Krszti1660
Krszti1660
#3793
ezt ja ki:S
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'nobody'@'localhost' (using password: NO) in /home/a7726055/public_html/inc/config.php on line 5
include("db.php");
$link = mysql_connect($db_server, $db_user, $db_password) or die("Could not connect");
mysql_select_db($db_name) or die("Could not select database");
$query = "SELECT * from config";
$result = mysql_query($query) or die("Query failed");
while ($row = mysql_fetch_assoc($result)) {
$config[$row['soption']]=$row['svalue'];
$site_name = $config['SiteName'];
$sql="select * from users where userid='1'";
$result = mysql_query($sql) or die("Query failed.");
while ($row = mysql_fetch_array($result))
$support_email=$row['email'];
$server_url = $config['SiteUrl'];
// config options
$version = $config['ScriptVersion'];
$uploads = $config['Uploads'];
$registration = $config['MemberRegistration'];
$validation = $config['EmailValidation'];
$ads = $config['Advertisements'];
$watermarking = $config['Watermarking'];
// thumbnail settings
$dest_height = $config['ThumbHeight'];
$dest_width = $config['ThumbWidth'];
$server_root = $config['SiteRoot'];
$server_directory = "";
$server_save_directory = $server_directory . "/images/"; // /folder/
// do not change the following variables
global $server_dir;
$server_dir = $server_root . $server_save_directory;
$page_url = $server_url . $server_directory;
$image_url = $server_url . $server_save_directory;
$valid_mime_types_display = $config['Extension'];
$valid_file_ext=explode(",",$config['Extension']);
function getSize ($imageurl)
if ( intval(phpversion()) < 5 )
die ( 'PHP5 Required' );
$headers = get_headers($imageurl, 1);
return $headers['Content-Length'];
// Convert a URL to the local file path and vice versa, convert a local file path to a URL.
// this sets the sytem / or \ :
strstr( PHP_OS, "WIN") ? $slash = "\\" : $slash = "/";
// This is the location of the php file that contains this
// function. Usually this request is made to files/folders
// down the directory structure, so the php file that
// contains these functions is a good "where am i"
// reference point:
$WIMPY_BASE['path']['physical'] = getcwd();
$WIMPY_BASE['path']['www'] = "http://".$_SERVER['HTTP_HOST'];
function url2filepath($theURL){
global $WIMPY_BASE, $slash;
$AtheFile = explode ("/", $theURL);
$theFileName = array_pop($AtheFile);
$AwimpyPathWWW = explode ("/", $WIMPY_BASE['path']['www']);
$AtheFilePath = array_values (array_diff ($AtheFile, $AwimpyPathWWW));
if($AtheFilePath){
$theFilePath = $slash.implode($slash, $AtheFilePath).$slash.$theFileName;
} else {
$theFilePath = implode($slash, $AtheFilePath).$slash.$theFileName;
return ($WIMPY_BASE['path']['physical'].$theFilePath);
function filepath2url ($theFilepath){
$AtheFile = explode ($slash, $theFilepath);
$AwimpyPathFILE = explode ($slash, $WIMPY_BASE['path']['physical']);
$AtheFilePath = array_values (array_diff ($AtheFile, $AwimpyPathFILE));
$thFileURL = implode("/", $AtheFilePath)."/".$theFileName;
return ($WIMPY_BASE['path']['www']."$thFileURL");
?>a db.php-ban meg nincs semmi
Krszti1660
Sk8erPeter
#3791
most fel akarok tenni egy másik motort és az instalnál ezt írja ki:
File ' . $db_file . ' is not writable. Please change the access permissions or delete current file.
És a db.php-ben meg nincs semi :S
Krszti1660
Krszti1660
#3786
meg találtam és próbáltam átt írni 777-re de akkor sem jó :S
dpi_init.php on line 80 ennek a php-nak a kódját másoltam be.... -
Krszti1660
Na most kérdezek egy láma kérdést:
session_start();
list($usec, $sec) = explode(" ", microtime());
$START_TIME = ((float)$usec + (float)$sec); $WIPED_TIME = 0;$root_path ="{ROOT_PATH}";
$cdomain ="{C_DOMAIN}";if(!DEFINED('NOGZ') && eregi('gzip',$_SERVER['HTTP_ACCEPT_ENCODING'])) @ob_start("ob_gzhandler");
REQUIRE_ONCE( './includes/dpi_functions.php' );
REQUIRE_ONCE( './includes/dpi_temp.php' );
REQUIRE_ONCE( './includes/dpi_specials.php' );
REQUIRE_ONCE( './includes/dpi_iptc.php' );
REQUIRE_ONCE( './includes/dpi_custom.php' );$settings = load_settings();
DEFINE('TEMP_DIR', "./theme/$settings[theme]/templates");#Load the Global Settings
$meta_tags = eval_template('header_meta_tags');
$header_right = eval_template('header_right');
$myurl = urlencode("http://$_SERVER[HTTP_HOST]$_SERVER[REQUEST_URI]");$center = ''; #Initialize center content
$title = '';
$logged_user = FALSE;if(isset($_COOKIE['user'])) {
@list($id,$pass) = @explode(',',$_COOKIE['user']);
$id = _html($id);
$pass = _html($pass);
$USR = user($id);if($USR) {
if(md5($USR['password']) == $pass) {
$logged_user = html_arr($USR);
$admincp_link = strtolower($settings['admin_user']) == strtolower($logged_user['username']) ? eval_template('user_admin_link') : '';if($logged_user['locked'] == 'Y') {
setcookie('user','',time(),'/',$cdomain);
echo "Automatically logging out, your account has been suspended by administrator.<br>";
redirect("$root_path/index.php",3);
die();
}$header_links = eval_template($logged_user ? 'user_links' :'visitor_links');
$V_TIMAGES=false;
if(!$logged_user) {
if(isset($_SESSION['s_'.md5(_ip())])) {
$total_images = substr_count($_SESSION['s_'.md5(_ip())],',');
$total_images++;
$series = urlencode(base64_encode($_SESSION['s_'.md5(_ip())]));
$header_links .= eval_template('visitor_totals');
$V_TIMAGES=true;
}$iarchive_p1 = date("Y_F_d",filemtime(DATA_DIR."/LID"));
$css = eval_template("css");Ezt írja ki: warning : File/Folder is not writable (chmod to 777 through FTP)
és nem is találom a chmod-ot :S
Krszti1660
Tele von Zsinór
#3765
ezt komplett át kellene nézni és aztán vagy meg csinálni vagy pedig hagyni a francba. Így is ki fizettem a domain-t...
Szóval csak át kéne nézni
Krszti1660
Tele von Zsinór
#3753
Na sziasztok
Nekem egy programozó kellene
Egy mmorpg maffiás játékot szeretnék elindítani és ennek az oldal motrát kellene át nézni. Domain, tárhely már meg van ha az oldal motort is meg tudná valaki nézni mindjárt lehet is fordítani le és indulhat a játék
Kérlek valaki írjon PM-et vagy pedig itt
Krszti1660
Tele von Zsinór
#3753
Hát most nem tudok kérdezni mert hulla fáradt vagyok de kb holnap este 18óra fele ha lehet akkor fel jövök és beszélünk
Krszti1660
Kellene nekem egy profi php-s aki érti a mysql-t is
Szóval van egy játék motrom és nem működik :S
azért mert állítólag a mysql- lekérdezések nem jók. Aki tud az írjon!
- Hardcore pizza és kenyér topik
- MWC 2026: Hálózattechnológiai mélyvíz Bóday Tamással. Mint rendesen.
- Jogász topik
- ASUS routerek
- Mini-ITX
- VGA kibeszélő offtopik
- Komplett RGB Gamer PC / RTX 3080 / i5-12490F / 32GB DDR5 / 250GB & 1TB SSD / IRÁNYÁRAS
- Magyar kiosztású Apple Magic Keyboard 2, Touch ID, teljes méretű
- Új Mac Studio M4 Max 2025 14C CPU /32C GPU / 36GB RAM / 512GB - 1 ÉV APPLE GARANCIA
- 2026 MacBook Air / MacBook Pro / M5 - M5 Pro - M5 MAX 14" / 16"
- Asus 15.6,core i3 8145U(4x3,9Ghz)IntelUHD VGA,MAGYAR Vil.bill.,8-20GB RAM,SSD+HDD?,,Win.11
