EC200A-EU modem firmware upgrade procedure;
*) lte - improved recovery after unexpected modem reboot for Chateau's 5G and 5G R16 series devices;
*) lte - improvements to modem "firmware-upgrade" command;
*) lte - MBIM increased assignable APN profile count up to 8 then modem firmware allows it;
*) lte - modem firmware update (FOTA), added support to install provider specific version;
*) lte - removed trailing "F" symbol from uicc;
*) lte - set "sms-read=no" and "sms-protocol=auto" as default values;
*) lte - set IPv6 address reporting format in modem init for AT modems and MBIM modems with AT channel;
*) mac-server - allow MAC-Telnet access through any bridged port when bridge interface is allowed;
*) mac-telnet - use ASCII DEL as erase/backspace char instead of BS (fixes mac-telnet backspace for WinBox4);
*) macvlan - improved error when trying to create new interface on already busy parent interface;
*) macvlan - updated driver;
*) modem - KNOT BG77 modem, improved handling of modem unexpected restarts;
*) mpls - added fast-path support for VPLS;
*) mpls - added MPLS mangle support;
*) mpls - added support for "ICMP Fragmentation needed";
*) mpls - do no drop LDP peering session on PW deactivation;
*) mpls - do not reconnect VPLS on name or comment changes;
*) netinstall - removed unused "Get key" button;
*) netinstall - save and restore device-mode configuration on format;
*) netinstall-cli - added "-o" option to install devices only once per netinstall run;
*) netinstall-cli - fixed x86 detection;
*) netwatch - added "ignore-initial-up" and "ignore-initial-down" properties;
*) netwatch - fixed multiple variables;
*) netwatch - fixed probe toggle when adding a comment;
*) ospf - fixed memory corruption;
*) ospf - improved stability on configuration update;
*) ovpn - added VRF support to OVPN server (server menu now supports multiple entries and previous server configuration is automatically imported);
*) ovpn - improved system stability;
*) ovpn-client - added tls-crypt, tls-crypt-v2 support;
*) ovpn-server - added "user-auth-method" property and allow mschap2 for RADIUS authentication;
*) pimsm - improved system stability after interface disable;
*) poe-out - added low-voltage-too-low status;
*) poe-out - improved PoE-out configuration handling when doing reset-configuration command;
*) poe-out - upgraded firmware for CRS354-48P-4S+2Q+ device (the update will cause brief power interruption to PoE-out interfaces);
*) poe-out - upgraded firmware for PSE (BT) controlled boards (the update will cause brief power interruption to PoE-out interfaces);
*) port - display a warning when using invalid log-file with the "remote-access" feature;
*) port - more detailed print command output, include in "USED-BY" property channel number(s);
*) ppp - add routes in matching VRF;
*) ppp - added support for bridge-port-pvid configuration via ppp profile;
*) ppp - added support for bridge-port-trusted configuration via ppp profile;
*) ppp - do not print local/remote pool related errors in log when configuration does not require pool usage;
*) ppp - fixed typos in log message;
*) ppp - reuse link-local IPv6 address for static bindings when possible;
*) ppp - set APN/PDN type "IPv4/v6" according assigned PPP profile protocol setting;
*) pppoe - added support for PPPoE server over 802.1Q VLANs;
*) profiler - classify ppp processing;
*) profiler - improved process classification;
*) profiler - renamed radv process to radvd;
*) ptp - added dynamic switch ACL rules in order to trap PTP packets to CPU instead of forwarding;
*) ptp - added option to configure L2 transport with forwardable and non-forwardable MAC destination;
*) ptp - added PTP support for CRS320-8P-8B-4S+ and CRS326-4C+20G+2Q+ devices;
*) ptp - display warning when none of the PTP ports has a link;
*) ptp - fixed DSCP values for IPv4 packets;
*) ptp - fixed packet receive with enabled igmp-snooping;
*) ptp - fixed packet tx/rx when enabling PTP on 1/2.5/100Gbps links for 98CX8410, 98DX8525, 98DX4310 switches (introduced in v7.16);
*) ptp - fixed synchronization on QSFP28 interfaces;
*) ptp - make PTP process more stable and deterministic when applying configuration;
*) ptp - restrict configuring g8275 profile with IPv4 transport;
*) qos-hw - allow to disable/enable profiles, disabled or removed profile gets replaced with the default;
*) qos-hw - enabling PFC on port also requires setting egress-rate-queueN;
*) qos-hw - fixed export when changing default Tx Manager;
*) qos-hw - fixed incorrect port byte-use counter;
*) qos-hw - improved PFC behavior;
*) qos-hw - improved system stability when enabling QoS;
*) qos-hw - improved WRED and ECN behavior;
*) qos-hw - rename pfcN-pause and pfcN-resume to pfcN-pause-threshold and pfcN-resume-threshold;
*) qos-hw - reworked PCP and DSCP mapping (now supports single, multiple and range values, previous configuration with minimal value mapping is converted to a single value);
*) qos-hw - switch-cpu port trust settings are forced to "keep";
*) queue - improved system stability when too many simple queues are added;
*) quickset - added "LTE AP" quickset profile with one wifi interface;
*) rip - improved stability when changing metric;
*) romon - added dynamic switch rules on devices supporting it when enabling the service;
*) romon - added interface-list support;
*) romon - send uptime in discovery;
*) rose-storage - allow to set iscsi-iqn only when type=iscsi and allow nvme-tcp-name only when type=nvme-tcp;
*) rose-storage - do not allow to format exported disks;
*) rose-storage - enable autocomplete for local-path property in "/file/sync" menu;
*) rose-storage - enable more threads for faster RAID sync;
*) rose-storage - ensure unique nvme-tcp-names for nvme-tcp clients;
*) rose-storage - improved error messages;
*) rose-storage - improved system stability;
*) rose-storage,raid - improved stability of degraded arrays on startup;
*) rose-storage,raid - store superblock in 1.2 format, show raid super block info when detected to help with reassembling arrays;
*) route - fixed discourse attribute print;
*) route - fixed minor typo in failure message;
*) route - fixed possible issue with inactive routes after reboot (introduced in v7.16);
*) route - improved stability;
*) route - improved stability with static route configuration;
*) route - increased interface name length limit in log messages;
*) route - removed possibility for IPv6 routes to specify interface in the dst-address;
*) routerboot - fixed boot MAC for devices with Alpine CPU ("/system routerboard upgrade" required);
*) routerboot - fixed boot MAC for MIPSBE CRS3xx and CRS5xx switches ("/system routerboard upgrade" required);
*) routerboot - improved stability for IPQ8072 and IPQ6010 when flash-boot is used ("/system routerboard upgrade" required);
*) routing-filter - fixed subtract and add for numerical values (+x, -x);
*) rsync - fixed when used over ssh and spaces in directory names;
*) sfp - fixed 1Gbps supported rate for RB960 and RB962 devices;
*) sfp - fixed linking with 1Gbps optical modules with "combo-mode=sfp" configuration for CRS312 device;
*) sfp - improved initialization and linking for some SFP modules;
*) sfp - improved initialization for certain SFP modules on CRS309 and CRS317 devices ("/system routerboard upgrade" required);
*) sfp - improved power control configuration for QSFP optical modules according to the EEPROM field;
*) sfp - improved SFP auto-negotiation for L22, L23 devices;
*) sfp - improved SFP28, QSFP28 interface stability using DAC cable for CRS520 switch;
*) smb - stability improvements for client/server;
*) snmp - added wifi fields to MIKROTIK-MIB;
*) socks - fixed comment property for access configuration;
*) ssh - added option to configure SSH ciphers (replaced allow-none-crypto parameter);
*) ssh - do not regenerate host key after update from RouterOS version older than 7.9;
*) ssh - improved logging;
*) ssh - improved speed;
*) ssh - prefer GCM ciphers for arm64 and x86 devices when ciphers=auto;
*) ssl/tls - improved performance;
*) sstp - added pfs=required option to allow only ECDHE during TLS handshake;
*) storage - preserve permissions,owners,attributes when syncing under "/file/sync";
*) storage,rsync - fixed to work with clients passing "-a" option;
*) supout - added BGP advertisements section;
*) supout - added device-mode section;
*) supout - do not create autosupout.rif for second time after system reboot;
*) supout - print non BGP and OSFP routes if route list is too large;
*) supout - reduce minimal RAM required for export to be included;
*) supout - use separate LTE section;
*) switch - added "all" argument for "new-dst-ports" switch rule property for CRS3xx, CRS5xx, CCR2116 and CCR2216 devices;
*) switch - added IPv6 flow label matching in switch rules for CRS3xx, CRS5xx, CCR2116 and CCR2216 devices;
*) switch - allow bond interfaces in switch rules for CRS3xx, CRS5xx, CCR2116 and CCR2216 devices;
*) switch - allow matching network bitmask for IPv4 and IPv6 dst/src-address properties in switch rule;
*) switch - disallow switch-cpu in "ports" and "new-dst-ports" rule properties for CRS3xx, CRS5xx, CCR2116, CCR2216 and RB5009 devices;
*) switch - fixed a potential issue with packet corruption caused by incorrect switch initialization on CRS3xx/5xx devices;
*) switch - fixed L2MTU for 25Gbps ports;
*) switch - fixed RSPAN error message when using mirror-target=cpu;
*) switch - fixed rule disable in certain cases for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) switch - fixed storm-rate accuracy on 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) switch - force "mac-protocol" when matching IPv4 or IPv6 specific properties;
*) switch - improved CPU performance for CRS328-24P-4S+ switch;
*) switch - improved system stability for RB5009 and CCR2004-16G-2S+ devices;
*) switch - make switch rule "ports" property not required and unsettable (allows matching packets on all switch ports);
*) switch - updated dynamic switch rules when using HW bridge with IGMP snooping (224.0.0.0/24 and ff02::/16 destination addresses are forwarded and copied to CPU);
*) system - improved IPv6 maximum routing table size based on total memory;
*) system - make ICMP error source address selection configurable (icmp-errors-use-inbound-interface-address parameter in ip settings);
*) system - make TCP timestamp handling configurable (tcp-timestamps parameter in ip settings);
*) system - moved "/system/upgrade" to "/system/package/local-update";
*) tftp - improved stability;
*) upnp - rename service description file from gateway_description.xml back to gateway.xml;
*) user-manager - improved stability;
*) vpls - added support for bridge-pvid configuration;
*) vrf - fixed packet handling with enabled queues;
*) vxlan - fixed issue causing to loose IPv6 VTEP address setting;
*) webfig - added search option for settings;
*) webfig - allow download from file details;
*) webfig - allow style.css and script.js in branding packages;
*) webfig - fixed uploading files with Windows style newlines;
*) webfig - hide inherited wifi password;
*) webfig - improved keyboard navigation;
*) webfig - improved screen reader support;
*) webfig - improved system stability when used over many simultaneous sessions;
*) webfig - redirect "/help/license.html" to "/license.txt" for backwards compatibility;
*) webfig - reduce flickering when table is sorted by column with duplicate values;
*) webfig - Skin Designer moved to centralized page;
*) webfig - status page is deprecated, old status page config will work, but can't be updated or created;
*) webfig - support unicode strings;
*) wifi - add information to each interface, showing which CAPsMAN manages it or which CAP hosts it when applicable;
*) wifi - added a debug log entry when switching channel;
*) wifi - added ability to set security.owe-transition-interface to "auto";
*) wifi - added access-list stats (CLI only);
*) wifi - added configuration.installation property to limit use of indoor-only channels;
*) wifi - added debug log messages on station authentication mismatch;
*) wifi - added extra info to CAPsMAN about message;
*) wifi - added last-activity property in registration table;
*) wifi - added multi-passphrase (PPSK) support (CLI only);
*) wifi - added option to reset MAC address (CLI only);
*) wifi - added station-roaming support;
*) wifi - allow IPv6 LL address in caps-man-addresses;
*) wifi - disabled 802.11h on 2.4GHz station;
*) wifi - fixed "disabled" property in certain cases;
*) wifi - fixed failure to resume operation after DFS non-occupancy period has elapsed;
*) wifi - fixed failure with "auto" peer update on the OWE interface;
*) wifi - fixed occasional failure to bring up management frame protection and channel switch capabilities;
*) wifi - fixed the "no available channels" message still being displayed after a setting change has made some channels available;
*) wifi - improved FT roaming with WPA3 for some Apple devices;
*) wifi - indicate radios' ability to perform a channel switch in their "hw-caps" attribute;
*) wifi - indicate which channels are subject to DFS, or are indoor-only in output of "monitor" command;
*) wifi - re-word the "SA Query timeout" log message to "not responding";
*) wifi - show authentication type and wireless standard used by each client in registration table;
*) wifi - show regulatory limits on maximum bandwidth in output of radio/reg-info command;
*) wifi - when operating in station mode, log more information when AP switches to an unsupported channel;
*) wifi-qcom - added Superchannel country profile;
*) wifi-qcom - updated regulatory info for Ukraine, Australia and United States;
*) wifi-qcom-ac - allow use of channel 144 under "Japan" regulatory domain;
*) wifi-qcom-ac - fix possible conflict between radio and USB initialization on hAP ac2;
*) wifi-qcom-ac - improved CPU load balancing and system stability;
*) winbox - added "Copy to Access List" option under "WiFi/Registration" menu;
*) winbox - added "Max Entries" and "Total Entries" properties under "IP/Firewall/Connections/Tracking" menu;
*) winbox - added "Scan" and "Test Disks" features under "System/Disks" menu;
*) winbox - added Enable/Disable buttons under "Tools/Graphing" menus;
*) winbox - added MAC address support for "Group" property under "Bridge/MDB" menu;
*) winbox - added missing "bus" option for compatible devices under "System/RouterBOARD/USB Power Reset" menu;
*) winbox - added missing properties under "IP/Neighbors" menu;
*) winbox - allow to edit Ethernet MAC address;
*) winbox - clear "Value" field when unset under "IP/DNS/Static" menu;
*) winbox - fixed duplicate timezone names;
*) winbox - fixed typo in "System/Reset Configuration" menu;
*) winbox - hide LCD menu for devices without display;
*) winbox - hide LTE "External Antenna" menu for devices without switchable antenna option;
*) winbox - improved stability;
*) winbox - minimal required version is v3.41;
*) winbox - refresh values under "Bridge/VLANs/MVRP Attributes" menu;
*) winbox - renamed and moved "System/Auto Upgrade" to "System/Packages" menu;
*) winbox - renamed wrong invalid interface flag to inactive;
*) winbox - show "FEC" property on status tab for interfaces that use it;
*) winbox - show MLAG settings for CRS326-4C+20G+2Q+ device;
*) winbox - updated properties and behavior under "Switch/QoS" menu;
*) wireguard - do not initiate handshake when peer is configured as responder;
*) wireless - added option to reset MAC address (CLI only);
*) wireless - added vlan-id to registration-table;
*) wireless - allow to set Canada2 country profile when locked with US lock package for CubeG device;
*) wireless - enable all chains by default for RB911 and RB922 series devices;
*) wireless - fixed antenna gain for SXT5ac device;
*) wireless - preserve configured country while using setup-repeater, added "country" argument (CLI only);
*) x86 - Realtek r8169 updated driver;
*) zerotier - added debug logging;
*) zerotier - do not show default settings in export;
*) zerotier - upgraded to version 1.14.0; -
Lenry
lionhearted #23452 üzenetére
beírtam, hogy%l
mindkét wifi provisioningjébe (2 és 5G), és így mostl
ésl2
a nevük.I - íííí
nem elll -
Lenry
Kicsirics77 #23457 üzenetére
teljesen jól, én a megjelenése óta használom.
nyilván elsősorban vészmegoldásnak jó, de annak hibátlan. gyakorlatilag egy winbox telefonos felületre optimalizálva. -
Lenry
Anaconda #23448 üzenetére
- 1db WAN csatlakozó, gigabites
Mikrotikek esetében ez csak egy szoftveres beállítás, fizikailag minden csatlakozó egyenértékű, és bármelyiket kijelölheted WAN-nakdhcp rezervációnál lehessen megadni a klienseknek a boot szerver és boot image opciókat
ezt a routerOS minden routeren tudjaegyébként igen, szerintem jó választás.
csak figyelj arra, hogy hEX néven már tizenéve is volt Mikrotik router, az nyilván jóval gyöngébb, mint ez a faceliftelt változat, ráadásul az ára is kb ugyanez. a régi RB750Gr típusazonosítóval fut, ez az új meg E50UG. -
Lenry
biztos én vagyok a hülye, de capsman provisioning-nél hogyan kell jól használni a "name format" mezőt? mert száz helyen látom leírva, hogy
name-format=identity
, aminek gondolom az lenne a célja, hogy a router nevét adja a létrejövő interfésznek, de nálam azt eredményezi, hogy az lesz a neve az interfésznek, hogy "identity"meg mi a fene van a mikrotik fórumokkal?
Lenry
Protezis #23245 üzenetére
Mikor töröljem ki a default configot?
már a resetnél van ilyen opció, ekkor létre sem jön (ahogy a kolléga fentebb mutatta is). aztán vagy úgy mész tovább, ahogy ugyanott mutatta, hogy az addigra már módosított scriptet importálja is rögtön (run after reset), ekkor az egyetlen manuális dolgod az a user / password létrehozása és kész is vagy.
a B opció, hogy resetelsz, no default config, ekkor nem kapsz semmilyen IP-t, kézzel felveszed a gépednek a jövőbeli tartománynak megfelelőt, MAC addressel rácsatlakozol a routerre, importálod az eddigre már módosított konfigot, user / password -> profit.
azért ez nem akkora truváj
Lenry
lionhearted #23243 üzenetére
Egyébként igen, de ez olyan, hogy én se szeretem ha megkérdezek valamit hogyan kell megcsinálni, és valaki beleköt abba, hogy miért akarom megcsinálni, szóval én se teszem
Lenry
Protezis #23237 üzenetére
te nem akarod érteni, amit írok:
RouterOS-ből hiányzik egy normális text alapú backup
az export / import a textalapú backup. egészen pontosan ugyanazt csinálja, mint a backup / restore, csak scriptbe ment, nem binárisba.
attól félsz, hogy kizárod magad (aminek amúgy szubminimális az esélye, és ha igen, akkor is mi van, resetelsz még egyet), de arra már nem vagy hajlandó, hogy végignézd, hogy mit fog csinálni az import script, hogy tuti ne zárd ki magad
most akkor biztosra akarsz menni vagy sem?Wireguard config belemegy? Elég nyugtalanító, hogy valamit csak úgy kihagy.
semmit nem fog "csak úgy" kihagyni. a show-sensitive kapcsolóval bele fog rakni minden jelszavazott vackot is. -
Lenry
Protezis #23233 üzenetére
Soronként, vagy akárhogy részletekben betöltve nagyon könnyen kizárhatom magam.
ez a lényege a soronként betöltésnek, hogy tudod mi fog történni.De ettől függetlenül az import tudtommal nem feltétlenül írja felül a meglévő configot.
ha valami logikai ütközés van, akkor megáll. ugyanúgy, ahogy a bináris restore is.
de továbbra is: ezért ütöd be soronként, hogy előre lássad mi történik.Nekem olyan egyszerű megoldás kéne, hogy backup text formátumban, átírom benne a címeket, aztán restore.
mert szerinted az export / import mégis mi, ha nem pontosan ez? -
Lenry
Protezis #23231 üzenetére
Az exportban meg vagy benne van a default config, ami visszatöltésnél problémát okozhat, vagy nincs benne
az exportban az van benne, ami éppen benne van a routered konfigjában. semmi más.
de ha attól félsz, hogy elakad valahol az import, akkor csináld azt, hogy néhány soronként illeszted be a terminálba, úgy pontosabban nyomon tudod követni, hogy mikor mi történik. -
Lenry
What's new in 7.16.2 (2024-Nov-26 14:09):
*) dns - fixed lookup order for static DNS entries (introduced in v7.16.1);
*) leds - fixed bogus argument for "leds" property (introduced in v7.16);
*) leds - fixed PoE-in LEDs for CRS318-1Fi-15Fr-2S device;
*) routerboot - improved stability for IPQ8072 and IPQ6010 when flash-boot is used ("/system routerboard upgrade" required); -
Lenry
silver-pda #22885 üzenetére
ha nem él a vezeték, akkor a route-ja automatikusan érvénytelenné válik
Lenry
lionhearted #22860 üzenetére
Lenry
ha úgyis a bejövő interfészt figyeled, akkor szerintem nincs szükség a dst. address feltételre is, ha eljutott hozzád a csomag, akkor nyilván a te IP címed volt a címzett.
egyébként ha nagyon szeretnéd, hogy ott legyen, akkor a megoldás inkább az, hogy bekapcsolod a Mikrotik saját DDNS-ét, ha még nincs (IP/cloud), aztán Firewall - Address List-be felveszed az ott kapott URL-t egy listára (ez automatikusan fel fog mindig oldódni az aktuális IP címedre, létrejön egy dinamikus tétel a listában), és fenti NAT szabályokban dst. address helyett dst. address list-et adsz meg
Lenry
pedig de, az a megoldás.
remove config, no default config, aztán bemászol MAC alapján valamelyik porton és úgy importálsz.mert az összes interfészt is törli.
dehogy törli, a bridgeket meg egyéb virtuális interfészeket fogja törölni, de a fizikai eth1, eth2, ethX ugyanúgy ott lesz -
Lenry
allnickused #22422 üzenetére
konzol az nemcsak hogy kommunikál kikapcsolva, hanem bekapcsol magától és egy idő után kikapcsol, mintha misem történt volna
frissítéseket tölt le, PS-en kikapcsolható funkció, egész biztos vagyok benne, hogy Xboxon is -
Lenry
a cloud DNS másnál is lehalt?
Lenry
What's new in 7.15 (2024-May-29 15:44):
!) system - added support for AMPERE (R) and ARM64 CHR installations (new ARM64 CHR image available);
!) system - added support for AMPERE (R) hardware (new ARM64 ISO file, new ARM64 extra-nics.npk package);
*) bgp - added initial vpnv6 support;
*) bgp - correctly synchronize input.accept-nlri address list;
*) bgp - fixed prefix count when BGP sessions run with multiple AFIs;
*) bgp - fixed selecting local.default-address from wrong VRF;
*) bgp - use IPv6 as default address-family for IPv6 sessions;
*) bgp-vpn - use VRF interface as gateway for leaked connected routes;
*) branding - added option to hide default configuration prompt;
*) branding - added option to hide or replace default caps-mode-script;
*) bridge - added error message if MLAG peer-port is configured with "mlag-id";
*) bridge - added MLAG peer-port events to logs;
*) bridge - added MVRP support;
*) bridge - do not allow multiple bonds with same "mlag-id";
*) bridge - improved protocol-mode STP, RSTP and MSTP stability;
*) bridge - rename monitor property "path-cost" to "actual-path-cost";
*) bridge - reworked dynamic VLAN creation;
*) bridge - use default "edge=auto" for dynamically bridged interfaces (PPP, VPLS, WDS);
*) certificate - added support for different ACME servers for ssl-certificate (CLI only);
*) certificate - added support for importing pbes2 encrypted private keys with aes128;
*) certificate - added trusted parameter for certificate import;
*) certificate - allow replacing certificate with internal import;
*) certificate - delete certificate related files automatically from storage after import;
*) certificate - improved RSA key signature processing speed;
*) chr - allow to "generate-new-id" only while CHR is running on level "free" license;
*) chr - fixed bogus messages printed out while booting up the system (introduced in v7.14);
*) chr - fixed Xen and Vultr missing ethernet (introduced in v7.14);
*) console - added "byte-array" option to ":convert" command;
*) console - added "proplist" parameter to interactive commands;
*) console - added "rows" property for sniffer quick mode;
*) console - added "sanitize-names" property under "/console/settings" menu (option for replacing reserved characters with underscores for files, disabled by default);
*) console - added "type" parameter to ":resolve" command;
*) console - added "use-script-permissions" option when running scripts from CLI;
*) console - added hotkey "F8" to print entire multiline input;
*) console - added link from "/iot/lora" to "/lora";
*) console - added log for script execution failures;
*) console - added multi-line print in "/file" menu;
*) console - added option to get "about" value (dynamically created text field by RouterOS services like CAPsMAN);
*) console - added option to read and change file line endings in full-screen editor;
*) console - added warning log for modified filenames due to reserved characters;
*) console - covert spaces, CR, LF in ":convert to=url" command;
*) console - do not convert string to array in ":deserialize" command;
*) console - fixed ":onerror" behavior when "do" block is missing;
*) console - fixed "export where" functionality in certain menus;
*) console - fixed console prompt when entering hot lock mode with "F7";
*) console - fixed DHCP server "authoritative=no" configuration export;
*) console - fixed do/while implementation not working with variables (introduced in v7.14);
*) console - fixed filtering by "dhcp" flag in "/ip/arp" menu;
*) console - fixed multiple typos in help;
*) console - improved stability;
*) console - optimized configuration export to prevent startup of processes without any configuration;
*) console - remove unnecessary serial ports for Alpine CPUs;
*) console - show system note before serial login if enabled;
*) console - use user permissions when running scripts from WinBox and WebFig;
*) container - do not allow negative number for "ram-high" setting;
*) defconf - do not override default DHCP server lease time;
*) defconf - fixed 5ghz-ax channel width for L11, L22 devices;
*) defconf - fixed unknown topics in log messages;
*) defconf - minor configuration script updates;
*) dhcpv4-relay - added VRF support;
*) discovery - added LLDP MAC/PHY Configuration/Status TLV support;
*) discovery - added LLDP Maximum Frame Size TLV support;
*) discovery - added LLDP Port Description TLV support;
*) discovery - advertise only physical interface name for LLDP PortID TLV;
*) discovery - always send LLDP MED Power TLV if MED was received;
*) discovery - fixed high CPU utilization when "tx-only" mode is set;
*) discovery - optimized LLDP information update;
*) disk - added option to auto configure media sharing;
*) disk - added support for formatting exfat file-system;
*) disk - improved support for file systems with non-ascii characters in file names;
*) disk - improved support for formatting ext4 file-system;
*) disk - improved system stability when adding partition with no parent;
*) disk - the "scan" command will now detect and include USB drives that were previously ejected;
*) dns - added support for "adlist";
*) dns - added VRF support;
*) dns - improved system stability when caching entries;
*) eap - improved eap-peap, eap-mschap2 client authentication (dot1x/wireless/ipsec);
*) ethernet - fixed default names for CRS310-8G+2S+ device (introduced in v7.14);
*) ethernet - fixed interface disable for CRS326-4C+20G+2Q;
*) ethernet - fixed management port disable/enable on CCR2004-1G-12S+2XS, CCR2004-1G-2XS-PCIe, CCR2216, CCR2116 devices;
*) ethernet - improved port speed downshift functionality for CRS326-4C+20G+2Q;
*) fetch - added "idle-timeout" parameter;
*) fetch - changed topic "info" to "error" for permission denied logs;
*) fetch - fixed slow throughput due to "raw" logging which occurred even when not listening to the topic (introduced in v7.13);
*) file - allow adding and renaming files and directories;
*) file - avoid refreshing whole file system during file modification;
*) file - improved external storage detection;
*) health - added "cpu-temperature" for IPQ50xx devices;
*) health - added log for fan state changes on CRS3xx, CRS5xx, CCR2xxx, CCR1016r2, CCR1036r2 devices;
*) health - fixed fan behavior for CRS310-1G-5S-4S+ (introduced in v7.14);
*) health - fixed rogue voltage on CRS510-8XS-2XQ-IN;
*) install - cdrom and hdd install images contain additional packages that can be interactively selected;
*) ipv6 - properly initialize default ND "interface=all" entry;
*) leds - fixed LEDs for L22 device;
*) lora - removed LoRa WinBox and console functionality duplication (moved to IoT package since v7.11);
*) lte - added "at-chat" support for DELL T99W175 (PID: 0x05c6 VID: 0x90d5);
*) lte - added support for concatenated AT commands in "modem-init" string;
*) lte - added support to set "modem-init" string for "dialer-less" modems;
*) lte - apply the same configuration for Microsoft branded EM12-G modem (Surface Mobile Broadband) as for Quectel EM12-G;
*) lte - do not show persistent interfaces for multi-apn slave interfaces;
*) lte - dropped support for R11e-LTE-US FOTA firmware update;
*) lte - fixed R11e-LTE-US modem dial-up;
*) lte - fixed situation where link is not restored after Quectel MBIM modem firmware update;
*) lte - improved FG621-EA modem APN authentication;
*) lte - make interface persistent (unused interface configs can be removed, allow to export and examine current configuration without the device present);
*) lte - removed 2 APN restriction for RG520F-EU modem;
*) lte - use the correct network interface for multi-interface LTE modems;
*) media - added support for DLNA;
*) metarouter - removed support;
*) modem - send APN authentication for BG77 modem also if ppp-client interface created manually;
*) netinstall - improved stability;
*) netinstall-cli - fixed incorrect server address assignment (introduced in v7.14);
*) ovpn - fixed import ovpn config when remote port is missing;
*) ovpn - fixed minor typo in error message;
*) poe-out - added LLDP power management support for devices with single PoE-out port;
*) poe-out - fixed powering devices if input voltage is lower than 12V for hEX PoE (introduced in v7.9);
*) poe-out - improved firmware upgrade stability for AF/AT controlled boards;
*) poe-out - moved "PoE LLDP" property from "/interface/ethernet/poe" to "/ip/neighbor/discovery-settings" and enable it by default;
*) ppp - added "enable-ipv6-accounting" option under PPP AAA menu (CLI only);
*) ppp - added log when disconnecting a client due to "WISPr-Session-Terminate-Time" RADIUS attribute;
*) ppp - allow underscores in domain names;
*) ppp - enabled monitoring of registration state, RSRP, RSRQ, SINR, PCI, CellID for BG77 modem;
*) ppp - fixed "Framed-IPv6-Pool" usage when received from RADIUS;
*) ppp - fixed "on-down" script running even when tunnel was not up;
*) profiler - added "neighbor-discovery" task;
*) ptp - added PTP support for CCR2116 device;
*) qos-hw - added "offline" tx-manager (CLI only);
*) qos-hw - added "profile" and "map" support for CPU port;
*) qos-hw - added congestion avoidance support for 98DX8xxx, 98DX4xxx, 98DX325x switch chips (CLI only);
*) qos-hw - added ECN marking support for compatible switches;
*) qos-hw - added per-queue traffic shapers (CLI only);
*) qos-hw - added Priority Flow Control for compatible switches (CLI only);
*) qos-hw - added support for QoS profile assignment via ACL rules;
*) qos-hw - added WRED support for compatible switches;
*) qos-hw - fixed port "print stats/usage" when using "from" property;
*) qos-hw - replaced buffer with bytes in QoS monitor;
*) queue - improved system stability (introduced in v7.6);
*) quickset - only show LTE mode for devices without other wireless interfaces;
*) radius - added "require-message-auth" option that requires "Message-Authenticator" in received Access-Accept/Challenge/Reject messages;
*) radius - include "Message-Authenticator" in any RADIUS communication messages besides accounting for all services;
*) route - do not allow routes with empty "dst-address";
*) route - do not redistribute loopback address as connected route;
*) route - fixed bgp-vpn prefix import with the same route distinguisher (RD);
*) route - improved system stability;
*) route - rework of route attributes;
*) route - show route-distinguisher (RD) in route print;
*) route-filter - allow setting different AFI gateways;
*) route-filter - fixed ext community list matcher;
*) sfp - added "100M-baseFX" link mode support for compatible devices;
*) sfp - added "sfp-ignore-rx-los" setting;
*) sfp - fixed "sfp-tx-fault" state indication for CRS510;
*) sfp - fixed link establishment with 100Mbps optical modules (requires "/interface ethernet reset" or adding "100M-baseFX" modes for advertise or speed properties);
*) sfp - fixed missing Tx traffic at 10Gbps rate on CCR2004-16G-2S+ in rare cases;
*) sfp - ignore SFP RX LOS signal for modules with bad EEPROM;
*) sfp - improved "sfp-tx-power" value monitoring in certain cases;
*) sfp - improved auto-negotiation linking for some MikroTik cables and modules;
*) sfp - improved system stability for CR2004-1G-2XS-PCIe (introduced in v7.14);
*) sfp - improved system stability with some GPON modules for CCR2004 and CCR2116 devices;
*) smb - added logs for share connection requests;
*) smb - do not allow setting empty "comment" or "domain" properties;
*) sms - added option to select SMS storage;
*) sms - added SMS PDU to SMS inbox "print detail";
*) sms - added workaround for modems which do not notify regarding new SMS arrival (missing URC);
*) sms - improved SMS handling;
*) sms - removed SMS for SMIPS;
*) sms - use "gsm" logging topic for serial modem SMS logs;
*) snmp - added missing PoE-out status codes to MIKROTIK-MIB;
*) snmp - added new "mtxrOpticalVendorSerial" OID to MIKROTIK-MIB;
*) socks - attempt to parse domain name as IP before resolving;
*) ssh - added support for user Ed25519 private keys;
*) ssh - export host Ed25519 public key;
*) ssh - fixed bogus output;
*) ssh - fixed permissions to run ".auto.rsc" scripts;
*) ssh - require "policy" user policy when adding public key;
*) sstp - added SNI support;
*) sstp - disconnect clients when server is disabled;
*) storage - improved configuration storing process on first system boot after configuration reset;
*) switch - added support for multiple ingress and egress port mirroring on 98DXxxxx switches;
*) switch - added support for RSPAN mirroring on 98DXxxxx switches;
*) switch - fixed L3HW and QoS monitor during switch reset;
*) system - added resource values (Product name, File name and File version) for Windows executable files;
*) system - general work on optimizing the size of RouterOS packages;
*) system - show "cpu-frequency" for Alpine CPUs;
*) system - skip configuration upgrade from RouterOS v6 on configuration reset;
*) system - updated office address in RouterOS license;
*) system - updated online manual links from "wiki" to the help documentation;
*) timezone - updated timezone information from "tzdata2024a" release;
*) traffic-flow - detect IPv4 source address if not set;
*) traffic-flow - improved system stability;
*) userman - added "require-message-auth" option that requires "Message-Authenticator" in received Access-Request messages;
*) userman - include "Message-Authenticator" in any RADIUS communication messages besides accounting for all services;
*) vlan - added MVRP (applicant) configuration option;
*) vlan - ensure that VLAN MTU remains unchanged when adjustments are made to the parent interface MTU, only modifications to the L2MTU might impact VLAN MTU;
*) vlan - fixed MTU reset on bridge after reboot;
*) vlan - limit "vlan-id" range from 1-4095 to 1-4094;
*) vrf - fixed VRF interfaces being moved to main table after reboot (introduced in v7.14);
*) webfig - allow pasting with ctrl+v into terminal;
*) webfig - fixed column preferences for ordered tables;
*) webfig - show inherited properties for wifi interfaces;
*) wifi - added "reselect-interval" support;
*) wifi - changed interface default to "disabled=yes";
*) wifi - do not report disabled state for CAPsMAN managed interface;
*) wifi - fixed configuration export for "disabled" property;
*) wifi - improve channel selection after radar detection events;
*) wifi - improve regulatory compliance for L11, L22 devices;
*) wifi - improved interface initialization reliability on DFS channels;
*) wifi - improved stability of DFS check in the 5GHz-A band;
*) wifi - improved system stability when provisioning CAPs in certain cases;
*) wifi - rename "available-channels" parameter to "channel-priorities" and include desirability rating for each channel;
*) wifi - report current CAPsMAN address and identity on CAP;
*) wifi - show inherited properties with "print" command (replaces "actual-configuration") and added "print config" for showing only configured values;
*) wifi-qcom - added configuration.distance setting to enable operation over multi-kilometer distances;
*) wifi-qcom - updated driver;
*) winbox - added "Download" and "Flush" buttons under "System/Certificates/CRL" menu;
*) winbox - added "Flat Snoop" button under "WiFi" menu;
*) winbox - added "FT Preserve VLAN ID" setting under "WiFi/Configuration/FT" menu;
*) winbox - added "Request logout" button under "System/Users/Active Users" menu;
*) winbox - added "Trusted" checkbox under "System/Certificates/Import" menu;
*) winbox - added drop down menu for "User" property when importing SSH key under "System/User/SSH Keys" and "System/User/SSH Private Keys" menus;
*) winbox - added invalid flag under "IP/DHCP Relay" menu;
*) winbox - added key type and key length column for user SSH keys;
*) winbox - added missing SFP monitoring properties under "Interface/SFP" menu;
*) winbox - added passphrase option for SSH host key export;
*) winbox - added passphrase option for SSH host key import;
*) winbox - allow specifying size and rtmpfs size with M, G units under "System/Disks" menu;
*) winbox - allow to specify "M" or "G" postfix for download, upload or total limits under "User Manager/Limitations" menu;
*) winbox - do not show "Host Key Size" when using ed25519 key under "IP/SSH" menu;
*) winbox - fixed the issue where the skin file fails to appear in the user group menu after creation;
*) winbox - renamed "Channel" column to "Current Channel" under "Wifi" menu;
*) winbox - show "Valid Servers" and "Unknown Servers" column by default under "IP/DHCP Server/Alerts" menu;
*) winbox - show inherited properties for wifi interfaces;
*) winbox - show SIM settings for SXTR device under "Interfaces/LTE/Modem" menu;
*) winbox - updated icons for certain menus;
*) winbox - use correct values for "Jump Target" property under "IPv6/Firewall/Filter Rules" menu;
*) wireguard - added option to mark peer as responder only;
*) wireguard - added peer "name" field and display it in logs;
*) wireguard - do not attempt to connect to peer without specified endpoint-address;
*) wireguard - fixed "auto" argument usage for "private-key" and "preshared-key" settings;
*) wireguard - fixed performance issues showing QR code;
*) wireless - perform shorter channel availability check for 5600-5650MHz if regulatory domain permits it;
*) x86 - fixed ixgbe Tx hang by disabling TSO;
*) x86 - fixed VLAN tagged packet transmit for ice driver;
*) x86 - ice driver update to v1.13.7;
*) x86 - improved stability for RTL8125 driver;
*) x86 - ixgbe driver update to 5.19.9;
*) x86/chr - improved panic saving (increased minimal RAM requirements to 256MB);szép nagy lista...
Lenry
7.14.2 (2024-Mar-27 09:48):
*) lte - fixed firmware upgrade not found issue for Chateau LTE12 (introduced in v7.14.1);
*) wifi-qcom - added configuration.distance setting to enable operation over multi-kilometer distances (CLI only); -
Lenry
Istv@n #21815 üzenetére
két ötlet:
192.168.1.x/32-t a 192.168.2.akárhányas gatewayen keresse és ennek a szabálynak kisebb legyen a distance értéke, mint az 1.0/24-é
(de nem vagyok 100%-ig biztos benne, hogy ez így működik, és ha igen, akkor jó ötlet egyáltalán)a másik, hogy létrehozol egy VLAN-t arra a portra, amibe ez a gép be van kötve és azt a VLAN az 1.0-s hálózathoz kötöd. így technikailag ottmarad az 1.0-s hálózaton és nem kell routing szabályt sem módosítani.
ezt érzem jobb megoldásnak -
Lenry
lionhearted #21791 üzenetére
benéztem
Lenry
annyiban jobb, hogy nem kell megvárnod amíg újjáépül a kapcsolat. ennyi.
annyiban rosszabb, hogy amúgy az volna a WG alap filozófiája, hogy nem forgalmaz, ha nincs mit, így harmadik félnek nehezebb megfigyelni -
Lenry
igen, próbáltam, pontosan ugyanitt akadtam el, mint te
aztán elolvastam ezt, és úgy döntöttem, hogy egyelőre ráhagyom
Lenry
ratkaics #21724 üzenetére
road warrior az az eszköz, ami nincs helyhez (ezáltal mondjuk fix IP címhez) kötve, mint pl egy területi képviselő laptopja, ami bárhonnan, bármilyen IP címről felcsatlakozhat.
konfigurációs szempontból ez leginkább annyit jelent, hogy a szerver oldalon nem adod meg, hogy milyen endpointról várod az adott klienst
Lenry
lionhearted #21709 üzenetére
na majd kipróbálom, ha bekerül a stabilba. az adguarddal egyébként elégedett vagyok, szóval csak úgy nem dobnám ki
Lenry
lionhearted #21707 üzenetére
akkor lőhetem le az AdGuardot?
Lenry
zelikocc #21676 üzenetére
az 1.149 az maga a Mikrotik, és azért nem látsz rajta a lokál hálózat felől eszközt, mert az az eth1 felé érvényes IP cím, egyébként valószínűleg fut egy DHCP kliens azon az interfészen, a túloldalt lévő eszköztől kapja ezt az IP-t, kapcsold ki a DHCP klienst.
a net meg azért megy el, mert gondolom szerencsétlen router nem tudja, hogy akkor most merre felé is kéne route-olnia az 1.0/24-et
Lenry
7.14-re frissítés óta egy kikapcsolt logging szabály spammeli tele a logot, amit ráadásul azóta töröltem is, de ez sem tántorítja el a munkájától
újra is indítottam... így is
Lenry
7.13.5 changelog:
1. When upgrading by using "check-for-updates", all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
2. Drivers for older wireless and 60GHz interfaces, as well as the wireless management system CAPsMAN, are now part of a separate "wireless" package instead of being a part of the bundle package. This package can be uninstalled if not needed.
3. The existing "wifiwave2" package has been divided into distinct packages: "wifi-qcom" and "wifi-qcom-ac", and the necessary utilities for WiFi management are now included in the RouterOS bundle. RouterOS and "wifi-qcom-ac" packages alongside each other now fit into 16MB flash memory.
What's new in 7.13.5 (2024-Feb-16 19:35):
*) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
*) bridge - fixed packet forwarding after changing HW offloaded bridge interface settings in certain cases (introduced in v7.13);
*) dns - do not close connection with DoH server after query execution (introduced in v7.13.3);
*) leds - fixed modem signal strength for RBSXTR&R11e-LTE (introduced in v7.13);
*) sms - increased SMS read timeout;
*) wifi-qcom - improved memory allocating process;
*) wifi-qcom - improved regulatory compliance for L11, L22 devices;
*) wifi-qcom - improved system stability for L11, L22 devices;
Download the new 'RouterOS 7.13.5' version here: https://mikrotik.com/download -
Lenry
E.Kaufmann #21460 üzenetére
dehogynem
a tűzfal sorban értékeli ki a szabályokat, az első olyat, ami megfelel a kapcsolatnak, azt végrehajtja, és ott vége is a kiértékelésnek.húzd a sor elejére a hairpint
Lenry
Kenderice #21453 üzenetére
nincs benne semmi újdonság, továbbra is ennyi az egész
Lenry
jól emlékszem, hogy a wireguard kliensben ha endpointnak URL-t adsz meg, azt egyszer lecsekkolja, aztán ha közben változik az IP, akkor így jártál?
ha igen, akkor van-e erre valami megoldás, hogy reconnect esetén újra oldja fel az URL-t?mod: már nem így van
7.10 changelogból:
) wireguard - retry "endpoint-address" DNS query on failed resolve -
Lenry
csitkiri01 #21266 üzenetére
nem akkora truváj
Firewall - NAT
új szabály:
chain: srcnat
src address: 192.168.88.0/24
dst address 192.168.88.0/24
action: masquarade -
Lenry
csitkiri01 #21262 üzenetére
a DDNS bekapcsolásával csak a noip-t váltod ki, portjaid attól még nem lesznek jobban vagy kevésbé megnyitva.
egyébként én elérem a Jellyfinedet az IP címed alapján, amit ügyesen rajta felejtettél a screenshotodon, szóval ez a része működik
ha neked otthonról nem működik a noip-s webcímről megnyitva, az azért van, mert nem hoztál létre a tűzfalban hairpin NAT szabályt -
Lenry
privatposta #21124 üzenetére
Ez miért nem kivitelezhető?
Lenry
privatposta #21129 üzenetére
Mondom: authentikáció RADIUS szerver, mindenkinek egyedi usernév és jelszó és az alapján szortírozod őket, de erre nem lesz két kattintásos megoldás
Lenry
privatposta #21122 üzenetére
hogy akarod authentikálni őket?
a Mikrotikben a RADIUS-t össze lehet henkölni egy LDAP-pal, de előre szólok, hogy sokkal nagyobb szopás, mint amennyit ér az egész -
Lenry
egy csomó 4G USB modemet kezelnek a Mikrotik eszközök, úgyhogy az nem lesz gond.
backup WAN-t beállítani szintén nem nagy truváj, létrehozod a netkapcsolatot a backup netre is, route-oknál ennek a kapcsolatnak nagyobb distance-ot adsz a 0.0.0.0/0 felé. ha a másik route elérhetetlenné válik, ezt fogja használni.
dióhéjban ennyi, de persze ezt lehet tuningolni különböző scriptekkel, ami figyeli az élő netkapcsolatot, stb.
- HP EliteOne 800 G5 All-in-One i5-9500 32GB 1000GB 23.8" Érintőkijelző!! 1 év garancia
- Gamer PC-Számíógép! Csere-Beszámítás! I7 13700F / RTX 4070Ti Super 16GB OC / 32GB DDR5 / 1TB SSD
- Lenovo ThinkPad Z13 G1 (ELKELT)
- Dell és HP szerver HDD caddy keretek, adapterek. Több száz darab készleten, szállítás akár másnapra
- ÁRGARANCIA!Épített KomPhone i5 14400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
