Archttila
Raspberry Pi szerveren fut egy qbittorrent-nox ami ala raktam egy post scriptet, hogy kitakaritsa a letoltott anyagokbol a szemetet (nfo, txt, exe) ezzel nincs is gond mukodik szepen, viszont jo lenne ha at is nevezne a tartalmakat. Erre talaltam egy powershell-lel mukodo megoldast amit megprobaltam lefordittatni Linux szamara is ertelmezheto kodda de hibaval elszall. Ime a wines code#THIS PART CLEANS UP THE FILE NAMES #REMOVE DOTS get-childitem -recurse | dir -Filter *.mp4 | Rename-Item -NewName { $_.BaseName.replace('.',' ') + $_.Extension } get-childitem -recurse | dir -Filter *.mkv | Rename-Item -NewName { $_.BaseName.replace('.',' ') + $_.Extension } #SPACE OUT SEASONS AND EPISODES - UPPER CASE get-childitem -recurse | dir -Filter *.mp4 | Rename-Item -NewName { $_.BaseName.replace(' S01E',' S01 E').replace(' S02E',' S02 E').replace(' S03E',' S03 E').replace(' S04E',' S04 E').replace(' S05E',' S05 E').replace(' S06E',' S06 E').replace(' S07E',' S07 E').replace(' S08E',' S08 E').replace(' S09E',' S09 E').replace(' S10E',' S10 E').replace(' S11E',' S11 E').replace(' S12E',' S12 E').replace(' S13E',' S13 E').replace(' S14E',' S14 E').replace(' S15E',' S15 E') + $_.Extension } get-childitem -recurse | dir -Filter *.mkv | Rename-Item -NewName { $_.BaseName.replace(' S01E',' S01 E').replace(' S02E',' S02 E').replace(' S03E',' S03 E').replace(' S04E',' S04 E').replace(' S05E',' S05 E').replace(' S06E',' S06 E').replace(' S07E',' S07 E').replace(' S08E',' S08 E').replace(' S09E',' S09 E').replace(' S10E',' S10 E').replace(' S11E',' S11 E').replace(' S12E',' S12 E').replace(' S13E',' S13 E').replace(' S14E',' S14 E').replace(' S15E',' S15 E') + $_.Extension } #SPACE OUT SEASONS AND EPISODES - LOWER CASE NAMING TO UPPER CASE get-childitem -recurse | dir -Filter *.mp4 | Rename-Item -NewName { $_.BaseName.replace(' s01e',' S01 E').replace(' s02e',' S02 E').replace(' s03e',' S03 E').replace(' s04e',' S04 E').replace(' s05e',' S05 E').replace(' s06e',' S06 E').replace(' s07e',' S07 E').replace(' s08e',' S08 E').replace(' s09e',' S09 E').replace(' s10e',' S10 E').replace(' s11e',' S11 E').replace(' s12e',' S12 E').replace(' s13e',' S13 E').replace(' s14e',' S14 E').replace(' s15e',' S15 E') + $_.Extension } get-childitem -recurse | dir -Filter *.mkv | Rename-Item -NewName { $_.BaseName.replace(' s01e',' S01 E').replace(' s02e',' S02 E').replace(' s03e',' S03 E').replace(' s04e',' S04 E').replace(' s05e',' S05 E').replace(' s06e',' S06 E').replace(' s07e',' S07 E').replace(' s08e',' S08 E').replace(' s09e',' S09 E').replace(' s10e',' S10 E').replace(' s11e',' S11 E').replace(' s12e',' S12 E').replace(' s13e',' S13 E').replace(' s14e',' S14 E').replace(' s15e',' S15 E') + $_.Extension } #CLEAN UP get-childitem -recurse | dir -Filter *.mp4 | Rename-Item -NewName { $_.BaseName.replace(' ',' ').replace(' ',' ').replace(' ',' ').replace(' ',' ') + $_.Extension } get-childitem -recurse | dir -Filter *..mkv | Rename-Item -NewName { $_.BaseName.replace(' ',' ').replace(' ',' ').replace(' ',' ').replace(' ',' ') + $_.Extension } #REMOVE EVERYTHING AFTER EPISODE get-childitem -recurse | dir -Filter *.mp4 | Rename-Item -NewName { ($_.BaseName -creplace '(?<=S\d+ E\d+)\D.*') + $_.Extension } get-childitem -recurse | dir -Filter *.mkv | Rename-Item -NewName { ($_.BaseName -creplace '(?<=S\d+ E\d+)\D.*') + $_.Extension } exit
Ez pedig a Linux-os: (mar a sajat eleresekkel)#!/bin/zsh# Elérési útvonalakmovies_path="/mnt/PiDrive1/Movies"tv_shows_path="/mnt/PiDrive1/TV Shows"# REMOVE DOTS - MP4find "$movies_path" -type f -name "*.mp4" -execdir zmv '(*).(*.mp4)' '$1 $2' \;find "$tv_shows_path" -type f -name "*.mp4" -execdir zmv '(*).(*.mp4)' '$1 $2' \;# REMOVE DOTS - MKVfind "$movies_path" -type f -name "*.mkv" -execdir zmv '(*).(*.mkv)' '$1 $2' \;find "$tv_shows_path" -type f -name "*.mkv" -execdir zmv '(*).(*.mkv)' '$1 $2' \;# SPACE OUT SEASONS AND EPISODES - UPPER CASE - MP4find "$movies_path" -type f -name "*.mp4" -execdir zmv '(* S[0-9]E[0-9]*)' '$1 E$2' \;find "$tv_shows_path" -type f -name "*.mp4" -execdir zmv '(* S[0-9]E[0-9]*)' '$1 E$2' \;# SPACE OUT SEASONS AND EPISODES - UPPER CASE - MKVfind "$movies_path" -type f -name "*.mkv" -execdir zmv '(* S[0-9]E[0-9]*)' '$1 E$2' \;find "$tv_shows_path" -type f -name "*.mkv" -execdir zmv '(* S[0-9]E[0-9]*)' '$1 E$2' \;# SPACE OUT SEASONS AND EPISODES - LOWER CASE NAMING TO UPPER CASE - MP4find "$movies_path" -type f -name "*.mp4" -execdir zmv '(* s[0-9]e[0-9]*)' '$1 E$2' \;find "$tv_shows_path" -type f -name "*.mp4" -execdir zmv '(* s[0-9]e[0-9]*)' '$1 E$2' \;# SPACE OUT SEASONS AND EPISODES - LOWER CASE NAMING TO UPPER CASE - MKVfind "$movies_path" -type f -name "*.mkv" -execdir zmv '(* s[0-9]e[0-9]*)' '$1 E$2' \;find "$tv_shows_path" -type f -name "*.mkv" -execdir zmv '(* s[0-9]e[0-9]*)' '$1 E$2' \;# CLEAN UP - MP4find "$movies_path" -type f -name "*.mp4" -execdir zmv '(* *)' '$1 $2' \;find "$tv_shows_path" -type f -name "*.mp4" -execdir zmv '(* *)' '$1 $2' \;# CLEAN UP - MKVfind "$movies_path" -type f -name "*.mkv" -execdir zmv '(* *)' '$1 $2' \;find "$tv_shows_path" -type f -name "*.mkv" -execdir zmv '(* *)' '$1 $2' \;# REMOVE EVERYTHING AFTER EPISODE - MP4find "$movies_path" -type f -name "*.mp4" -execdir zmv '(* S[0-9]E[0-9]*)(*)' '$1' \;find "$tv_shows_path" -type f -name "*.mp4" -execdir zmv '(* S[0-9]E[0-9]*)(*)' '$1' \;# REMOVE EVERYTHING AFTER EPISODE - MKVfind "$movies_path" -type f -name "*.mkv" -execdir zmv '(* S[0-9]E[0-9]*)(*)' '$1' \;find "$tv_shows_path" -type f -name "*.mkv" -execdir zmv '(* S[0-9]E[0-9]*)(*)' '$1' \;viszont annak ellenere, hogy az
autoload zmvbe van allitva a.zshrcfajlba (onnalloan el is indul) a scriptet lefuttatva ezt a hibauzetet kapom:find: ‘zmv’: No such file or directorySzerintetek miert nem mukodik?
Archttila
Nem teljesen programozás de szerintem ti tudtok segíteni.
Git repóba szeretném feltolni a konfig fájljaimat, de a GPG-t valami miatt nem akarja az igazat...
Természetesen előtte generáltam kulcsot amit github-on sikeresen hozzá is adtam a profilom-hoz, de már itt elakad őkelme:echo "test" | gpg2 --clearsign ✔ at 17:48:12 -----BEGIN PGP SIGNED MESSAGE-----Hash: SHA256testgpg: signing failed: Inappropriate ioctl for devicegpg: [stdin]: clear-sign failed: Inappropriate ioctl for devicecat .gitconfig[user]signingkey = 52ECEX7C42E28R96email = akarmi@gmail.comname = csokistyuk[commit]gpgsign = true[alias]logs = log --show-signature[gpg]program = gpg2 -
Archttila
Domonkos
#14937
alucard@rpi4 ~]$ file /usr/lib/firefox/firefox/usr/lib/firefox/firefox: ELF 32-bit LSB shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 3.2.0, BuildID[sha1]=e85a2f37d50354822033146e2bacd187746a808e, stripped[alucard@rpi4 ~]$ uname -marmv7lJah igen, a forráskódban x86 arch szerepelt, én meg
makepkg -A-val ARM-re forgattam. Ez lehet gond? -
Archttila
Remélem nem OFF ha igen akkor előre is elnézést kérek, de sajnos máshol nem kaptam segítséget.
AUR repoóból forgattam egy Wayland patchelt Chromium Ozone böngészőt, de sajnos az alábbi hibaüzenettel elhasal:
Csak azt szeretném tudni, hogy mi a problémája a képen látható 109-es sorral.
Raspberry Pi with Arch SwayWM
- Samsung kuponkunyeráló
- Hobby rádiós topik
- MWC 2026: Vitrinben itt a Nothing Phone (4a)
- Apple MacBook
- MWC 2026: Kezünkben a minden tekintetben európai okostelefon
- MWC 2026: Kedves naplóm!
- Apple iPhone 15 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 86%
- Samsung Galaxy A56 5G / 8/256GB / Kártyafüggetlen / 12Hó Garancia / Akku:100%
- Samsung Galaxy S20 Ultra / 12/128GB / Kártyafüggetlen / 12Hó Garancia
- Apple iPhone 13 / 128GB / Kártyafüggetlen / 12Hó garancia / Akku:100%
- Eladó Lian Li UNI FAN SL120 v2 & SL140 v2 (7db 120 & 2db 140)
