keopsz
HÁZIGAZDA
"We believe that the chipset is the weakest link of this machine, as the chipset dissipates and needs more than the CPU. We still cannot prove this claim but we've heard that 1.6GHz CPU has TDP of 4W, while the chipset has 8W. This is simply unacceptable, but we'll have to live with it."
"MSI told us that a fire happened in the factory that makes the batteries in China, and therefore they couldn't send us a sample notebook with a six-cell battery."
"The CPU, as we wrote so many times before, works at 1.6GHz and runs Windows XP really fast. It runs between 700 and 1600MHz, depending on what you do."
"The fan is very quiet and you can sometimes hear the hard drive as the machine’s fan will be almost completely silent."
"It is as good as it gets and we will be surprised if we see anyone making anything much better than this. "
http://www.fudzilla.com/index.php?option=com_content&task=view&id=7613&Itemid=1
aha.
keopsz
HÁZIGAZDA
"Der einfache und angenehme Einsatz des MSI Wind im Internet steht im Vordergrund und sogar der Name ist in diesem Zusammenhang zu sehen, so steht die Bezeichnung WIND laut MSI für WIreless Network Device."
keopsz
HÁZIGAZDA
isaiahból kicsit lassú a ph, pedig odabaaaaaaasz:
http://www.eeepcnews.de/2008/04/12/via-isaiah-und-nvidia-der-intel-atom-killer/
keopsz
HÁZIGAZDA
http://www.eeepcnews.de/2008/04/18/intel-atom-benchmarks-via-isaiah-vergleich/
keopsz
HÁZIGAZDA
http://www.eeepcnews.de/2008/05/25/video-intel-atom-nur-halb-so-schnell-wie-der-celeron/#more-748
keopsz
HÁZIGAZDA
http://www.msi-wind.de/
- OpenMediaVault
- Jövedelem
- HP ProBook 6560b, 15,6" HD+, i5-2520M CPU, 8GB DDR3, 500GB HDD, W10, Számla, garancia ( olvasd végi
- Lenovo Thinkpad L450, 14" HD, i3-5005U CPU, 8GB DDR3, 128GB SSD, W11, Számla, 1 év garancia ( olvas
- HP ProBook 650 G2 15,6" FHD, i5-6200 CPU, 8GB DDR4, 256GB SSD, W11, Számla, 1 év garancia ( olvasd
- Dell Latitude 5490, 14" FHD IPS, i5-7300U CPU, 8GB DDR4, 256GB SSD, W11, Számla, 1 év garancia ( ol
- Dell Latitude 7320 Carbon /i5-1145G7/16GB/256GB SSD/13.3" FHD laptop
- Lenovo T14s Gen 1 Ryzen 7 pro 4750U, 16GB RAM, 512GB SSD, jó akku, számla, garancia
- Keresünk iPhone 16/16e/16 Plus/16 Pro/16 Pro Max
- BESZÁMÍTÁS! GIGABYTE RTX 5080 AERO OC 16GB videokártya garanciával hibátlan működéssel
- Beszámítás! HP Elitebook 840 G11 14 FHD notebook - Ultra 5 135U 16GB DDR5 256GB SSD Intel Win11
- Ventilátor bazár /NZXT/CORSAIR/LIAN LI/DEEPCOOL/ZALMAN/120MM/140MM/VEZÉRLŐK/LED KIT-ek/
(sok neki az 1280.768
