Padavan firmware image file-ok, hasznos infók
kutga
Intruder2k5
#2126
Ha elárulod hogyan váltok repot akkor este megcsinálom. Vagy használom a tiédet.
Ezt akár az admin felületről is fel lehet tenni?
kutga
Intruder2k5
#2123
100-as. Küldöm a template.config-ot.
### Target Vendor/Product (support only Ralink RT3883/MT7620/MT7621)
CONFIG_VENDOR=ASUS
CONFIG_PRODUCT=RT3052
### Target ProductID (board select, max 12 symbols)
CONFIG_FIRMWARE_PRODUCT_ID="RT-N10C1"
### Linux kernel configuration
### Force MT7620 CPU clock to 600MHz (override Uboot settings)
#CONFIG_FIRMWARE_CPU_600MHZ=y
### Enable MT7620 CPU sleep mode (downclock to 200MHz on idle)
#CONFIG_FIRMWARE_CPU_SLEEP=y
### Kernel driver select for WiFi AP 2.4GHz
### 2.7 = MT7620 v2.7.2.0
### 3.0 = MT7620 v3.0.4.0
CONFIG_FIRMWARE_WIFI2_DRIVER=2.7
### Enable IPv6 support
CONFIG_FIRMWARE_ENABLE_IPV6=y
### Enable USB support
#CONFIG_FIRMWARE_ENABLE_USB=y
### Enable FAT/FAT32 filesystem support. ~0.1MB
#CONFIG_FIRMWARE_ENABLE_FAT=y
### Enable exFAT (FAT/FAT32 too) filesystem support. ~0.12MB
#CONFIG_FIRMWARE_ENABLE_EXFAT=y
### Enable EXT2 filesystem support. ~0.1MB
#CONFIG_FIRMWARE_ENABLE_EXT2=y
### Enable EXT3 filesystem support. ~0.2MB
#CONFIG_FIRMWARE_ENABLE_EXT3=y
### Enable EXT4 (EXT3/2 too) filesystem support. ~0.4MB
#CONFIG_FIRMWARE_ENABLE_EXT4=y
### Enable XFS filesystem support. ~0.6MB
#CONFIG_FIRMWARE_ENABLE_XFS=y
### Enable FUSE (filesystems in userspace) support. ~0.1MB
#CONFIG_FIRMWARE_ENABLE_FUSE=y
### Enable swap files/partitions support. ~0.05MB
#CONFIG_FIRMWARE_ENABLE_SWAP=y
### Include UVC camera modules. ~0.2MB
#CONFIG_FIRMWARE_INCLUDE_UVC=y
### Include USB-HID modules. ~0.2MB
#CONFIG_FIRMWARE_INCLUDE_HID=y
### Include USB-Serial modules (e.g. pl2303). ~0.03MB
#CONFIG_FIRMWARE_INCLUDE_SERIAL=y
### Include network QoS scheduling modules. ~0.2MB
#CONFIG_FIRMWARE_INCLUDE_QOS=y
### Include IMQ module for shapers (a bit of performance degradation). ~0.02MB
#CONFIG_FIRMWARE_INCLUDE_IMQ=y
### Include IFB module for shapers. ~0.03MB
#CONFIG_FIRMWARE_INCLUDE_IFB=y
### Include IPSet utility and kernel modules. ~0.4MB
CONFIG_FIRMWARE_INCLUDE_IPSET=y
### Include NFSv3 server. ~0.6MB
#CONFIG_FIRMWARE_INCLUDE_NFSD=y
### Include NFSv3 client. ~0.5MB
#CONFIG_FIRMWARE_INCLUDE_NFSC=y
### Include CIFS (SMB) client. ~0.2MB
#CONFIG_FIRMWARE_INCLUDE_CIFS=y
### Userspace configuration
### Include WebUI international resources. Increased firmware size
#CONFIG_FIRMWARE_INCLUDE_LANG_BR=y
#CONFIG_FIRMWARE_INCLUDE_LANG_CZ=y
#CONFIG_FIRMWARE_INCLUDE_LANG_DA=y
#CONFIG_FIRMWARE_INCLUDE_LANG_DE=y
#CONFIG_FIRMWARE_INCLUDE_LANG_ES=y
#CONFIG_FIRMWARE_INCLUDE_LANG_FI=y
#CONFIG_FIRMWARE_INCLUDE_LANG_FR=y
#CONFIG_FIRMWARE_INCLUDE_LANG_NO=y
#CONFIG_FIRMWARE_INCLUDE_LANG_PL=y
CONFIG_FIRMWARE_INCLUDE_LANG_RU=y
#CONFIG_FIRMWARE_INCLUDE_LANG_SV=y
#CONFIG_FIRMWARE_INCLUDE_LANG_UK=y
### Include NTFS-3G FUSE driver (instead of Paragon "ufsd"). ~0.4MB
#CONFIG_FIRMWARE_INCLUDE_NTFS_3G=y
### Include LPR printer daemon. ~0.12MB
#CONFIG_FIRMWARE_INCLUDE_LPRD=y
### Include USB-over-Ethernet printer daemon. ~0.05MB
#CONFIG_FIRMWARE_INCLUDE_U2EC=y
### Include "tcpdump" utility. ~0.6MB
#CONFIG_FIRMWARE_INCLUDE_TCPDUMP=y
### Include "hdparm" utility (allow set HDD spindown timeout and APM). ~0.1MB
#CONFIG_FIRMWARE_INCLUDE_HDPARM=y
### Include "parted" utility (allow make GPT partitions). ~0.3MB
#CONFIG_FIRMWARE_INCLUDE_PARTED=y
### Include SMB (and WINS) server. ~1.5MB
#CONFIG_FIRMWARE_INCLUDE_SMBD=y
### Include WINS server only. ~0.4MB
#CONFIG_FIRMWARE_INCLUDE_WINS=y
### Include syslog for SMB and WINS server. ~0.3MB
#CONFIG_FIRMWARE_INCLUDE_SMBD_SYSLOG=y
### Include FTP server. ~0.2MB
#CONFIG_FIRMWARE_INCLUDE_FTPD=y
### Include EAP-TTLS and EAP-PEAP authentication support. openssl ~1.2MB, wpa_supplicant +0.04MB
#CONFIG_FIRMWARE_INCLUDE_EAP_PEAP=y
### Include HTTPS support for DDNS client. openssl ~1.2MB
#CONFIG_FIRMWARE_INCLUDE_DDNS_SSL=y
### Include HTTPS support. openssl ~1.2MB
#CONFIG_FIRMWARE_INCLUDE_HTTPS=y
### Include sftp-server. openssl ~1.2MB, sftp-server ~0.06MB
#CONFIG_FIRMWARE_INCLUDE_SFTP=y
### Include dropbear SSH. ~0.3MB
CONFIG_FIRMWARE_INCLUDE_DROPBEAR=y
### Make the dropbear symmetrical ciphers and hashes faster. ~0.06MB
CONFIG_FIRMWARE_INCLUDE_DROPBEAR_FAST_CODE=y
### Include OpenSSH instead of dropbear. openssl ~1.2MB, openssh ~1.0MB
#CONFIG_FIRMWARE_INCLUDE_OPENSSH=y
### Include OpenVPN. IPv6 required. openssl ~1.2MB, openvpn ~0.4MB
#CONFIG_FIRMWARE_INCLUDE_OPENVPN=y
### Include Elliptic Curves (EC) to openssl library. ~0.1MB
#CONFIG_FIRMWARE_INCLUDE_OPENSSL_EC=y
### Include "openssl" executable for generate certificates. ~0.4MB
#CONFIG_FIRMWARE_INCLUDE_OPENSSL_EXE=y
### Include xUPNPd IPTV mediaserver. ~0.3MB
#CONFIG_FIRMWARE_INCLUDE_XUPNPD=y
### Include Minidlna UPnP mediaserver. ~1.6MB
#CONFIG_FIRMWARE_INCLUDE_MINIDLNA=y
### Include Firefly iTunes mediaserver. ~1.0MB
#CONFIG_FIRMWARE_INCLUDE_FIREFLY=y
### Include ffmpeg 0.11.x instead of 0.6.x for Minidlna and Firefly. ~0.1MB
#CONFIG_FIRMWARE_INCLUDE_FFMPEG_NEW=y
### Include Transmission torrent. openssl ~1.2MB, transmission ~1.5MB
#CONFIG_FIRMWARE_INCLUDE_TRANSMISSION=y
### Include Transmission-Web-Control (advanced WebUI). ~0.8MB
#CONFIG_FIRMWARE_INCLUDE_TRANSMISSION_WEB_CONTROL=y
### Include Aria2 download manager. openssl ~1.2MB, aria2 ~3.5MB
#CONFIG_FIRMWARE_INCLUDE_ARIA=y
### Include TOR proxy ~2.3MB
#CONFIG_FIRMWARE_INCLUDE_TOR=y
### Include GeoIP database info for TOR proxy ~3MB
#CONFIG_FIRMWARE_INCLUDE_TOR_GEOIP=y
### Include GeoIPv6 database info for TOR proxy ~8.5MB
#CONFIG_FIRMWARE_INCLUDE_TOR_GEOIPV6=y
### Include privoxy proxy ~0.3MB
#CONFIG_FIRMWARE_INCLUDE_PRIVOXY=y
### Include dnscrypt-proxy ~0.3MB
#CONFIG_FIRMWARE_INCLUDE_DNSCRYPT=y
### Include WPAD support
#CONFIG_FIRMWARE_INCLUDE_WPAD=y
### Include compressed memory support
CONFIG_FIRMWARE_INCLUDE_ZRAM=y
### Connection settings SSH PROMETHEUS
### IP
IPWRT=192.168.1.1
### Login
ROOTWRT=admin
### Password
PWDR="admin"
### SSH Port
ssh_port="22"
### Include Aria2 WEB control
#CONFIG_FIRMWARE_INCLUDE_ARIA_WEB_CONTROL=y
### Include alternative L2TP control client RP-L2TP
#CONFIG_FIRMWARE_INCLUDE_RPL2TP=y -
kutga
Intruder2k5
#2123
Napközben Ubuntun futtattam a scriptet, de valami loopba került, ugyanazt tekerte órákig, nem történt semmi.
kutga
Intruder2k5
#2121
Igen, az már nem ment fel. Lassan kiokoskodom hogyan mentsem le a fw-t, mert se a megosztott mappát, se a virtuális géphez adott pendrive-ot nem csatolja fel.
kutga
Intruder2k5
#2119
Igen, ezt valóban kérdezte. Én Padavan-ng stable-t választottam.
Inkább egyenként kapcsolgatom a csomagokat. Ftp szerver belefért, most próbálok egy white témát.
kutga
Intruder2k5
#2116
Persze ha elmondod hogy nyerem ki. Virtualbox image-et használok.MOD
Megtaláltam. -
kutga
Intruder2k5
#2114
Végül semmit.
Még a skin sem fért bele. Mondjuk ennek nem is kell tudnia sokat. -
kutga
Fordítok én is egyet a kis Asusra. Ügyesen kell sakkozni a modulokkal, mert könnyen meghaladja az engedélyezett méretet a firmware.
kutga
Hölgyek/Urak!
Tegnap beállítottam az Asus rt n10 c1 routert az általam készített padavan fw-rel vezetéknélküli kliensnek, de nem vagyok benne biztos hogy mindent jól csináltam, így inkább leírom lépésről lépésre.
1. Első körben reseteltem a routert, az egyik lan ponrtját kábellel csatlakoztattam az otthoni gépbe, böngészőben 192.168.1.1, majd a LAN fülön adtam neki ip címet egy másik tartományban, 192.168.2.1 mondjuk.
2. Ezután az Administration fül alatt átkapcsoltam AP módba.
3. A Wireless bridge fülön kiválasztottam az AP Client (AP disabled) opciót, majd csatlakoztam az otthoni wifi hálózatra.
4. Végül szintén a LAN fülön kézzel megadtam az alapértelmezett átjárónak és a DNS szervernek a fő router ip címét, 192.168.1.1Így most van internet a kliensre vezetékkel kötött eszközökön de akad pár furcsaság.
A kliens router ip címét nem látom a fő router (ez egy TP-Link szintén padavannal) dhcp listájában, nem tudok belépni az admin felületére (192.168.2.1 sem működik).
A másik, hogy minden, a kliens routerre csatlakoztatott eszköznek a fő router admin felületén azonos a mac címe (mégpedig az Asusé).
A kérdésem, hogy ez jól van így?
kutga
Oké, lesz kis időm keresgélek, köszi. Pár hete lomtalanítás alkalmával egy csomó router előkerült amiket még fel lehetne használni, anyáméknak, anyósnak pl, lehetne velük kísérletezni.
MOD
woodworm
Valami Asus, de nincs nálam, otthon megnézem. A tp-link maradt openwrt-n, most az rt n10 c1-et fogtam be megint otthon. -
kutga
Hölgyek/Urak!
Ha a routerem nincs az összefoglaló szerinti listában azt jelenti, hogy egyáltalán nem érhető el rá a padavan, vagy hogy még senki nem csinálta meg?
kutga
Hölgyek/Urak!
TP-Link TL-WR841N v9-re elérhető a Padavan? Az összefoglalóban nem találom, openwrt van rajta, de az nekem egy kissé komplikált. Teszi a dolgát, de ami a Padavan alatt két kattintás, azzal itt küzdeni kell rendesen.
kutga
Intruder2k5
#1939
Így már jó köszi.
kutga
Intruder2k5
#1933
Mit rontok el? Beállítom a tftp-t ahogy kell, indítom a routert recovery módban, felmegy a firstflash, ujraindul és semmi, nem tudok belépni a 192.168.0.1en. A lan led sem világít.
kutga
Hölgyek/Urak!
Végül megrendeltem a TPLink C5v4-et, az összefoglalóban található trx fájlt csak fel kell rá tölteni?
kutga
Intruder2k5
#1920
Valószínű. Egyébként működik a dolog, nem csinál saját alhálózatot mint a ddwrt és valamivel jobb sebességet mértem. Próbálgatom még holnap.
kutga
Intruder2k5
#1917
Basszuskulcs. Nem állítottam be AP módot az Administration fülön.
kutga
Kicsit elakadtam. Arra rájöttem hogy tudok kapcsolódni wifihez, de hogy tudom ezt utána tovább osztani lanon? AP-Client, AP-Client+AP, vagy mi kell hozzá? Lan-wan ip címekhez mit kell megadni?
kutga
Intruder2k5
#1912
Alap minden. Hazaérek megnézem. Milyen címen találom a hálózaton?
kutga
Intruder2k5
#1908
Oké megnézem bár gondolom nem indult volna el ha rossz a partíció.
kutga
Intruder2k5
#1906
A trx fájlt hogy tudom kinyerni?
kutga
Intruder2k5
#1903
Megcsináltam az orosz oldalon található angol image fájllal, van internet. Később még visszanézek a beállításokra, mert egyelőre nem teljesen tiszta honnan kapok ip-t. Az Asust AP-Client módra állítottam és csatlakoztam az itthoni wifire. A sebességre is rámérek majd.
kutga
Intruder2k5
#1898
Elindítottam a scriptet, de látszólag ugyanazokat a csomagokat tölti le folyamatosan. Meddig várjak vele?
kutga
Intruder2k5
#1898
Időm az most van. Ez alatt is van kliens mód ugye?
kutga
Intruder2k5
#1896
Na mindjárt ránézek. Igazából a DDWRT-vel sincs problémám, de ez izgalmasabban hangzik mint valami készet tenni rá.
kutga
Intruder2k5
#1894
Virtuális gépen van Linuxom, mindjárt rá is nézek.
MOD
Ez az oldal viszont igencsak orosz.
kutga
Hölgyek/Urak!
Az Asus rt n10 c1 routerem bent van az összefoglaló listában, mint olyan router amire lehet Padavant fordítani.
Nem igazán értek hozzá, de ez mit jelent? DDWRT felment rá, igazából elég is, de ha ez jobb, akkor megpróbálkoznék vele.
- Asus Vivobook S16 S3607QA-PL018W
- Bomba ár! Dynabook Portege X30-L-K - i7-1260P I 8GB I 256SSD I 13,3" FHD I Cam I W11 I Gari!
- új akku Ár/ÉRTÉK BAJNOK! Dell Latitude 5330 i3-1215U - 16GB 256GB 13.3" FHD 1 év garancia
- Thrustmaster TMX Force Feedback Kormány szett + Playseat 3 hónap Garancia Beszámítás Házhozszállítás
- Apple iPhone 14 Pro Max 128GB Space Black használt, szép állapot 100% akku 6 hónap garancia
