Archttila
megprobaltam script formajaban is (mindharom forditasi lehetoseggel) de egyik sem mukodik
script
import osfrom srtranslator import SrtFile#from srtranslator.translators.deepl_api import DeeplApi#from srtranslator.translators.deepl_scrap import DeeplTranslatorfrom srtranslator.translators.translatepy import TranslatePytranslator = TranslatePy()filepath = "/home/alucard/Downloads/film.srt"srt = SrtFile(filepath)srt.translate(translator, "nl", "hu")# Making the result subtitles prettiersrt.wrap_lines()srt.save(f"{os.path.splitext(filepath)[0]}_translated.srt")result
[alucard@arch ~/Downloads]$ python translate.pyLoading /home/alucard/Downloads/film.srt... Translating chunk. 0 %Traceback (most recent call last):File "/home/alucard/Downloads/translate.py", line 9, in <module>srt.translate(translator, "nl", "hu")File "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/srt_file.py", line 154, in translatetranslation = translator.translate(^^^^^^^^^^^^^^^^^^^^^File "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/translators/translatepy.py", line 14, in translateresult = self.translator.translate(^^^^^^^^^^^^^^^^^^^^^^^^^^File "/home/alucard/.local/lib/python3.11/site-packages/translatepy/translate.py", line 135, in translateraise NoResult("No service has returned a valid result")translatepy.exceptions.NoResult: No service has returned a valid resultdeepl api-val is neztem ott
SyntaxError: invalid decimal literaluzenettel fosta ossze magat.Megnezem ezeket hatha [link]
Archttila
-t deeplx-el csak ennyit dob vissza[alucard@arch ~/Downloads]$ python -m srtranslator -t deeplx film.srt -i nl -o huLoading film.srt... Translating chunk. 0 %Traceback (most recent call last):File "<frozen runpy>", line 198, in _run_module_as_mainFile "<frozen runpy>", line 88, in _run_codeFile "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/__main__.py", line 110, in <module>srt.translate(translator, args.src_lang, args.dest_lang)File "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/srt_file.py", line 154, in translatetranslation = translator.translate(^^^^^^^^^^^^^^^^^^^^^File "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/translators/deeplx.py", line 28, in translatereturn self._translate(text, source_language, destination_language)^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/translators/deeplx.py", line 18, in _translatereturn PyDeepLX.translate(^^^^^^^^^^^^^^^^^^^File "/home/alucard/.local/lib/python3.11/site-packages/PyDeepLX/PyDeepLX.py", line 105, in translaterespJson = json.loads(respText)^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3.11/json/__init__.py", line 346, in loadsreturn _default_decoder.decode(s)^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3.11/json/decoder.py", line 337, in decodeobj, end = self.raw_decode(s, idx=_w(s, 0).end())^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3.11/json/decoder.py", line 355, in raw_decoderaise JSONDecodeError("Expecting value", s, err.value) from Nonejson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0) -
Archttila
Az alabbi [link] srt translatort szeretnem hasznalni terminalban, de hibauzenetet kapok:[alucard@arch ~/Downloads]$ python -m srtranslator film.srt -i nl -o huTraceback (most recent call last):File "<frozen runpy>", line 198, in _run_module_as_mainFile "<frozen runpy>", line 88, in _run_codeFile "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/__main__.py", line 9, in <module>from .translators.deeplx import DeeplXFile "/home/alucard/.local/lib/python3.11/site-packages/srtranslator/translators/deeplx.py", line 1, in <module>from PyDeepLX import PyDeepLXModuleNotFoundError: No module named 'PyDeepLX'a
pip install srtranslatorhiba nelkul lefutott... tudnatok segiteni?
Archttila
lsebestyen
#3904
Igen ugy nez ki..
Na midnegy, nezek majd valami mas megoldast.
Koszi
Archttila
BÚÉK mindenkinek!
cousin333 irt nekem anno Waybar-ra egy jópofa kis scriptet, [link] ami sajnos a mai napon már nem töltődött be, íme:
Traceback (most recent call last):File "/home/alucard/.config/waybar/modules/./weather.py", line 13, in <module>temp = re.match(re_fmt, summary[0].text_content()).group()IndexError: list index out of rangeSzerintetek mi lehet a gond? Egy időjárásmodulról van szó egyébként...
Archttila
cousin333
#3485
cousin333
Ma mar nem indult el az altalad irt (eddig tokeletesen mukodo) script. Megnezned nekem hogy mi lehet a gond?
Ezt kopi vissza:[alucard@arch ~/.config/waybar/modules]$ ./weather.pyTraceback (most recent call last):File "/home/alucard/.config/waybar/modules/./weather.py", line 3, in <module>import requestsModuleNotFoundError: No module named 'requests' -
Archttila
cousin333
#3482
#!/usr/bin/env pythonfrom lxml import htmlimport requestsimport jsonlat = "47.95"lng = "21.71"resp = requests.get("https://darksky.net/forecast/{},{}/ca12/en".format(lat, lng))tree = html.fromstring(resp.content)summary = tree.cssselect("span.summary.swap")print(summary[0].text_content().split()[0],"°C")Koszonom sikerult!
Annyi gond van csak vele, hogy ronda mint az elso felesegemUgy kellene kineznie mint a bal oldali a CPU temp-nek csak ikon nelkul. Szerintem az a problema, hogy a script ugy hivja le a temp adatot, hogy odabiggyeszti az ertek moge a "C"-hez tartozo kis karikat. Ha nem tenne akkor kozvetlen a szam moge kerulne a print-ben megadott
°C -
Archttila
Nem ertek a programozashoz, ezert kerlek segitsetek megoldani az alabbi problemat.
Adott a felso waybar amire kitettem egy weather modult. Viszont en azt szeretnem, hogy ne mutassa a min. max. temp-et, csak az aktualisat egy nagy C -vel a vegen.
A keredesem tehat az, hogy kellene atirnom ehhez a kodsor aljan talalhato print funkciot? (bizony ennyire alapszinten vagyok)
Elore is koszi, es bocs a lama kerdesert
A kep tobbi resze most nem fontos (config es style.css)
- 186 - Lenovo Legion 5 (15IRX10) - Intel Core i7-13650HX, RTX 5070 (ELKELT)
- Használt Apple A1243 EMC2171 német kiosztású vezetékes billentyűzet / 12 hónap jótállás
- Apple iPhone 13 Pro Max 128GB,Átlagos,Dobozaval,12 hónap garanciával
- Xiaomi Redmi 9T 64GB, Kártyafüggetlen, 1 Év Garanciával
- BESZÁMÍTÁS! ASRock B650M R7 8700F 32GB DDR5 512GB SSD RX 6800XT 16GB Zalman Z1 PLUS CM 750W
illetve fogalmam nincs merre induljak el a hibakeresesben
